Opinions On This Laptop
by BlueOvalFitter - 07/05/20 08:02 PM
Anyone else see Hamlin hood flap fly out?
by 555 - 07/05/20 07:54 PM
Husqvarna AWD with a Honda engine
by yeehaw1960 - 07/05/20 07:02 PM
Recommended car shipper?
by HawkeyeScott - 07/05/20 06:10 PM
My 2011 Sonata SE 2.0T
by strongt - 07/05/20 05:39 PM
Throwing in the towel on local clothing retailers
by Reddy45 - 07/05/20 05:09 PM
Castrol Edge vs Edge EP
by Gene K - 07/05/20 05:03 PM
Car related YouTube channels
by dishdude - 07/05/20 04:59 PM
Suspension Bushings Oil Resistant?
by TacoFergie - 07/05/20 03:43 PM
Building a solar generator
by BeerCan - 07/05/20 03:22 PM
Used CVT fluid in a power steering application
by mahanddeem - 07/05/20 02:06 PM
New Mobil1 EP HM, API SP label design.
by wemay - 07/05/20 02:00 PM
Generator oil
by Eddie - 07/05/20 01:51 PM
This never ceases to amazing me
by SLO_Town - 07/05/20 01:46 PM
Empty shelves and lack of variety.
by sloinker - 07/05/20 01:17 PM
Mann HU816 (28 month service)
by Barwich - 07/05/20 12:23 PM
Napa Gold 1348 and Mahle OC148 C&P
by BeerCan - 07/05/20 10:38 AM
Turboman92, TrustyAutos, TacoFergie, electro, SilentC
71852 Registered Users
107 registered members (4WD, 72te27, 2010Civic, 18LateModelFan, 14Accent, 9 invisible), 1,780 guests, and 25 spiders.
Topics307,463
Posts5,311,632
Members71,852
Oil filter cutter question #5458002 06/19/20 07:31 PM
supton Offline OP
So I bought one a few years ago, looks like the one below. But one thing that has mystified me is: how do you use it "well"? I've been using it with the filter chucked into a filter wrench so as to get leverage in one hand, holding this cutter in the other. At one point I had the filter clamped down in a vice but after moving my vice hasn't been in a good location to do that--is that the best way, with a large open clear area to spin this cutter around?
Or do most people just spin it around in the air?
I lucked out on the last trip to Walmart and found a filter wrench (socket I guess is the right term) that fits the current fleet--it's been rather annoying to try to use a 3 jaw adjustable wrench with this.
[Linked Image]
2011 Toyota Camry, base, 2.5L/6MT, 206k
2010 Toyota Tundra DC, 4.6L/6AT, 160k
2003 CRV, 2.4L/4AT, 161k
1999 Toyota Camry LE, 2.2L/4AT, 225k
Re: Oil filter cutter question [Re: supton] #5458030 06/19/20 07:55 PM
rollinpete Offline
When you start off just tighten a little then spin it and tighten a little more and keep repeating till your thru. Kinda like cutting a pipe with a pipe cutter. I just bought one recently and made a video with my first one I cut open, I did over tighten when I cut mine, but it still worked. I cut open a Fram Ultra for a up coming video I'm working on.
Pete.
97 Ford Expl.Sport 4.0 ohv 4wd 5spd 190k
SRGT 5w30
Whip City Wrencher
Currently under the influence of oil shocked2
Re: Oil filter cutter question [Re: supton] #5458192 06/20/20 01:02 AM
N
NoNameJoe Offline
N
Tighten it down just enough to get the cutting wheel to bite into the filter, then spin until you score the outside evenly. Advance the wheel and repeat.
Do not tighten it down excessively at each step like the guy in the video did. Doing so will lead to a dent that will be annoying as the wheel runs in and out of the dent while you spin the filter or the tool. Tightening it excessively will also mean you'll have to put more effort into spinning the filter since the wheel is biting into more material. Just do a lot of spinning with shallow bites versus less spinning with deeper bites. Not worth the energy with an oily filter.
Also make sure to lubricate the cutting wheel(s).
2015 Civic LX Coupe
Re: Oil filter cutter question [Re: supton] #5458269 06/20/20 07:11 AM
DuckRyder Offline
What Joe said.
Robert
  • 2019 Volkswagen Jetta R-Line
  • 1972 F100 Ranger XLT (445FE/C6/9” 3.50 Truetrac)
  • 2002 Ford Ranger XLT 4D Supercab 3.0L
Re: Oil filter cutter question [Re: supton] #5459654 06/22/20 07:30 AM
supton Offline OP
Thanks!
