FJC Foaming Evaporator Cleaner Review
by Reddy45 - 07/04/20 12:10 AM
Ford 351W oil filter best value
by alex16 - 07/03/20 11:12 PM
Super tech euro 5w40 - Canada
by Johan1 - 07/03/20 10:19 PM
Strangers show up for vet's funeral.
by simple_gifts - 07/03/20 09:44 PM
Troybilt tb22ec refuses to run correctly
by Dogred08 - 07/03/20 09:43 PM
Harbor Freight Nitrile gloves
by 1978elcamino - 07/03/20 09:04 PM
Did anyone get a 25% coupon for July 4th?
by 1978elcamino - 07/03/20 08:58 PM
05 4.6 Northstar crank sensor re learn?
by cknight49090 - 07/03/20 08:40 PM
In the year 2049...
by eljefino - 07/03/20 08:05 PM
2-year old oil 124 Spider
by DAC17 - 07/03/20 07:57 PM
New to us van
by ram_man - 07/03/20 07:22 PM
original '05 Chrysler trans pan gasket material ?
by visitor - 07/03/20 06:16 PM
rock auto can't ship to Calif????
by 928 - 07/03/20 06:04 PM
2001 Silverado 1500 T-Case Fluid
by Blang - 07/03/20 05:53 PM
Nasty Car wreck
by ford46guy - 07/03/20 05:53 PM
Best style of condenser?
by ddeflyer - 07/03/20 05:17 PM
Advance Auto now selling Die Hard Batteries
by Kira - 07/03/20 05:01 PM
Ontario Nuclear update - Part 2
by OVERKILL - 07/03/20 04:36 PM
Is this totaled?
by NoNameJoe - 07/03/20 04:23 PM
Johan1, MrMoneyMcLube, JeffAR, ThaKid22, Speedeuphoria
71843 Registered Users
40 registered members (blufeb95, carlprop, 2009Caraman, 2strokeNorthstar, aquariuscsm, alcyon, 1 invisible), 983 guests, and 22 spiders.
Topics307,396
Posts5,310,313
Members71,843
Deck spray #5456715 06/18/20 09:09 AM
B
buck91 Offline OP
B
So I hate to open a can of worms but lets throw it out there. Has anybody found a under deck spray which actually works? I don't mind applying more than once a year but it would be pointless to require use before each cut. My priority would be combining both decreased build up and hopefully corrosion protection. FWIW this is a 1/4 acre residential application.
2018 F150 Screw 4x4 2.7L Ecoboost
2011 F150 Scab 4x4 5.0L
1996 Mustang GT 5spd/ragtop
Re: Deck spray [Re: buck91] #5456741 06/18/20 09:42 AM
Donald Offline
Cut in dry grass is the largest thing you can do.
2015 Ford F-250 w/Powerstroke
Re: Deck spray [Re: buck91] #5456756 06/18/20 09:55 AM
spasm3 Online Happy
Online Happy
I've tried a lot, and nothing that's worth the time. I've tried bed liner coatings, epoxy paints, even graphite ez slide coatings. Nothing holds up to the abusive conditions under the deck.
13 elantra 84k 5w30 synpwr
17 mazda cx-5 19000 miles m1 0w30
Re: Deck spray [Re: buck91] #5456758 06/18/20 09:59 AM
SatinSilver Offline
I wonder if some Wet and Forget would work well under there. Just an idea. Seems to work on so many things for a once a year application.
Re: Deck spray [Re: Donald] #5456847 06/18/20 11:15 AM
B
buck91 Offline OP
B
Definitely. Unfortunately for some reason during the later spring when the grass needs cut almost every 3 days the yard rarely has time to dry fully. I do follow up almost all cuttings with a hose to the underside until the water runs pretty clear but this doesn't really seem to do much.
Re: Deck spray [Re: buck91] #5456853 06/18/20 11:20 AM
K
Kestas Offline
Global Moderator
Global Moderator
K
I'm on my 5th year with a mower I bought new. I religiously rinse it after each mowing. It still has corrosion developing under deck.
Re: Deck spray [Re: buck91] #5457014 06/18/20 02:29 PM
N
Normac Offline
N
Pressure Washer when done mowing. Quick, easy, and works every time.
Actually I enjoy mowing in fall the most, as dry fallen leaves clean the mower deck out for you.
Re: Deck spray [Re: buck91] #5457055 06/18/20 03:26 PM
W
walterjay Offline
W
I super cleaned my deck and applied a graphite anti stick paint. I really made no difference. Cut dry for best results.
Re: Deck spray [Re: buck91] #5457075 06/18/20 03:43 PM
L
Lubener Offline
L
The best lazy man's deck cleaning method is to run the mower through a pile of leaves. Those leave scrub the underside down to the metal. Unfortunately, that is a fall activity.
The "thinking" man's friend.
Re: Deck spray [Re: buck91] #5457108 06/18/20 04:26 PM
T
tundraotto Offline
T
fools errand IMHO.....you can spray it with pam cooking spray so nothing sticks....but is that really feasible?
get a deck thick and well built enough that it wont rust through is the most logical solution I can think of. (think fabricated deck, or one of those super thick JD pressed decks)
Re: Deck spray [Re: buck91] #5457110 06/18/20 04:28 PM
O
OilReport99 Offline
O
I rinse after each mowing. It will rust at some point, though.
2018 Ram 1500 - VME 5W-20
Re: Deck spray [Re: buck91] #5457112 06/18/20 04:31 PM
Duffyjr Offline
Even dry grass is 80% water if you have a decent lawn. As others have said the best thing to do is hose it down after every mow so no moisture gets trapped under the stuck on grass.
89 GMC Sierra Advanced 5w30/TG
08 Lucerne CX Advanced 5w30/TG
18 Toro Super Recycler T5 10w30
Re: Deck spray [Re: Lubener] #5457209 06/18/20 06:55 PM
spasm3 Online Happy
Online Happy
That and mowing over a bunch of sweet gum tree balls.
Re: Deck spray [Re: spasm3] #5457419 06/19/20 04:06 AM
L
Lubener Offline
L
I cut down my sweet gum, got tired of those spiked tree balls.
Re: Deck spray [Re: Lubener] #5457558 06/19/20 09:03 AM
N
Normac Offline
N
Mine got cut down right after a gum ball sailed out of the mower's discharge chute and put a hole in my vinyl siding.
