Pentosin Mania
by Snagglefoot - 07/01/20 11:30 PM
Spills. Synthetic vs petrolium
by Chris142 - 07/01/20 10:35 PM
Michelin Pilot Sport All-Season 4
by FordFocus - 07/01/20 10:04 PM
NGK Ruthenium Spark Plugs
by Deontologist - 07/01/20 07:49 PM
Ram Truck Speaker Upgrade Questions
by edhackett - 07/01/20 07:41 PM
OLM SCREWED UP
by demarpaint - 07/01/20 06:12 PM
Have Valvoline European 5w-40. Use in Cummins?
by RetiredGuyOR - 07/01/20 06:06 PM
Change in evaporation rate over time?
by mosschops - 07/01/20 05:56 PM
17 Golf overzealous OLM/Minder
by lawrencerd - 07/01/20 04:24 PM
First cell phone
by Chris142 - 07/01/20 04:08 PM
Motorcraft FL836 Specifications
by viscous - 07/01/20 03:41 PM
Chipmunks - Damit.
by PontiacHO - 07/01/20 03:37 PM
27/18k portable genset oil.
by 1978elcamino - 07/01/20 03:31 PM
Saw a new BMW and had to do a double take.
by wemay - 07/01/20 02:55 PM
Seems like there is less activity on BITOG
by SLO_Town - 07/01/20 02:21 PM
Rock Auto horrible customer service
by cknight49090 - 07/01/20 02:09 PM
Mobil 1 rebate hassle
by cknight49090 - 07/01/20 02:00 PM
RetiredGuyOR, BretBouer, JKMark, Tugcan, George_Robert
71821 Registered Users
18 registered members (Bjornviken, blufeb95, alcyon, CARJ, Bailes1992, ctechbob, 2 invisible), 650 guests, and 26 spiders.
Topics307,388
Posts5,309,620
Members71,821
What grease for my spicer u-joints 2500 diesel? #5457401 06/19/20 01:57 AM
R
RateNate Offline OP
R
Hey everyone this is for my cummins truck, I had a shop change my original ujoints and they put in a greaseable spicer brand they told me.
The reason im asking this simple question about what grease to use is that I sometimes have floods over some backroads where I live in the winter here in norcal near some farm land and they do flood bad and it gets to my ujoints for sure, and so I was wondering if I could just use one brand and be good or change the grease out to something else during the winter? Currently I have lucas extra HD grease the green stuff in my ujoints, is this alright for my application?
I currently grease it every 5k but I have noticed they start squeaking before that and when new grease goes in it stops for about 3-4k, and also do I pump grease until it purges out or would I pump it a few times and be done? Thank you!
Re: What grease for my spicer u-joints 2500 diesel? [Re: RateNate] #5457428 06/19/20 05:14 AM
Delta Offline
I have the factory Spicer joints in my truck. I've been using Traveller Marine and Off Road grease from Tractor Supply in mine. It's an NLGI #2 rated grease with supposed salt and water resistance. I usually put a couple pumps in every 3-4K (shaft going to the front differential once a year), or to where you can just barely hear it start to seep out. Not sure if this is the proper way, but it's what I've been doing. Also used this grease on my old S10's suspension components and never had any issue.
'17 VW GTI 2.0T - 6MT - 22K - Motul X-Cess 5w40
'15 Camry SE - 2.5 - 27K - Edge 0w20
'09 Tacoma TRD Offroad 4x4 - 4.0 - 142K - RGT 5w30
Re: What grease for my spicer u-joints 2500 diesel? [Re: RateNate] #5457473 06/19/20 07:10 AM
T
TheLawnRanger Offline
T
I've been using Masterpro high temp wheel bearing grease.
2011 Impala
2012 Colorado
2018 Buick Encore
Oil: 5w30 synthetic
Re: What grease for my spicer u-joints 2500 diesel? [Re: RateNate] #5457491 06/19/20 07:43 AM
Snagglefoot Online Content
Online Content
Why not go to the source.
If you want the job done right......do it yourself.
Re: What grease for my spicer u-joints 2500 diesel? [Re: RateNate] #5457530 06/19/20 08:35 AM
B
Bighorn2500 Offline
B
I've been using Schaeffer's 238 or 274 in mine and the ball joints on my truck. Also works well on everything on the tractors as well.
2012 Ram 2500 SLT 6.7L Cummins 4x4
2018 Dodge Durango GT 3.6L 4x4
Re: What grease for my spicer u-joints 2500 diesel? [Re: RateNate] #5457683 06/19/20 12:23 PM
Chris142 Offline
I use Valvoline Chassis grease with Moly. Some will say that Moly is bad in a U-joint. Works well for me.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: What grease for my spicer u-joints 2500 diesel? [Re: RateNate] #5458243 06/20/20 06:23 AM
dlundblad Offline
Lucas red and tacky is a well rounded choice if you have other machines that need greased and only 1 gun.
If not, I’d run that Dana stuff just because.
03 Jeep WJ 4.0 208k
02 Volvo S60 2.4T 199k
97 Chevy Blazer 4.3 175k
04 Audi A4 3.0 210k
Re: What grease for my spicer u-joints 2500 diesel? [Re: Delta] #5459310 06/21/20 04:48 PM
R
RateNate Offline OP
R
Would this grease work if it hits water for a bit? I would prefer to use one grease type and be done with it, since I dont know too much about this lucas XD green grease.
Re: What grease for my spicer u-joints 2500 diesel? [Re: Snagglefoot] #5459311 06/21/20 04:49 PM
R
RateNate Offline OP
R
Good point but that grease is $$ from what ive seen..
Re: What grease for my spicer u-joints 2500 diesel? [Re: dlundblad] #5459312 06/21/20 04:51 PM
R
RateNate Offline OP
R
Would the green HD lucas grease I have just be the same thing? Only reason im asking is because of the flooding I have here in the winter so I dont want that to affect my grease if it cant handle water well.
Re: What grease for my spicer u-joints 2500 diesel? [Re: RateNate] #5459362 06/21/20 06:30 PM
B
BlakeB Offline
B
I’ve been using Delo Grease EP NLGI 2 in everything for a while with no issues. I’m using it in the universal joints on all of our farm equipment PTOs and personal vehicles as well as any equipment wheel bearings I have with a zerk.
[Linked Image]
Re: What grease for my spicer u-joints 2500 diesel? [Re: RateNate] #5459437 06/21/20 08:53 PM
B
buck91 Offline
B
Interesting that you are getting squeaking after a few thousand miles. Wonder if that’s a sign of a warranty issue?
I believe spicer only specifies a nlgi #2 lithium so you should have many affordable and well performing options. If you are really worried about water above all else look and the Schaffer or the amsoil grease. I use that grease Lucas for a GP and bike grease and it seems robust, sorry to hear it’a working poorly for you.
FWIW my all purpose automotive grease gun grease is valvoline synpower but I do use jet lube Simone grease nlgi #3 for poly bushings.
2018 F150 Screw 4x4 2.7L Ecoboost
2011 F150 Scab 4x4 5.0L
1996 Mustang GT 5spd/ragtop
Re: What grease for my spicer u-joints 2500 diesel? [Re: RateNate] #5460655 06/23/20 11:04 AM
L
LubricatusObsess Offline
L
Use what Dana / Spicer recommends for grease constituents. It's been so long, I haven't looked, but I settled on NLGI #2 lithium complex soap thickener, medium vis oil (nonsynthetic since it gets spit out and needs regreasing), and MO2 fine dispersed additive for boundary friction antiwear. I used to use Mobilgrease EP 2 with Moly, but since they consolidated distributors and it's not locally available I switched to Mystik available at Fleet Farm.
Don't know what your Lucas grease is made of.
