Forums Migration
Please read this thread
High Flow Thermostats
by Nick1994 - 07/12/20 02:51 AM
Hy-per Lube ZDDP Supplement 6pk $13.00
by alchargo - 07/11/20 10:38 PM
97 Civic HX valve cover pics
by CARJ - 07/11/20 10:22 PM
Time to ditch Speedplays
by UG_Passat - 07/11/20 10:03 PM
Dale L Nuzum
by Dalenuzum - 07/11/20 10:02 PM
*BANG* (Garage Door Spring)
by ctechbob - 07/11/20 09:40 PM
TPMS Sensors
by 92saturnsl2 - 07/11/20 09:16 PM
Chevron Delo 400 XSP 5W-30 XSP
by Gene K - 07/11/20 08:48 PM
LED retrofit for recessed can lights
by Donald - 07/11/20 07:08 PM
PP HM 5W-20 $15 at Wally
by Jackson_Slugger - 07/11/20 07:03 PM
Defeated by roll pin
by bcossa2001 - 07/11/20 06:56 PM
Dexron VI in place of Mercon LV?
by BigLee - 07/11/20 06:50 PM
89 c4 oil
by dogememe - 07/11/20 06:17 PM
Noticed the Titanium info.
by Farnsworth - 07/11/20 06:16 PM
FebiBilstein Parts
by willbur - 07/11/20 06:03 PM
Life goes on
by 53' Stude - 07/11/20 06:02 PM
Lubegard in a GM transfer case?
by BlakeB - 07/11/20 05:21 PM
Is MSO2 Liquid Moly OK in DIG NA engines
by JimPghPA - 07/11/20 03:10 PM
Rider Magazine Question
by Smoky14 - 07/11/20 02:38 PM
cadillactech, ILoveOil111, quantalume, SUmeme22, DaveCaddell
71910 Registered Users
25 registered members (Ausfahrt, blufeb95, Danimal1q2w3, carviewsonic, celicaxx, 5 invisible), 575 guests, and 27 spiders.
Topics307,747
Posts5,316,936
Members71,910
CRV O2 #5457065 06/18/20 03:36 PM
supton Offline OP
So I had the CRV inspected yesterday, and while it passed they said it had a pending code, P0134. That comes up as low or no activity on upstream O2 sensor. After digging around I found an Android and my Elm327 adapter and "scanned" it. This time it came up as a fault but not under pending--yet the money light is off. Hrm.
I haven't used Torq in a few years but apparently the last time I did I turned on the O2 sensors so I was able to (poorly) overlay them. I would have guessed 1x1 was first sensor and 1x2 was second? That seems wrong. I would have expected wide swing on the first (unless if it was lazy--which fits the code)--or if the second was wide swing then that would say I have a dead cat. Am I just reading this wrong? Trying to diagnose this a bit better before I just toss an O2 sensor at it.
[Linked Image]
2011 Toyota Camry, base, 2.5L/6MT, 206k
2010 Toyota Tundra DC, 4.6L/6AT, 160k
2003 CRV, 2.4L/4AT, 161k
1999 Toyota Camry LE, 2.2L/4AT, 225k
Re: CRV O2 [Re: supton] #5457082 06/18/20 03:50 PM
J
JimPghPA Offline
J
I plan on changing the upstream O2 sensor every 60 K miles on my 2016 CR-V to protect the cat. I know they ain't cheap at around $360, but the cat probably cost a heck of a lot more. And I am not 100 % sure, but I think if the O2 sensor goes bad there is also the possibility of it causing the engine to run lean enough to cause engine damage.
OP, is it still the original sensor at 161 K?
Boy will I be happy when ALL vehicles on public roads are autonomous.
JimPghPa
Re: CRV O2 [Re: supton] #5457094 06/18/20 04:06 PM
supton Offline OP
I did not see it show up in the service records so I would assume that it is original at 161k. I don't know if Torq can log fast enough to show if it is lazy or not?
I saw a Denso on Amazon for like $125, haven't started shopping yet, but I'm guessing that is about as good as the price gets. I would ASSUME Denso is fine for this application too.
Vehicle lived in the 'burbs and saw lots of short tripping IMO. Lots of trips just long enough to get heat out of the heater core.
Re: CRV O2 [Re: supton] #5457107 06/18/20 04:23 PM
J
JimPghPA Offline
J
You better do some research about counterfeit auto parts. Sometimes if a price sounds too good to be true it just may be. There have been some post here on BITOG about counterfeit auto parts and some of the places that they are sold are the online outlets like e-bay and Amazon. With the possible damage a bad O2 sensor can cause you want to be sure you are buying one that is reliable.
Maybe some other people here on BITOG can add more knowledge about what would be the lowest cost brand and source for an O2 sensor for a 2003 CRV with a 2.4 L engine, and still be good quality?
JimPghPa
Re: CRV O2 [Re: supton] #5457111 06/18/20 04:31 PM
supton Offline OP
Quick look shows that $125 or so is going rate at Ebay and Amazon for Denso 234-9005. Ironically it's $45 at AAP or AZ! I haven't gotten far enough to see what the OEM part is nor the OEM price.
Re: CRV O2 [Re: JimPghPA] #5457126 06/18/20 05:01 PM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
Why is that O2 sensor $360?!? Seems way out of line. Is there some special attribute?
Re: CRV O2 [Re: supton] #5457172 06/18/20 06:09 PM
J
JimPghPA Offline
J
I looked at the price about 2 weeks ago on a Honda genuine parts web site, and if I remember correctly a couple of others were a little less, but not much. I guess I will have to look some more.
BTW, there are some YouTube videos on how to change it. Along with a special 6 point socket that has a slot for the pigtail, one trick is to put penetrating oil on it the day before, and then right before you change it run the engine for only one minute. The person who made that video said the relatively thin exhaust heats up much faster than the thicker housing of the O2 sensor, therefore the hole the O2 sensor is installed in expands more than the sensor making it easier to remove the sensor.
They said they had 4 of them to do and one would not come loose, so they tried the penetrating oil the day before and then the one minute run and the tough one came loose.
JimPghPa
Re: CRV O2 [Re: supton] #5457185 06/18/20 06:28 PM
J
JimPghPA Offline
J
I just looked on some of the online Honda parts stores and there prices range form $160.93 to $179.61
I do not remember where I saw $360, maybe that was on one of the Honda forums, and included having a dealer do it. I do not remember for sure, but I do remember I saw it and a few price near that amount, but again that could have been on a Honda forum, and could have included having a dealer do it.
I guess I remembered incorrectly where I had seen it a couple of weeks ago.
JimPghPa
Re: CRV O2 [Re: supton] #5457228 06/18/20 07:36 PM
W
WyrTwister Offline
W
https://www.rockauto.com/en/catalog/honda,2003,cr-v,2.4l+l4,1415719,exhaust+&+emission,oxygen+(o2)+sensor,5132
Wyr
God bless
Re: CRV O2 [Re: WyrTwister] #5457237 06/18/20 07:49 PM
supton Offline OP
Wow do they have prices all over the place!
Re: CRV O2 [Re: supton] #5457409 06/19/20 03:15 AM
ctechbob Offline
Generally, the upstream sensors are much more expensive as they're a heated 5 wire wideband A/F sensor as opposed to a narrowband sensor like downstream ones are. So about $100 ea give or take.
I've been putting off doing mine since I've got 2-Upstream and 2-Downstream on both cars...
2008 Acura TL Type S-170k
2003 Honda Accord V6-222k
Oil-Havoline HM 5W30
Filter-Partsmaster 61334
Trans-Idemitsu H+
Re: CRV O2 [Re: ctechbob] #5457461 06/19/20 06:50 AM
spasm3 Offline
I change the upstream ones at about the 80k or so mark, but i've never replaced downstream sensors.
13 elantra 84k 5w30 synpwr
17 mazda cx-5 19000 miles m1 0w30
Re: CRV O2 [Re: supton] #5457480 06/19/20 07:16 AM
supton Offline OP
I replace as they fail. I get the premise of replacing before they fail and take out a cat, but so far... shrug We do log every fillup in the cars and would notice an mpg drop very quickly--pre-pandemic we would routinely fillup once a week and a drop in range would annoy us.
Re: CRV O2 [Re: supton] #5457521 06/19/20 08:26 AM
A
ARCOgraphite Offline
A
I dont know how to interpret the new, and now common proportional wideband O2 sensors.
I assume this engine has a traditional (garbage ) step function lambda sensor.
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#9 70254mi-Rotella
Gas Truck 5W20 + Fram Ultra 7317 Filter
