Forums Migration
Please read this thread
anyone noticed worse acceleration with fram ultra?
by cals400ex - 07/09/20 08:39 AM
Good article on battery recycling
by Fattylocks - 07/09/20 07:19 AM
Civic rear wheel bearing
by toad - 07/09/20 07:06 AM
Nokian Entyre C/S
by Robster - 07/09/20 06:00 AM
Corolla Cross
by wemay - 07/09/20 05:51 AM
Pennzoil strikes again with PDS (Euro 5W40)
by edyvw - 07/09/20 01:44 AM
Extra Load tires - Firmer ride?
by Spetz - 07/09/20 12:34 AM
make sure to use a software firewall
by 2004tdigls - 07/08/20 11:02 PM
Castrol 0w40 without LL-01 in BMW S63
by propellerhead78 - 07/08/20 09:59 PM
Automated key duplicators
by y_p_w - 07/08/20 09:59 PM
0W20 vs 5W20 base oils
by aquariuscsm - 07/08/20 09:39 PM
Shell Rotella T6 Multi Vehicle 5w30
by SummitX670 - 07/08/20 08:56 PM
Silicone rubber valve cover gaskets?
by Spetz - 07/08/20 07:59 PM
Back Up Camera
by Redright9 - 07/08/20 07:53 PM
Good Jackstands?
by 2015_PSD - 07/08/20 07:17 PM
Harbor Freight recalls more jack stands
by FordBroncoVWJeta - 07/08/20 07:11 PM
can a family of 4 use 34k gallons
by WhyMe - 07/08/20 05:26 PM
305 SBC Starter Grinding
by WA1DH - 07/08/20 05:19 PM
Ever hit a water meter with your riding mower?
by bchannell - 07/08/20 05:10 PM
99Burbans, EmanInOz, Apollon, lulliya, bike70ride
71894 Registered Users
104 registered members (ARCOgraphite, 2015_PSD, afree, 1911CHAMPION, amh, 4WD, 9 invisible), 1,789 guests, and 44 spiders.
Topics307,632
Posts5,314,667
Members71,894
2005 Scion TC atf question #5457701 06/19/20 12:48 PM
R
redlobster Offline OP
R
Can I use this when doing 3x drain and refill?
https://www.bgprod.com/catalog/tran...scosity-full-synthetic-atf/#bg-product-5
I have access to free BG fluids.
I believe factory calls for Toyota WS fluid
Re: 2005 Scion TC atf question [Re: redlobster] #5457703 06/19/20 12:53 PM
JustN89 Offline
Sticking within the BG product line, I believe THIS is the product you'd want to use. It calls out Toyota WS specifically.
You know what they say, cross threads are tighter than locktite!
Re: 2005 Scion TC atf question [Re: redlobster] #5457704 06/19/20 12:54 PM
K
kschachn Offline
K
There is no such thing as Dexron VI "low viscosity", so if they are sticking to the properties of Dexron VI licensed fluid then it is the same viscosity as regular Dexron VI. One might assume what they mean is that the initial viscosity of a Dexron VI fluid is somewhat lower than the old Dexron III fluids, but the reason for that is because the Dexron VI fluid is more shear stable than the old Dexron III. As a result once in use the eventual viscosity is either the same or higher.
If your vehicle specifies a Dexron III or VI fluid then yes it will be fine since Dexron VI supersedes Dexron III licensing. What does the owner's manual say for the fluid specification or license?
1994 BMW 530i, 253K
1996 Honda Accord, 289K
1999 Toyota Sienna, 437K
2000 Toyota ECHO, 290K
Re: 2005 Scion TC atf question [Re: redlobster] #5457857 06/19/20 04:30 PM
G
Gebo Offline
G
I'd make sure I used what Toyota calls for. I don't think is is WS but I may be wrong. I think it is T-IV.
'98 LEX LS400 310K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 75K
Shell Gas and Truck 5w-30
Amsoil OE 10w-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: 2005 Scion TC atf question [Re: Gebo] #5458793 06/20/20 09:15 PM
R
R
Looked up the manual online and it does call for T-IV, maybe Mobil 1 atf instead?
