65 200 6 mustang running kinda hot
by old1 - 07/04/20 01:30 PM
Neo-protec GT em
by dervdave - 07/04/20 01:19 PM
Mannol 9929 Ester additive
by dervdave - 07/04/20 01:14 PM
2015 Corolla with 7k miles has “soft brakes”
by NHBFAN - 07/04/20 12:30 PM
Put Bilsteins on the Silverado
by bdcardinal - 07/04/20 12:19 PM
Hour meter - not moving?
by Serge - 07/04/20 11:52 AM
Was in a Parade today!
by sasilverbullet - 07/04/20 11:40 AM
Amsoil bypass kit ford 6.7 (BMK33)
by willypete - 07/04/20 11:39 AM
Should I buy a "B" Temperature tire for 2016 Pilot?
by oily boyd - 07/04/20 11:15 AM
Happy 4th of July
by 4WD - 07/04/20 09:12 AM
Collective car nouns, real and imagined
by MrHorspwer - 07/04/20 08:44 AM
Motorcraft FL-820S, ~9000 miles
by robertcope - 07/04/20 08:42 AM
FJC Foaming Evaporator Cleaner Review
by Reddy45 - 07/04/20 12:10 AM
Ford 351W oil filter best value
by alex16 - 07/03/20 11:12 PM
Super tech euro 5w40 - Canada
by Johan1 - 07/03/20 10:19 PM
Strangers show up for vet's funeral.
by simple_gifts - 07/03/20 09:44 PM
Troybilt tb22ec refuses to run correctly
by Dogred08 - 07/03/20 09:43 PM
Johan1, MrMoneyMcLube, JeffAR, ThaKid22, Speedeuphoria
71843 Registered Users
92 registered members (Bill_W, BAJA_05, 55hambone, ABN_CBT_ENGR, alchargo, 12 invisible), 1,817 guests, and 26 spiders.
Topics307,414
Posts5,310,628
Members71,843
Prestone Asian power steering fluid and brake fluid for Honda Accord. #5457617 06/19/20 10:22 AM
A
aquariuscsm Offline OP
A
Stopped by AZ to browse. They have Prestone Asian formula power steering fluid (lists Honda on the label). Also saw various brake fluids including Pentosin (I think I spelled that right?). Would these fluids be as good and /or better than oem Honda dealership fluids to do turkey baster fluid changes?
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Pennzoil Platinum High Mileage 10W30
Re: Prestone Asian power steering fluid and brake fluid for Honda Accord. [Re: aquariuscsm] #5457634 06/19/20 10:52 AM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
Honda PSF is cheap enough on Ebay/Amazon/discount Honda Dealers online, that I see no reason to go elsewhere. Prestone may be great stuff, if so, evidence would be welcome. Im sure its easier to get and somewhat cheaper...
I run Pentosin and ATE brake fluids in my Euro cars, but have also run a lot of Prestone and Valvoline DOT 4 in various applications. For Hondas, Ive stuck with Honda brake fluid, because I thought there were issues a few years ago with Honda and Toyota brake systems with other fluids. Seems contrary to what Id expect for something as simple and consistent with brake fluid. But I havent used much yet...
Re: Prestone Asian power steering fluid and brake fluid for Honda Accord. [Re: aquariuscsm] #5457638 06/19/20 10:53 AM
SevenBizzos Offline
I used that the entire time I owned an Accord. It's cheap and easy to find.
2018 Ford Edge Sport 23k - Amsoil XL 5W-30, EA15k43
2009 Hyundai Sonata V6 Limited 177k - Mobi1 5W-30 HM, Puralator Pure One PL-35610
2002 Mustang GT 76k - Amsoil XL 5W-30, EA011,Rained on 8 times
Re: Prestone Asian power steering fluid and brake fluid for Honda Accord. [Re: JHZR2] #5457641 06/19/20 11:01 AM
B
blufeb95 Online Content
Online Content
B
The prestone powersteering fluid is pretty expensive it's like $7 for a 12oz bottle, it's actually cheaper to buy OE Honda, I used the prestone stuff in my mother's odyssey when I switched out the fluid a few months ago, it works well enough I guess, not sure there's any reason to use it over the Honda. When I looked at the prestone SDS though it appears to be about half PAO mied with hydrocracked mineral oil so it may be more durable than the Honda fluid.
Re: Prestone Asian power steering fluid and brake fluid for Honda Accord. [Re: blufeb95] #5457661 06/19/20 11:36 AM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
What objective evidence do we have that durability of Honda PSF is an issue, or that oxidation is an issue?
PAO as the end all be all is a wife's tale.
Re: Prestone Asian power steering fluid and brake fluid for Honda Accord. [Re: aquariuscsm] #5457749 06/19/20 01:47 PM
J
JeffKeryk Online Content
Online Content
J
I have used the OReilly house brand for Honda PS fluid. Comes in a quart size.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: Prestone Asian power steering fluid and brake fluid for Honda Accord. [Re: aquariuscsm] #5457764 06/19/20 02:09 PM
J
JEL01 Online Content
Online Content
J
I see no reason not to use Honda OE fluid based on internet horror stories about using the wrong stuff in Hondas, true or wive’s tale I can’t say because I’ve never used anything else
Brake fluid, however, I’ve used Autozone brand, Honda, Prestone and maybe one more over the years and never a problem there
Cars I maintain:
02 Mercedes CLK430
09 Honda Accord V6
13 Lexus RX350 AWD
02 Toyota Tundra 4x4
18 Lexus GX460
Re: Prestone Asian power steering fluid and brake fluid for Honda Accord. [Re: aquariuscsm] #5457799 06/19/20 03:10 PM
R
RyanY Offline
R
Power Steering
Compatible aftermarket PS fluid will work fine. In this case, Prestone Asian has the advantage of being available locally, but it usually costs more than Honda fluid. I currently use Lucas because new Honda fluid did not solve my notchy steering issue but Lucas did. Whatever you choose, just make sure the bottle directly states that it is compatible with Honda.
Brake
Any DOT 3, 4, or 5.1 will work fine in a Honda. I currently use Prestone DOT 3. DO NOT use DOT 5
2007 Cadillac CTS 3.6L >131k miles; mix of PUP/Magnatec 5W-30 + ACDelco PF2129G
2012 Honda Odyssey EX-L >109k miles; QSUD 0W20 + STP S6607XL
Re: Prestone Asian power steering fluid and brake fluid for Honda Accord. [Re: JHZR2] #5457849 06/19/20 04:19 PM
G
Gebo Offline
G
I like it, I love it, I want.....
+1
'98 LEX LS400 310K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 75K
Shell Gas and Truck 5w-30
Amsoil OE 10w-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: Prestone Asian power steering fluid and brake fluid for Honda Accord. [Re: aquariuscsm] #5457963 06/19/20 06:39 PM
slacktide_bitog Offline
Since Prestone stopped making their Honda-specific power steering fluid, they want you to use the Asian fluid at double the price mad
Napa has Idemitsu PSF for less than $4 a bottle. Occasionally, their house brand Honda PSF is even less when on sale. Pep Boys, AAP, and Pep Boys also carry Honda-specific fluids on sale a few times a year.
There is nothing wrong with Pentosin LV brake fluid. It is a great choice. However, the brand you use isn't as important as changing it regularly. Honda says every 3 years, but you can probably get away with flushing it when you replace the pads and rotors. Most cars never get their brake fluid flushed and go to the junkyard on their original fluid.
Re: Prestone Asian power steering fluid and brake fluid for Honda Accord. [Re: aquariuscsm] #5460275 06/22/20 08:54 PM
ctechbob Offline
I've always used Valvoline brake fluid, from back when they had a 'Synpower' one to their current Dot 3/4 stuff. Honda OEM for the PSF. I just like to settle on one thing that works across all my vehicles and then stick with it unless there is a specific performance need that I need to address with a different fluid.
2008 Acura TL Type S-170k
2003 Honda Accord V6-222k
Oil-Havoline HM 5W30
Filter-Partsmaster 61334
Trans-Idemitsu H+
