How To Remove Overspray On Aluminum Wheels?
by NDL - 07/02/20 07:16 AM
Gas Buddy Card to pay?
by Redright9 - 07/02/20 04:35 AM
Pentosin Mania
by Snagglefoot - 07/01/20 11:30 PM
Spills. Synthetic vs petrolium
by Chris142 - 07/01/20 10:35 PM
Michelin Pilot Sport All-Season 4
by FordFocus - 07/01/20 10:04 PM
NGK Ruthenium Spark Plugs
by Deontologist - 07/01/20 07:49 PM
Ram Truck Speaker Upgrade Questions
by edhackett - 07/01/20 07:41 PM
OLM SCREWED UP
by demarpaint - 07/01/20 06:12 PM
Have Valvoline European 5w-40. Use in Cummins?
by RetiredGuyOR - 07/01/20 06:06 PM
Change in evaporation rate over time?
by mosschops - 07/01/20 05:56 PM
17 Golf overzealous OLM/Minder
by lawrencerd - 07/01/20 04:24 PM
First cell phone
by Chris142 - 07/01/20 04:08 PM
Motorcraft FL836 Specifications
by viscous - 07/01/20 03:41 PM
Chipmunks - Damit.
by PontiacHO - 07/01/20 03:37 PM
27/18k portable genset oil.
by 1978elcamino - 07/01/20 03:31 PM
Saw a new BMW and had to do a double take.
by wemay - 07/01/20 02:55 PM
Seems like there is less activity on BITOG
by SLO_Town - 07/01/20 02:21 PM
bigmike323, SolsticeSHO, Bazza32, Klink_II, williamshrader
71828 Registered Users
84 registered members (alarmguy, 1978elcamino, Astro14, anpconnors, 55hambone, AurionX2, 6 invisible), 1,255 guests, and 35 spiders.
Topics307,393
Posts5,309,701
Members71,828
Under the rocker cover TR4. #5457432 06/19/20 05:26 AM
Silk Offline OP
Uh, no, not a TR4, maybe a Standard Vanguard...or a Leyland 20 ? Oh, it's another use of this engine, Massey Ferguson, a 135 in this case. the sludge is mainly water, pretty common in engines of this era - someone has blanked off the breather into the rocker cover.
Can't clean that up, it'll block the pickup screen ! No, we got that covered...the pickup is inside a cover. These engines were designed to be maintained forever. The pickup screen wasn't blocked, but gave it a clean. VERY sludgy inside, scooped it all down the drain hole. I'll let it drain over the weekend.
First Time I've seen a Lucas distributor with a ball bearing...but the shaft is worn at the bottom, trying for a used dist. Got to rebuild the carb too, got a kit coming for that.
IMG_20200619_115614.jpgIMG_20200619_132125.jpgIMG_20200619_155803.jpgIMG_20200619_132057.jpgIMG_20200619_132107.jpgIMG_20200619_115651.jpg
1987 BMW R65 - Penrite VTwin 20-50
2005 Nissan Expert - 5W-30 Castrol Edge
1996 Volvo T5 - Penrite HPR15 - 15W-60. Ryco syntec filter.
Re: Under the rocker cover TR4. [Re: Silk] #5457455 06/19/20 06:40 AM
B
BMWTurboDzl Offline
B
Kerosene bath?
435i
Re: Under the rocker cover TR4. [Re: Silk] #5457537 06/19/20 08:42 AM
W
wings&wheels Offline
W
Interesting disti...can you read a number off of it?
Is that oil sump specific to the TRactor application?
Thx for posting.
'05 Lotus Elise S/C
'85 Land Rover 90 diesel
'74 Triumph TR6
'74 BMW 2002
'72 Land Rover Series III 88"
'99 Porsche 996
'01 Porsche Boxster S (mostly Wife's...)
'19 VW Golf R (Wife's)
Piper Pa28-236
Re: Under the rocker cover TR4. [Re: Silk] #5457539 06/19/20 08:46 AM
A
andyd Offline
A
No draft tube? The Chevy 235 53-63 was another sludge monster. the breather would sludge up. Sonny would take off the tube , soak it in the gas bucket an light on fire on the gravel while I removed sludge from the rockers and valve cover. What a mess. grin2
Thick oil is better grin2
Re: Under the rocker cover TR4. [Re: Silk] #5457565 06/19/20 09:15 AM
N
NormanBuntz Offline
N
Interesting project. Good luck with it.
Porgy Tirebiter: "Heavy on the 30 weight, Mom."
2017 Toyota Camry XLE, 13K, 2nd owner
2007 Honda Ridgeline RTS, 98K, original owner
2007 Infiniti M35, 116K, original owner
Re: Under the rocker cover TR4. [Re: Silk] #5457570 06/19/20 09:18 AM
Donald Offline
There is a place in Trendwell NY that rebuilds old carbs. Does a much better job than just throwing a carb kit at it.
https://www.carbsandkits.com/tc/treadwell.html
2015 Ford F-250 w/Powerstroke
Re: Under the rocker cover TR4. [Re: Donald] #5457969 06/19/20 06:49 PM
A
andyd Offline
A
[quote=Donald]There is a place in Trendwell NY that rebuilds old carbs. Does a much better job than just throwing a carb kit at it.
https://www.carbsandkits.com/tc/treadwell.html[/quo
Silk lives in New Zealand and there's probably some one closer than upstate NY grin2
Re: Under the rocker cover TR4. [Re: Silk] #5458022 06/19/20 07:48 PM
B
bunnspecial Offline
B
I often joke about the BMC B series engine(as used in the MGA and MGB among others) being a tractor engine, but I don't think it was ever actually used in a production tractor. It's nice to see that the Triumph engine can quite literally claim to be one smile -more fuel for the MG-Triumph rivalry.
Of course, I'd better watch it since there's a beautiful +4 that I've been talking to a local shop now for about 5 years(they've never priced it to me, but I think he's ready to move it) and I'm 99% sure it's one that has a Triumph engine.
2010 Lincoln MKZ-Mobil 1 5W-30
1970 MG MGB Roadster-Valvoline VR-1 20W-50
1974 Austin Marina GT VR-1 20W-50
Re: Under the rocker cover TR4. [Re: Silk] #5458071 06/19/20 08:51 PM
Silk Offline OP
The Nuffield tractor had a 3 cyl diesel, or at least the ones I've seen have been. Although I do remember an old Nuffield that had a sidevalve 4 cyl petrol engine, so not under the BMC banner.
The sump is specific for the tractor of course. Standard built the engine for Massey Ferguson, but for their own use in mind too - the Phase One Standard Vanguard came out in 1947, the same year as the tractor. My experience of these engines was in another application. As an apprentice one of our customers had a fleet of Leyland 20 vans that we used to look after, fitted with the larger version of the Vanguard engine. So instead of standing next to an engine fully exposed like this, I was on my knees head down working on the engine. And then of course it was used in the TR Triumphs...but here in NZ they weren't as common as the Vanguard or Leyland 20.
The PCV is a pipe from the rocker cover into the intake manifold, there is a jet on the banjo fitting....someone has put a splitpin in it, and not as a jiggle valve, it's blocking it off. I'll have to see how it runs to see why. It is in for not starting and fuel running out the carb, but of course we need to look at the ignition as well...and we figured the tappets haven't been set for a couple of decades, or more. Carb kit is not a problem, our tractor parts supply lists one. Dist could be tricky, but sure to be one around.
Here is a Leyland 20, or 15, and a Phase 1 Van guard.
[Linked Image from britishtelephones.com]
[Linked Image from upload.wikimedia.org]
Re: Under the rocker cover TR4. [Re: Silk] #5458181 06/20/20 12:16 AM
Silk Offline OP
So, what shall I put in it ? Between our bulk oils - Delvac MX 15W-40, or Repsol 10w-40 A3/B4. Both are stout oils and able to take the obvious customer neglect...I'm leaning to the Repsol.
Re: Under the rocker cover TR4. [Re: Silk] #5458743 06/20/20 07:42 PM
J
jhellwig Offline
J
So is that a Continental engine? Never looked close at a 135 but it looks odd with that screen on that series. Is it a USA made one or England made? I had thought they went to the Perkins gas engines by then anyways.
Sparks fly from my fingers.
1995 Chevy K2500 Suburban lt 5.7
2014 Toyota Sienna
1983 Chevy K5 350
Re: Under the rocker cover TR4. [Re: Silk] #5458829 06/20/20 10:45 PM
Silk Offline OP
Re: Under the rocker cover TR4. [Re: Silk] #5459190 06/21/20 12:46 PM
J
jhellwig Offline
J
Ah, I misread the first sentence. The head looks like a Continental engine so that had me confused. They must have been making these in a third place than the US and England tractors.
2014 Toyota Sienna
1983 Chevy K5 350
