Forums Migration
Please read this thread
Time to Dump or Repair?
by GMFan - 07/09/20 12:46 PM
TIREREVIEW : Videos
by odie - 07/09/20 12:39 PM
HYUNDAI ; Manual tranny w/o a clutch pedal
by odie - 07/09/20 12:30 PM
Need Pressure Washer Recommendations
by qdeezie - 07/09/20 12:28 PM
1992 Chevy 1500 Truck
by HowAboutThis - 07/09/20 12:01 PM
Window Tint
by The Critic - 07/09/20 11:59 AM
12 month Interval on oil ?
by jdw1222 - 07/09/20 11:06 AM
Toyota Caliper Pin Question
by Gebo - 07/09/20 11:02 AM
Iphone text being used for ads
by stockrex - 07/09/20 10:14 AM
Price shock with used cars
by dlundblad - 07/09/20 09:47 AM
anyone noticed worse acceleration with fram ultra?
by cals400ex - 07/09/20 08:39 AM
Good article on battery recycling
by Fattylocks - 07/09/20 07:19 AM
Civic rear wheel bearing
by toad - 07/09/20 07:06 AM
Nokian Entyre C/S
by Robster - 07/09/20 06:00 AM
Corolla Cross
by wemay - 07/09/20 05:51 AM
Pennzoil strikes again with PDS (Euro 5W40)
by edyvw - 07/09/20 01:44 AM
Extra Load tires - Firmer ride?
by Spetz - 07/09/20 12:34 AM
make sure to use a software firewall
by 2004tdigls - 07/08/20 11:02 PM
kuldeep, BillDros, peterboyce, 99Burbans, EmanInOz
71897 Registered Users
123 registered members (77Se7en, 1911CHAMPION, Alex38, 2010Civic, Ag76, 4WD, 8 invisible), 1,951 guests, and 43 spiders.
Topics307,645
Posts5,314,876
Members71,897
Page 1 of 3 1 2 3
Fram XG10575 Good Replacement for AC Delco PF63? #5456747 06/18/20 09:44 AM
V
viscous Offline OP
V
Fram PH10575 originally had a 9-15 PSI black bypass poppet. GM owners requiring AC Delco PF48 sometimes chose PH10575 as a longer version of PH10060, the "official" PF48 replacement. Fram then redesigned the PH10575 with a 16-28 PSI white bypass poppet so it could replace AC Delco PF63, which has 22 PSI bypass. They instructed PH10575 users to move to the shorter PH10060.
Does the wide bypass range of the redesigned PH10575 seem suspicious? Did Fram redesign this filter properly so that it actually matches the 22 PSI specification of AC Delco PF63? Would anyone have reservations about installing a Fram XG10575 (Ultra Synthetic) in an application calling for AC Delco PF63?
Re: Fram XG10575 Good Replacement for AC Delco PF63? [Re: viscous] #5456760 06/18/20 10:01 AM
R
ryster Online Content
Online Content
R
The original PF63 has a 12psi specification. The redesigned PF63E is 22psi. The PF63E and the XG10575 are basically the same price and both easy to find. I would use the ACDelco PF63E just to know that I am using the recommended filter and there is no question on compatibility. FRAM doesn't list the psi spec of the XG10575 on their website, which is kind of concerning since most other mainstream aftermarket parts companies typically do.
2015 Chevrolet Equinox LT AWD
3.6L V6
Re: Fram XG10575 Good Replacement for AC Delco PF63? [Re: ryster] #5456769 06/18/20 10:08 AM
V
viscous Offline OP
V
Yes, I'm leaning that way also, but aside from the bypass ambiguity, doesn't the XG10575 offer superior construction?
Yes, I also found that very concerning. Do you believe Wix WL10255 is superior to PF63E?
Re: Fram XG10575 Good Replacement for AC Delco PF63? [Re: viscous] #5456810 06/18/20 10:39 AM
R
Online Content
R
The XG10575 might be better constructed, but I have serious doubts the bypass is rated at 22psi. A Google search indicates that the last time that FRAM listed the bypass psi, they indicated 16psi so it may be slightly lower than the 22psi recommended by GM for the PF63E applications.
The Wix WL10255 is rated for 22psi, so it meets that spec. Wix filters are typically well built and I would use one in my Chevy if I couldn't find an ACDelco PF63E.
The ACDelco is perfectly fine if you are following a 5,000-7,500 mile interval.
If you are following a 10,000-15,000 mile extended interval, then it probably would be better to use something other than the ACDelco. I wouldn't trust the ACDelco for that kind of interval. The Wix WL10255XP meets the 22psi spec and has synthetic media. The Mobil1 M1-212A would be another good choice if running an extended interval, and it has a bypass pressure that exceeds the 22psi spec that GM calls for.
3.6L V6
Re: Fram XG10575 Good Replacement for AC Delco PF63? [Re: ryster] #5456822 06/18/20 10:50 AM
V
viscous Offline OP
V
Yes, the OCI will not exceed the miles you mentioned, but it will exceed the time duration over which a typical driver would drive those miles. Any problems leaving an AC Delco installed a long time on an infrequently driven vehicle?
So you don't think Wix offers a better value than AC Delco?
I've seen concerns about reported low efficiency of Wix XP filters. Do you feel Wix XP or M1 offers a better value than AC Delco?
Re: Fram XG10575 Good Replacement for AC Delco PF63? [Re: viscous] #5456849 06/18/20 11:16 AM
H
haggler Offline
H
The Fram PH/XG 12060 is the Correct bypass replacement for PH10060. I would just use the spec filter that is shorter with the correct bypass. I picked up ACDelco pf64 at walmart for my next OCI since there was a $1.50 rebate. Standard Champion e-core construction. I could not find the Fram Ultra at my local walmart, only the extra guard. Extra guard is still probably better.
2019 MX-5 Soft Top Miata - Soul Red Crystal - M1 EP 0w20 - M1 EP 108a Filter
2020 Chevrolet Equinox - Factory Fill/Filter
Re: Fram XG10575 Good Replacement for AC Delco PF63? [Re: haggler] #5456873 06/18/20 11:34 AM
V
viscous Offline OP
V
Thanks, I was not aware of the current rebate offer.
Better than what?
Re: Fram XG10575 Good Replacement for AC Delco PF63? [Re: viscous] #5456896 06/18/20 11:58 AM
H
haggler Offline
H
ACDelco.
Re: Fram XG10575 Good Replacement for AC Delco PF63? [Re: viscous] #5456918 06/18/20 12:23 PM
Z
ZeeOSix Offline
Z
If Fram specifies their filter for your vehicle then what's the worry. A filter bypass valve setting doesn't have to be a perfect match between filter brands because the setting depends a lot on the filter designed flow vs delta-p characteristics. If a filter is more flow restrictive then it will require a higher bypass valve setting.
Re: Fram XG10575 Good Replacement for AC Delco PF63? [Re: ryster] #5456930 06/18/20 12:32 PM
Z
ZeeOSix Offline
Z
I just looked at the XG10575 on Fram's website, and it says 16-28 psi just as the OP mentions in his first post.
22 psi is right in the middle of the 16-28 psi range. Every bypass valve has a cracking pressure and a fully opened pressure. Could be that AC Delco just reports the mid-point psi only.
Re: Fram XG10575 Good Replacement for AC Delco PF63? [Re: viscous] #5456970 06/18/20 01:22 PM
R
Online Content
R
For me, value is a balance of price and function. If I can pay $7 for the OEM part as opposed to $5-$7 for an after market equivalent, I am going OEM since I know it was specified for the car by the manufacturer. Now, if the OEM part was $14, and the aftermarket part was $7 then I would go with the aftermarket part provided it had similar specs to the OEM part. If there was any question at all, I would just buy the OEM part for peace of mind.
I don't think time is a consideration. If the ACDelco is used for 5,000-7,000 miles across 4 months, or 12 months, it doesn't make a difference. Any degradation (if any at all) that occurs from just sitting idle would be minimal.
For a long interval such as 10,000-15,000 miles the Wix XP or M1 would be a better value than the ACDelco (about $5 more for a filter that will be on the car longer), since the Wix XP and M1 are designed for longer intervals. From an efficiency perspective, the Wix XP has the same efficiency rating as the M1 and the ACDelco (30 microns). FRAM claims efficiency based on 20 microns, which might be better, but if you are changing the oil every 5,000-7,000 miles does it make that much of a difference? If GM is using a filter with a 30 micron efficiency that should be sufficient.
3.6L V6
Re: Fram XG10575 Good Replacement for AC Delco PF63? [Re: viscous] #5457153 06/18/20 05:47 PM
4WD Online Confused
Online Confused
PF63E with 6k off 5.3L
Re: Fram XG10575 Good Replacement for AC Delco PF63? [Re: viscous] #5457173 06/18/20 06:09 PM
CT8 Offline
Most likely the the difference in the oil filters will never ever be noticed. Yeah there is a marketing paper about the better filter catching more and smaller crud . I doubt we will ever see the difference in real life.
2015 F150 2.7
2018 F350 6.2
Re: Fram XG10575 Good Replacement for AC Delco PF63? [Re: viscous] #5457175 06/18/20 06:11 PM
CT8 Offline
The only thing to worry about an oil filter is if it fails. and causes catastrophic damage.
2015 F150 2.7
2018 F350 6.2
Re: Fram XG10575 Good Replacement for AC Delco PF63? [Re: ryster] #5457351 06/18/20 11:17 PM
V
viscous Offline OP
V
Some have expressed concern about the XP filtering efficiency:
Originally Posted by oil_film_movies
You don't need the "XP" version, since it doesn't filter very well. Low efficiency rating....[PF64 has] got a paper filter media, not the better glass fiber & paper blend like the Wix and Fram Racing HP18 has. Very doubtful the PF64 filters better with that design.
Originally Posted by ZeeOSix
As discussed many times now, the XP/Platinum full synthetic filter has a pretty bad filtering efficiency ... only 50% @ 20 microns, while the WIX/NAPA Gold is much better at 95% @ 20 microns. If you want a good full synthetic media filter for a decent price, go with the FRAM Ultra, as it's efficiency is 99% @ 20 microns and rated to go 15,000 miles.
Page 1 of 3 1 2 3
