Forums Migration
Please read this thread
07 Tahoe trans fluid change.
by Anthony - 07/07/20 06:06 AM
Ravenol 15W40 Marine
by Realfine69 - 07/07/20 05:10 AM
2020 VW 0W20??
by Realfine69 - 07/07/20 05:06 AM
Who makes the O'reillys trans filters ??
by GMguy84 - 07/07/20 05:00 AM
[Seattle Craigslist] Cheap Pennzoil 5w20
by SlavaB - 07/07/20 02:14 AM
Best Synthetic Oil For Cleaning
by BlueOvalFitter - 07/06/20 11:18 PM
Make your predictions for 20 years from now...
by sloinker - 07/06/20 10:47 PM
Getting rid of carbon in exhaust ports?
by Spetz - 07/06/20 10:15 PM
Rotella Gas Truck 0W-20 VOA
by HDoilDude - 07/06/20 09:57 PM
Two Mobil 1 M1-110A filters. Different sizes
by Dallasmale1970 - 07/06/20 09:46 PM
BITOG forums migrating to Xenforo soon
by wwillson - 07/06/20 09:41 PM
Carburetors - I think I've learned to like them
by Kurtatron - 07/06/20 09:40 PM
Best fuel stabilizer/cleaner ?
by icemanrrc - 07/06/20 09:39 PM
Engine Restorer = Glittery oil?
by nastyc5 - 07/06/20 09:35 PM
MC FL-820S Cut Open
by BlueOvalFitter - 07/06/20 09:03 PM
Flat Back Diff Cover - Failures 🤔
by SavagePatch - 07/06/20 08:52 PM
VW 9M/9G Transmission fluid ?
by JswFL - 07/06/20 08:38 PM
First time UOA. Questionable potassium levels
by chknkatsu - 07/06/20 07:38 PM
STP oil treatment
by wymi516 - 07/06/20 07:12 PM
sycboi, BakonBittz, ssoH, Sumpter_al, Jeffham87
71868 Registered Users
73 registered members (AndyB, alarmguy, ajchien, 4WD, 94astro, antone, 7 invisible), 1,149 guests, and 27 spiders.
Topics307,534
Posts5,312,665
Members71,868
Question on string trimmer / edger #5457677 06/19/20 12:15 PM
F
Fordiesel69 Offline OP
F
I have a cheapie Troy built TB425cs trimmer that can take attachments. The prior owner sunk a ton of money into a tune-up, new carb, and fuel system. I got it for free and it runs very very excellent.
But the issue is the upper driveshaft that is part of the tube (which goes from the engine clutch, half way down to the coupler) is stripped. The male drive haft that is part of the trimmer or edger attachment is just fine and not worn at all.
The part is 100% un-obtanium and the ones I did find are too expensive. I tried to metal epoxy it, and it just strips out in 5 minutes. Does anyone know of a way I can merge the two pieces together permenantly as I only want this as an edger.
99' Crown Vic Police - SAP (P71)
00' Crown Vic Police - SAP (P71)
08' Crown Vics Police - SAP(P71's) (total of 3 garage queens)
13' Taurus Police
14' Fusion S Base
Re: Question on string trimmer / edger [Re: Fordiesel69] #5457681 06/19/20 12:18 PM
Donald Offline
Free isn't always a bargain.
2015 Ford F-250 w/Powerstroke
Re: Question on string trimmer / edger [Re: Fordiesel69] #5457685 06/19/20 12:26 PM
R
ripcord Offline
R
Can you post a pic? A couple of tack welds sound like the solution to me. Might need to cut a temporary access hole in the side of the outer tube to get access.
Re: Question on string trimmer / edger [Re: Fordiesel69] #5457728 06/19/20 01:16 PM
JohnnyJohnson Offline
Sounds like a factory design flaw so you need to buy a new trimmer. my money says this is a common failure.
2004 Corolla 140638
Out: Pennzoil Platinum HM 5W-20 ST 4386
In: Valvoline Synpower Full Synthetic 5W-30 Purolator PureONE
2006 Duramax 77117
Out: T6 5W-40 XG9100 73909
In: Rotella Dino PH9100 11-3-19
Re: Question on string trimmer / edger [Re: Fordiesel69] #5457833 06/19/20 04:03 PM
L
Little_Lebowski Online Content
Online Content
L
Drill tap and set screws?? If it's what I'm thinking.
A picture would help.
Re: Question on string trimmer / edger [Re: Little_Lebowski] #5458404 06/20/20 10:23 AM
J
jeepman3071 Online Content
Online Content
J
+1
1998 Jeep Wrangler Sahara 4.0L/5MT (157k) - PHM 10w30, Wix 51085
2009 BMW 328i N51 (63k) - Liqui Moly 5w40, MANN HU816X
Re: Question on string trimmer / edger [Re: Fordiesel69] #5458492 06/20/20 12:37 PM
P
punisher Offline
P
Assuming it is not pot metal (zinc) find someone who does TIG welding and see if it can be built up, and then filed out to size.
EDIT: 753-04503 Boom Assembly
https://www.amazon.com/MTD-Replacem...=753-04503&qid=1592675661&sr=8-4
Evidently Ryobi might make these now, or bought the rights to MTD.
Re: Question on string trimmer / edger [Re: Fordiesel69] #5459352 06/21/20 05:48 PM
super20dan Offline
this is exactly why not to buy these cheap throwaways from big box stores. there is little to no parts support down the line. I don't care if its just for occasional home use-its false economy
99 silverado 5.3
2003 tundra v6
1981 toyota cressida wagon
2003 kia sorento
04 toyota highlander 4cyl 2013 toyota rav4
Re: Question on string trimmer / edger [Re: super20dan] #5459381 06/21/20 07:17 PM
R
RyanY Online Happy
Online Happy
R
It's not just the cheapie units...I had 6 or 7 Stihl trimmers between 5 and 25 years old with un-obtanium fuel tanks, etc and couldn't piece together a single functional unit. I eventually threw in the towel and bought a new one. Even name brands only have obtainable parts for about 10 years.
2007 Cadillac CTS 3.6L >131k miles; mix of PUP/Magnatec 5W-30 + ACDelco PF2129G
2012 Honda Odyssey EX-L >109k miles; QSUD 0W20 + STP S6607XL
Re: Question on string trimmer / edger [Re: Fordiesel69] #5459666 06/22/20 07:45 AM
F
F
A little plot twist to the story......get it....... a plot "t w i s t", like what the drive cable should be doing. Funny huh?
Ended up going down to local power equipment dealer and they ended up having a skid of dead trimmers. Found a nice 2005 era Toro model 51950 that looks like it had the identical drive shaft tube and attachment point.
I planned to swap the tube and stuff over but after stripping this one down it was too good to use for parts. All the issue was one of the centrifugal clutch bolts had backed out locking up the clutch, and the other issue was the muffler was carboned up and plugged. After fixing these two isses the 2 stroke toro is much better and more powerful than the 4 stroke troy built.
Now onto finding another parts trimmer.......or a hack fix....
13' Taurus Police
14' Fusion S Base
Re: Question on string trimmer / edger [Re: Fordiesel69] #5461571 06/24/20 03:24 PM
M
m21bmr Offline
M
A couple of ideas...
1. Find another dead attachment capable trimmer with a good upper pipe & driveshaft as a donor to use with your current engine.
2. If you really only care about effectively making a fixed shaft edger, you could remove the drive shafts from the edger attachment and from the existing upper pipe, obtain a full-length flexible drive shaft from another donor trimmer, and then "permanently" attach the lower shaft to your existing upper shaft using the donor flexible drive shaft. You could cut the end of the upper tube if you need to make a minor adjustment to match the overall tube length needed for the donor drive shaft.
Re: Question on string trimmer / edger [Re: Fordiesel69] #5461842 06/24/20 09:41 PM
P
PantherFan88 Offline
P
These trimmers in in scrap piles of most small engine shops nationwide. MTD makes TB, Crapsman, etc. I see them everywhere with bad carbs because they are too cheap to justify fixing w/labor. Keep looking and you can find one. I think I have a similar Crapsman trimmer in my scrap pile... and 5 or 6 that I can get close to free. PM me a picture of the part and a P/N... those trimmers were and are super duper mass produced. Most parts are readily available cheap.
05 Crown Vic 4.6L - 62k - M1 5w-20 + MC FL820s
14 Yaris 1.5L - 14k - Mobil Super Syn 5w-30 + 90915-YZZF2
05 Tundra 4.7L - 305k - Mobil Super HM 5w-30 + MC FL-400
