Pentosin Mania
by Snagglefoot - 07/01/20 11:30 PM
Spills. Synthetic vs petrolium
by Chris142 - 07/01/20 10:35 PM
Michelin Pilot Sport All-Season 4
by FordFocus - 07/01/20 10:04 PM
NGK Ruthenium Spark Plugs
by Deontologist - 07/01/20 07:49 PM
Ram Truck Speaker Upgrade Questions
by edhackett - 07/01/20 07:41 PM
OLM SCREWED UP
by demarpaint - 07/01/20 06:12 PM
Have Valvoline European 5w-40. Use in Cummins?
by RetiredGuyOR - 07/01/20 06:06 PM
Change in evaporation rate over time?
by mosschops - 07/01/20 05:56 PM
17 Golf overzealous OLM/Minder
by lawrencerd - 07/01/20 04:24 PM
First cell phone
by Chris142 - 07/01/20 04:08 PM
Motorcraft FL836 Specifications
by viscous - 07/01/20 03:41 PM
Chipmunks - Damit.
by PontiacHO - 07/01/20 03:37 PM
27/18k portable genset oil.
by 1978elcamino - 07/01/20 03:31 PM
Saw a new BMW and had to do a double take.
by wemay - 07/01/20 02:55 PM
Seems like there is less activity on BITOG
by SLO_Town - 07/01/20 02:21 PM
Rock Auto horrible customer service
by cknight49090 - 07/01/20 02:09 PM
Mobil 1 rebate hassle
by cknight49090 - 07/01/20 02:00 PM
RetiredGuyOR, BretBouer, JKMark, Tugcan, George_Robert
71821 Registered Users
20 registered members (Bjornviken, alcyon, CARJ, blufeb95, Bailes1992, ctechbob, 2 invisible), 661 guests, and 28 spiders.
Topics307,388
Posts5,309,617
Members71,821
3.0L V6 Accord 2006. M1 5w20 6500miles. Driven Hard. #5457102 06/18/20 04:18 PM
G
Gasbuggy Offline OP
G
This is a Napa oil sample result, I copied the data so you don't have to download a file. No makeup oil added. Had 1 long 1500 mile road trip. The rest mostly 10-20 mile drives with little traffic. Lots of wide-open throttle. Engine seems to run very strong and on the road trip returned a best full tank of 33mpg. Usually, I get about 22 though. The oil had a strong fuel odor but TBN and viscosity look ok.
Does anyone see anything concerning? I ran the sample because the car has a short ram intake on it with a cone filter and I was curious if it was capturing dirt well enough. This car has been running Mobil 1 since it came off a lease in 2009. I refilled with M1 0w30 AFE and a bottle of Lubegard Biotech.
Miles on oil 6567
Mobil 1 SAE 5W20
Metals (ppm)
Iron (Fe) 27
Chromium (Cr) 2
Lead (Pb) 2
Copper (Cu) 2
Tin (Sn) 2
Aluminium (Al) 11
Nickel (Ni) <1
Silver (Ag) <1
Titanium (Ti) <1
Vanadium (V) <1
Contaminants (ppm)
Silicon (Si) 14
Sodium (Na) 9
Potassium (K) 2
Additives (ppm)
Magnesium (Mg) 689
Calcium (Ca) 994
Barium (Ba) <1
Phosphorus (P) 626
Zinc (Zn) 722
Molybdenum (Mo) 76
Boron (B) 47
Contaminants
Water (%) <0.05
Coolant No
Physical Tests
Viscosity (cSt 100C) 8.0
Physical / Chemical
Base Number (mgKOH/g) 3.2
Lab note;
All wear levels appear within acceptable limits for first
sample. Silicon level (dirt/sealant material) satisfactory.
Water content acceptable. Viscosity within specified
operating range. Action: As oil and filter(s) already
changed, resample at next recommended interval to
monitor and establish wear trend.
Re: 3.0L V6 Accord 2006. M1 5w20 6500miles. Driven Hard. [Re: Gasbuggy] #5457200 06/18/20 06:46 PM
ctechbob Online Content
Online Content
I think you'll find that the non-VCM J-Series motor is pretty near bulletproof if you keep up with the maintenance (Including valve adjustments/timing belt) and replace the oil pump seal when it starts to seep (it will). I'm at 230k+ on my J30A4 and it runs as well as it did the day I bought it.
2008 Acura TL Type S-170k
2003 Honda Accord V6-222k
Oil-Havoline HM 5W30
Filter-Partsmaster 61334
Trans-Idemitsu H+
Re: 3.0L V6 Accord 2006. M1 5w20 6500miles. Driven Hard. [Re: Gasbuggy] #5457243 06/18/20 07:55 PM
A
aquariuscsm Offline
A
Seems like alot of iron wear from a Honda engine. Maybe bump up to a W30?
Edit. I see you did (M1 0W30). Good move! thumbsup
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Pennzoil Platinum High Mileage 10W30
Re: 3.0L V6 Accord 2006. M1 5w20 6500miles. Driven Hard. [Re: Gasbuggy] #5457391 06/19/20 01:21 AM
G
Gasbuggy Offline OP
G
The iron numbers are higher. I saw a Blackstone result posted by another user and the average was iron 9 ppm. Aluminum was 3. Chromium 1.
I will be sticking with 30wt going forward.
I'll have to read about the oil pump seal
Re: 3.0L V6 Accord 2006. M1 5w20 6500miles. Driven Hard. [Re: Gasbuggy] #5457407 06/19/20 02:32 AM
Online Content
Best to just do it when you do the timing belt. It's not a repair that will leave you stranded if you don't do it. It will just seep oil from that area. Not enough that you'd notice it in your parking spot unless you sit there and idle for long periods.
https://www.bobistheoilguy.com/foru...-acura-j-series-timing-belt-and-oil-pump
Double-check it, but that list of parts should be identical for your J30A5 as it is for my J30A4.
Trans-Idemitsu H+
Re: 3.0L V6 Accord 2006. M1 5w20 6500miles. Driven Hard. [Re: Gasbuggy] #5457433 06/19/20 05:30 AM
demarpaint Offline
I'd stick with the 0W30, ESP 0W30.
God Bless Our Troops
Re: 3.0L V6 Accord 2006. M1 5w20 6500miles. Driven Hard. [Re: Gasbuggy] #5457444 06/19/20 06:09 AM
M
Matagonka Offline
M
Miss my V6 7th gen...
2018 Mazda 3 Touring HB 2.5
2020 Hyundai Palisade
Re: 3.0L V6 Accord 2006. M1 5w20 6500miles. Driven Hard. [Re: Gasbuggy] #5457541 06/19/20 08:46 AM
Schmoe Offline
My 06 V6 has had nothing but a diet of M1 EP 5W-30 since birth. Haven't ran any analysis on it, but it runs smooth as silk. Have done two timing belt changes....the first one, well, so called "mechanic" didn't change out anything else...sure enough, leaks started at about 150K. Currently have 165K on it and recently "gave" it to my 16 year old daughter to drive. I'm driving the V6 coupe. Maybe it's me, but the 06 seems to take off quicker than the 17. But the ride in the 17 is way more comfortable.
01 Supercrew Lariat 4X4
06 Accord EX-L V6
2018 CRV EX-L
2017 Accord Coupe V6 EX-L 6AT
Re: 3.0L V6 Accord 2006. M1 5w20 6500miles. Driven Hard. [Re: Gasbuggy] #5457801 06/19/20 03:15 PM
G
Gasbuggy Offline OP
G
Your 17 likely has torque management in the tune. the 06 doesn't seem too, and it has a hair-trigger on downshifts. it just wants to go, it's not fuel economy conscious at all.
Re: 3.0L V6 Accord 2006. M1 5w20 6500miles. Driven Hard. [Re: Gasbuggy] #5457921 06/19/20 05:39 PM
caprice_2nv Offline
Maybe that slightly high iron is just what you get when you run it hard a lot. Probably more concerning to see that number if it was babied. I'd sample again with the 30 weight and see if it makes any difference.
Silicon looks maybe slightly high but also could be just par for the course with an aftermarket filter.
This is really making me want to do my first couple UOA's. One on an old carbureted V8 that gets short tripped almost daily, occasionally driven very hard, and some longer trips, plus an old school crankcase breather and PCV system.
That and my work truck which idles a lot in dusty conditions.
84 Olds Cutlass - 350 Olds
83 Chevy Caprice - 305 Sbc
05 Silverado 1500 4wd - 4.8/4L60E
79 Honda CX500
Re: 3.0L V6 Accord 2006. M1 5w20 6500miles. Driven Hard. [Re: caprice_2nv] #5458382 06/20/20 09:58 AM
B
buster Offline
B
That could be the case. Single UOA's are unfortunately not the best for analyzing wear. A trend is needed.
2020 - Mazda CX-30 - Mobil 1 EP 0w20
2019 - Subaru Impreza - Dealer Oil
