Forums Migration
Please read this thread
High Flow Thermostats
by Nick1994 - 07/12/20 02:51 AM
Hy-per Lube ZDDP Supplement 6pk $13.00
by alchargo - 07/11/20 10:38 PM
97 Civic HX valve cover pics
by CARJ - 07/11/20 10:22 PM
Time to ditch Speedplays
by UG_Passat - 07/11/20 10:03 PM
Dale L Nuzum
by Dalenuzum - 07/11/20 10:02 PM
*BANG* (Garage Door Spring)
by ctechbob - 07/11/20 09:40 PM
TPMS Sensors
by 92saturnsl2 - 07/11/20 09:16 PM
Chevron Delo 400 XSP 5W-30 XSP
by Gene K - 07/11/20 08:48 PM
LED retrofit for recessed can lights
by Donald - 07/11/20 07:08 PM
PP HM 5W-20 $15 at Wally
by Jackson_Slugger - 07/11/20 07:03 PM
Defeated by roll pin
by bcossa2001 - 07/11/20 06:56 PM
Dexron VI in place of Mercon LV?
by BigLee - 07/11/20 06:50 PM
89 c4 oil
by dogememe - 07/11/20 06:17 PM
Noticed the Titanium info.
by Farnsworth - 07/11/20 06:16 PM
FebiBilstein Parts
by willbur - 07/11/20 06:03 PM
Life goes on
by 53' Stude - 07/11/20 06:02 PM
Lubegard in a GM transfer case?
by BlakeB - 07/11/20 05:21 PM
Is MSO2 Liquid Moly OK in DIG NA engines
by JimPghPA - 07/11/20 03:10 PM
Rider Magazine Question
by Smoky14 - 07/11/20 02:38 PM
cadillactech, ILoveOil111, quantalume, SUmeme22, DaveCaddell
71910 Registered Users
38 registered members (Ausfahrt, A_A_G, blufeb95, 53' Stude, 2009Edge, 5 invisible), 730 guests, and 23 spiders.
Topics307,747
Posts5,316,948
Members71,910
A/C temperature at vent... #5457838 06/19/20 04:09 PM
G
gregk24 Offline OP
G
The air coming out of the vents in my Accord felt warmer than usual. I checked the temperature of the air coming out and the driver side vent is registering at 47 degrees F on "LO" on recirculate with a fan speed of 4 out of 7. Passenger side is registering at 45 under same conditions. The temperature outside is 90 F and humidity is 50%. Does this sound normal?
If I increase fan speed the vent temp goes up, I assume that is normal since a higher volume of air is passing through.
2012 Honda Accord EX-L K24z3
61,xxx miles
PPPP 0w20 / Fram Ultra
2014 VW Jetta SE 1.8T ea888
54,xxx miles
Castrol Edge 0w40 / OEM filter
Re: A/C temperature at vent... [Re: gregk24] #5457865 06/19/20 04:36 PM
T
tiger862 Offline
T
Normal
Tiger862
2018 Grand Caravan
Re: A/C temperature at vent... [Re: gregk24] #5457868 06/19/20 04:39 PM
E
eljefino Offline
E
43' from mine, yours aren't too far off.
Re: A/C temperature at vent... [Re: gregk24] #5457871 06/19/20 04:40 PM
P
PowerSurge Offline
P
Your AC is working well. That’s a great temp for an ambient temp of 90.
1993 Porsche 964, 2001 Ford SVT F-150 Lightning, 2004 Chevrolet Corvette, 2018 Toyota Tundra 5.7L
Re: A/C temperature at vent... [Re: gregk24] #5457905 06/19/20 05:29 PM
L
Lou_Boyle Offline
L
Under those conditions you have a HUGE humidity load. Prob 50-60% of the cooling power is consumed in squeezing the water out of the air.
Re: A/C temperature at vent... [Re: gregk24] #5457930 06/19/20 05:54 PM
W
WyrTwister Offline
W
Sounds like it is doing OK .
Wyr
God bless
Re: A/C temperature at vent... [Re: gregk24] #5457974 06/19/20 06:55 PM
W
willbur Offline
W
Wanna measure at the vent closest to the evaporator, fan set on low+ (2), all windows open, outside temp taken near condenser. By way of comparison, my center vent temp was 36.7 and near condenser it was 90. Brrrr
Re: A/C temperature at vent... [Re: gregk24] #5458056 06/19/20 08:26 PM
Nick1994 Offline
Sounds ok, is this at idle or driving? A/C performance will likely be better as you're going down the road.
2015 Hyundai Genesis 5.0L 63k Dealer Bulk SynBlend 5w20 & OEM
2000 Toyota Camry 2.2L 239k Mobil Delvac 15w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 150k Rotella Gas Truck 5w30 & Wix
Re: A/C temperature at vent... [Re: gregk24] #5458074 06/19/20 08:56 PM
demarpaint Offline
That sounds a bit on the warm. A sticking blend door can cause issues not related to the AC itself. That would be something I'd check before connecting my manifold gauges.
God Bless Our Troops
Re: A/C temperature at vent... [Re: gregk24] #5458099 06/19/20 09:32 PM
1
14Accent Offline
1
If those are idle numbers at a stop, that's pretty good. A 40-45 degree drop from ambient is considered acceptable by most manufacturers, so you're right there.
Your Accord likely has an evaporator temperature sensor that tells the climate control when the core gets too cold to prevent freezing. My '03 Marauder had one, and while cruising it wouldn't let the AC get colder than about 38* at the center vents while cruising in 90 degree temps. Plenty cold, but you could watch the thermometer hit 38, then rise to 41-42, then back down to 38 over and over. My '99 Corolla didn't have a sensor, and the lowest I measured at the center vents on a 90 degree day was 31 degrees before it cut off (I'm assuming from the low pressure switch cutting out due to the low temp).
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
1980 Honda CB900C - 15k mile cream puff
Re: A/C temperature at vent... [Re: gregk24] #5458112 06/19/20 09:48 PM
dan_erickson Offline
My previous Accord from that era seemed like the AC was never cold enough even though the system was operating like it should. That’s just the way it is.
My 9th gen V6 is a little better but still not what I would consider fantastic
15 Accord Coupe EX-L V6 Navi
Castrol Magnatec 0w20
Re: A/C temperature at vent... [Re: Nick1994] #5458145 06/19/20 10:40 PM
G
gregk24 Offline OP
G
Those temps were taken at idle. I'll drive it tomorrow morning and try to measure the temp when at speed.
61,xxx miles
54,xxx miles
