Put Bilsteins on the Silverado
by bdcardinal - 07/04/20 12:19 PM
Hour meter - not moving?
by Serge - 07/04/20 11:52 AM
Was in a Parade today!
by sasilverbullet - 07/04/20 11:40 AM
Amsoil bypass kit ford 6.7 (BMK33)
by willypete - 07/04/20 11:39 AM
Should I buy a "B" Temperature tire for 2016 Pilot?
by oily boyd - 07/04/20 11:15 AM
Happy 4th of July
by 4WD - 07/04/20 09:12 AM
Collective car nouns, real and imagined
by MrHorspwer - 07/04/20 08:44 AM
Motorcraft FL-820S, ~9000 miles
by robertcope - 07/04/20 08:42 AM
FJC Foaming Evaporator Cleaner Review
by Reddy45 - 07/04/20 12:10 AM
Ford 351W oil filter best value
by alex16 - 07/03/20 11:12 PM
Super tech euro 5w40 - Canada
by Johan1 - 07/03/20 10:19 PM
Strangers show up for vet's funeral.
by simple_gifts - 07/03/20 09:44 PM
Troybilt tb22ec refuses to run correctly
by Dogred08 - 07/03/20 09:43 PM
Harbor Freight Nitrile gloves
by 1978elcamino - 07/03/20 09:04 PM
Did anyone get a 25% coupon for July 4th?
by 1978elcamino - 07/03/20 08:58 PM
05 4.6 Northstar crank sensor re learn?
by cknight49090 - 07/03/20 08:40 PM
In the year 2049...
by eljefino - 07/03/20 08:05 PM
Johan1, MrMoneyMcLube, JeffAR, ThaKid22, Speedeuphoria
71843 Registered Users
88 registered members (bdcardinal, benjy, 555, BeerCan, aquariuscsm, 94astro, 7 invisible), 2,044 guests, and 29 spiders.
Topics307,409
Posts5,310,576
Members71,843
06'Acura TSX A/C question #5457754 06/19/20 01:57 PM
K
Kozman011 Offline OP
K
Hello all,
Little confused here. Replacing compressor and condenser on a 2006. I think the compressor has gone bad. Got 245K out of her. My questions are as follows:
1. Do I need to have the system evacuated AND flushed prior to disassembly?
2. Adding oil to compressor. Do I do that or let the shop add it when they recharge system?
3. If I do it, what amount do I add for replacing the compressor and condenser?
4. Do I drain all the oil out of the new compressor if it was shipped with oil?
Thank you for any help you can send my way!
Re: 06'Acura TSX A/C question [Re: Kozman011] #5457767 06/19/20 02:13 PM
Donald Offline
You may need to replace a few other parts like orifice. Good time for o-rings also. The T134a should be removed prior to disassembly not just dumped into atmosphere. The compressor may ship with oil.
If the compressor really went bad there can be pieces of metal all through the system.
Bring the new compressor to the shop and have them do the work.
2015 Ford F-250 w/Powerstroke
Re: 06'Acura TSX A/C question [Re: Kozman011] #5457770 06/19/20 02:15 PM
Donald Offline
While you may same a little money buying your own compressor if there is an issue you will need to pay for more labor. The shop will not warranty anything. The manufacturer of the compressor may give you a new one under warranty but no labor,
Re: 06'Acura TSX A/C question [Re: Kozman011] #5457782 06/19/20 02:41 PM
K
K
Just looking to get about another year out of the car. NOT giving a shop 1K plus to put a compressor in. It's way to easy to remove/replace on the Honda K24. Can they evacuate and then flush the system in case there is junk floating around, prior to me changing out the compressor and condenser?
Re: 06'Acura TSX A/C question [Re: Kozman011] #5457844 06/19/20 04:12 PM
M
mk378 Online Content
Online Content
M
Either do it right (starting with an actual diagnosis, not "I think the compressor has gone bad"), or roll down the windows. It seems to me any money you spend on the path you're going will just be wasted.
Re: 06'Acura TSX A/C question [Re: mk378] #5457859 06/19/20 04:32 PM
G
Gebo Offline
G
mk378 speaks truth. Been there, done that, not pretty, pretty stupid on my part. Why was I so hard headed?
'98 LEX LS400 310K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 75K
Shell Gas and Truck 5w-30
Amsoil OE 10w-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: 06'Acura TSX A/C question [Re: Kozman011] #5457897 06/19/20 05:17 PM
Chris142 Offline
Can't flush a parallel flow condenser or expansion valve. Both must be replaced if the compressor blew up.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: 06'Acura TSX A/C question [Re: Kozman011] #5457940 06/19/20 06:04 PM
K
K
I will be replacing those parts as well.
Re: 06'Acura TSX A/C question [Re: Kozman011] #5458003 06/19/20 07:32 PM
cpayne5 Offline
You must (I think) pull the evaporator to replace the TXV. Pretty sure it cannot be accessed from underhood. If you're going that far, may as well replace the evaporator. The only components remaining in the system are the lines, which are trivial to flush at that point. Since you've replaced basically the entire system, you can then just measure how much oil is in the new compressor, and subtract that amount from the system total to figure out how much oil you'll need to add to the rest of the system.
I did the same job on my own '06 TSX two years ago. I replaced the compressor, evaporator, TXV, and condenser. Probably around the same mileage as yours. Mine's now at 276k.
The evaporator was leaking, the TXV was failing, and I had already jerry-rigged the compressor clutch (I replaced the thermal switch in the coil and re-shimmed it) a few years prior. It was time for an overhaul and it's been working great ever since.
Re: 06'Acura TSX A/C question [Re: cpayne5] #5458076 06/19/20 09:00 PM
K
K
Yep, I've already rigged the clutch about 20K ago. Glad to hear it worked out for you!!
Re: 06'Acura TSX A/C question [Re: Kozman011] #5458090 06/19/20 09:25 PM
cpayne5 Offline
Here's a video that shows the evap & txv replacement on an Accord. I used the video as a guide when I did my TSX. There are some minor differences with the Accord, but they're similar enough to where the video is very helpful.
https://www.youtube.com/watch?v=2Ftwfxp0_Qg
Re: 06'Acura TSX A/C question [Re: cpayne5] #5458296 06/20/20 07:53 AM
K
K
Thank you. That video will come in very handy as it appears the evap/expansion valve are the hardest part of the job. Much appreciated!
