The air coming out of the vents in my Accord felt warmer than usual. I checked the temperature of the air coming out and the driver side vent is registering at 47 degrees F on "LO" on recirculate with a fan speed of 4 out of 7. Passenger side is registering at 45 under same conditions. The temperature outside is 90 F and humidity is 50%. Does this sound normal?
If I increase fan speed the vent temp goes up, I assume that is normal since a higher volume of air is passing through.
