I tend to agree. ^^^^^
The CVT fluid in my car was so clear and clean when I first checked it I could hardly see it at all on the stick. And it stated that way from 40,000 all the way up until 120,000+ miles. Even then it was still hard to see. The CVT fluid did start to have more color after 200,000 miles. By the time I changed it at 283,500 miles it had the same color as motor oil with 2,000 miles on it. With the 4 drain and refills I have done on my car the CVT fluid is now back to where I can't hardly see it again.
The color change was likely due to oxidation of the CVT fluids many, many miles and heat cycles pit on it. The vast majority of the miles on my car have been cruising at highway speeds 64-79 mph. That obviously helped keep the overall fluid temperature down a fair amount. Eventually the heat that it was being put through caused the subtle yet steady change in it's appearance.
What prompted me to change the CVT fluid was the noticeable noise increase especially at cooler temps after start up in September. After the first 3 drain and refills it was way, way quieter than it was before. I knew with winter coming it would be best to change it out before it got really cold.
I do agree with Dr. Molakule that we cannot know the true state aka viscosity, any wear metals present or depletion of the additives, or the TBN or TAN of the CVT fluid just by observation with our eyes.
I do believe that when fluid color does change it is worth paying attention to. And especially if the fluid color changes rapidly... A slow very subtle change is not a unexpected finding. And yes, it is not truly definitive way to assess a fluid's viability or how much life could be left in it. Obviously lab analysis is needed for a definitive answer to that.
My car does have the internal ECM function where it will let you know when the fluid needs to be changed by the deterioration date of 210,000... Obviously it's not set by miles because I went well beyond that
In all my reading up on this system it became quite clear that those people who had their vehicles scanned by the Consult tool their deterioration numbers were actually quite low. The highest one I saw one guy who's number was 56,000 in just 66,000 miles of driving. Most other results were well, well less than that.
