Forums Migration
Please read this thread
I found a WWII movie for yinz to watch.
by JimPghPA - 07/12/20 04:45 PM
Jackpoint Jackstand Review
by RamFan - 07/12/20 03:03 PM
Lesabre Brake fluid capacity
by Ihatetochangeoil - 07/12/20 02:56 PM
Baking Cookies in the Car - 2.0
by Nick1994 - 07/12/20 02:17 PM
Dealer ruined my transmission!!!!
by John344 - 07/12/20 02:04 PM
Wax / Sealer Recommendations
by 92saturnsl2 - 07/12/20 01:45 PM
Horrible Duramax Aftermarket Filter Mod
by ToadU - 07/12/20 01:29 PM
Japan unveils timeline for indigenous fighter jet program
by gathermewool - 07/12/20 12:27 PM
NEW Rotella T6 15w40
by ToadU - 07/12/20 11:54 AM
2001 Silverado 1500 4x4 Alignment Concerns
by Blang - 07/12/20 11:37 AM
Full Synthetic for ATS V
by cadillactech - 07/12/20 11:33 AM
Gasoline engine oil in a diesel engine?
by LeslieX - 07/12/20 11:32 AM
Can I use IPA 70% to clean windshield?
by painfx - 07/12/20 09:47 AM
The Heat is on
by Snagglefoot - 07/12/20 07:39 AM
Working on your car
by CourierDriver - 07/12/20 07:35 AM
My last two cars were direct injection
by Railrust - 07/12/20 06:52 AM
High Flow Thermostats
by Nick1994 - 07/12/20 02:51 AM
Hy-per Lube ZDDP Supplement 6pk $13.00
by alchargo - 07/11/20 10:38 PM
Slick122, Ford4life76, Patrick_Hall1988, Ron1948, cadillactech
71914 Registered Users
84 registered members (2004tdigls, 2010Civic, Aichiguy, 53' Stude, 87sammy, AJB0009, 9 invisible), 2,137 guests, and 46 spiders.
Topics307,766
Posts5,317,416
Members71,914
Need advice on a accurate, programmable thermostat #5456744 06/18/20 09:43 AM
sasilverbullet Offline OP
I'm looking for one that if it's set at 77, then at 78 it will turn the A/C on, and when it's 77 again turn it off.
The one I have now doesn't turn on until the temp is 2 degrees higher. Then it runs the A/C for what seems like forever.
Here's one I had at my last house and it seemed accurate. Do you guys concur getting this will solve my problems?
[img]https://www.homedepot.com/p/Honeywe...ogrammable-Thermostat-RTH8500D/100295793[/img]
03 Porsche 911 Driven DT-40 5w-40 & Mahle filter
14 Honda Accord 4dr EX-L 4cyl-M1 5W-30 & WIX
02 Chevy 5.7L van-GTX HM 10W-40 & WIX
Re: Need advice on a accurate, programmable thermostat [Re: sasilverbullet] #5456779 06/18/20 10:17 AM
shanneba Offline
I have a Lux TX100e. It has the ability to set the "temperature swing" from +- 0.25 default) up to +- 2.25 degrees.
Maybe your current thermostat can also be adjusted?
I have it set for a +- 1.0 degree swing, the heat comes on at the set point -1 degree, goes off at set point +1
the A/C comes on at the set point +1 degree, goes off at set point -1
https://www.homedepot.com/p/Lux-7-Day-Manual-or-Programmable-Thermostat-TX100E-006/206605731
2003 BMW 330Ci
2013 HD Sportster XL1200C
Re: Need advice on a accurate, programmable thermostat [Re: sasilverbullet] #5456785 06/18/20 10:23 AM
P
PowerSurge Offline
P
Your current thermostat may have an adjustable swing setting. Meaning you can adjust how close to the set temperature the system will come on. If not, the Honeywell you linked is a great stat. That model is very high quality that will last for years. LUX brand thermostats are a cheaper alternative but are also well built. This one does not have a touchscreen, though:
https://www.amazon.com/Lux-Thermostat-selectable-universal-compatability/dp/B00F19KW0S/ref=sr_1_7?crid=1WDZPOTP9JYD3&dchild=1&keywords=lux+digital+thermostat&qid=1592493714&sprefix=Lux+dig%2Caps%2C160&sr=8-7
1993 Porsche 964, 2001 Ford SVT F-150 Lightning, 2004 Chevrolet Corvette, 2018 Toyota Tundra 5.7L
Re: Need advice on a accurate, programmable thermostat [Re: sasilverbullet] #5456788 06/18/20 10:25 AM
H
Hall Offline
H
I thought most thermostats operated similarly and one reason is to avoid having the AC (or furnace) cycling on and off too frequently.
On the unit you linked to, I see nothing that indicates it will operate like you want (I looked at the operating manual too). If your AC "runs forever" to drop 2º, I think your AC is more to blame (too small) than the thermostat.
Re: Need advice on a accurate, programmable thermostat [Re: sasilverbullet] #5456855 06/18/20 11:22 AM
Donald Offline
I think a 2 F degree swing is reasonable. You do not want your HVAC cycling all the time, it will shorten the life.
2015 Ford F-250 w/Powerstroke
Re: Need advice on a accurate, programmable thermostat [Re: sasilverbullet] #5456889 06/18/20 11:52 AM
R
Rand Offline
R
you would hate my window AC then it has 4 degree swing..
2degrees is pretty much industry standard.
Re: Need advice on a accurate, programmable thermostat [Re: sasilverbullet] #5456910 06/18/20 12:16 PM
dinofish Offline
Our Honeywell does what you want it to do, but ours is a bit older than the one you have linked. And no, it doesn't cycle all the time with this type of setting. But then again, I turn the A/C off during the day, and only turn it on at 6pm when everyone is back in the house.
Re: Need advice on a accurate, programmable thermostat [Re: dinofish] #5456916 06/18/20 12:22 PM
T
terry274 Offline
T
The OP is in Texas, turning the AC off is probably not gonna happen.
2011 Toyota Avalon
2019 Honda Ridgeline
2009 Ford Taurus
2012 Honda Accord
1996 Ford F150
Re: Need advice on a accurate, programmable thermostat [Re: sasilverbullet] #5456943 06/18/20 12:45 PM
K
Kawiguy454 Offline
K
That hysteresis/differential of 2 degrees is what you want. The AC should not be cycling on and off constantly. Keep in mind that a properly sized AC unit is SUPPOSED to stay on a lot. One of its main jobs is to remove humidity making it comfortable. An oversized AC unit with small differential temp will not get rid of very much humidity while adding wear to the ac unit.
Re: Need advice on a accurate, programmable thermostat [Re: terry274] #5456954 06/18/20 12:59 PM
+1 Cheers2
Re: Need advice on a accurate, programmable thermostat [Re: sasilverbullet] #5456984 06/18/20 01:46 PM
dinofish Offline
+1 Cheers2
If you are not turning it off during the day, I would keep it at the two degree setting. I agree with others that continuous turning on and off is probably bad. Maybe you can try setting it at a lower temperature like 75 degrees?
Re: Need advice on a accurate, programmable thermostat [Re: sasilverbullet] #5456998 06/18/20 02:06 PM
Pablo Offline
I thought a Nest would help in a similar situation. "Oh it will learn" people said. That thing has no more intelligence than a post. A simple thermostat would be better, IMHO.
DIRECT JOBBER - PABLO - for all your Amsoil needs
http://oilslubesandfilters.shopamsoil.com/
Re: Need advice on a accurate, programmable thermostat [Re: Pablo] #5457033 06/18/20 02:55 PM
Skippy722 Offline
Agreed. Our new house came with a Nest. Disabled the “auto learn” feature. Otherwise it’s great. If we leave I just turn on eco or crank the temperature up or down respectively, and turn it back to where I want it when we are leaving to go back home.
2019 Ram 1500 Classic
2018 Dodge Grand Caravan GT
Slight Mopar obsession
Re: Need advice on a accurate, programmable thermostat [Re: sasilverbullet] #5457057 06/18/20 03:27 PM
CDX825 Offline
Get a Pro 1 T 705 stat. They are reasonably priced and you can adjust the swing setting.
1984 Ford F250 6.9 Diesel C6 2WD Rotella T 15W40 NTZ Bypass Filter
1992 Mazda B2600 4x4 Amsoil Series 3000 5W30
1998 Ford Ranger 4x4 Pennzoil Platinum 5W30
Re: Need advice on a accurate, programmable thermostat [Re: sasilverbullet] #5457373 06/19/20 12:25 AM
Nick1994 Online Content
Online Content
I've got a Braeburn 2000NC that I put in in 2016, probably a newer version out by now. It lets you set the temperature differential at 0.5, 1, and 2 degrees. I keep it at 1.
Amazon Link
2015 Hyundai Genesis 5.0L 63k Dealer Bulk SynBlend 5w20 & OEM
2000 Toyota Camry 2.2L 239k Mobil Delvac 15w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 150k Rotella Gas Truck 5w30 & Wix
