There's just no way to tell. You could do all the things they say to extend trans life and a hard part failure will still get ya.
The number one failure I see in the 4Lsplipping-E j/k) is related to the coverter. GM had a real bad problem in the 97's with a check valve in the valve body not seating properly and allowing the converter to have a couple-hundred RPM slip speed. Needless to say this allows heat build up and wears out the converter clutch pretty quickly which results in metal contamination of the fluid. It's not quite as common as it once was but still pretty **** prevalent. Of course by the time the PCM recognizes the issue and illuminates the CE light and goes to default internal pressures (and the resulting harsh shift) the damage is likely already done.
Next most common is the reaction shell. This is a stamped metal shell that connects to the input (forward) sun gear. Used to be the flange that the sun gear splines were in would just break right off. GM updated the part and now the splines themselves strip off.
Then the input planet sun gear roller thrust bearings fail pretty frequently. This one usually isn't noticed until the trans starts whining badly on acceleration. It takes out the forward planet set, pump, converter, valve body... well pretty much you'll need another trans.
The input bearing is another roller bearing thats just behind the front pump. Pull the pump and look on the input drum at the base of the input shaft and there it is. Or at least usually
This one isn't too bad on hard part damage but with the cost of SRTA's (Service Replacement Transmission Assembly) so low any hard part damage is enough to total a 4L60.
The new one I'm seeing is a failure of the roller bearing racee on the rear planet carrier to ring gear hub. In the last couple of months I've seen a few where a section of the race is missing. The edges of the missing area are jagged and sharp. Think of a donut with between 1/3 and 1/2 of it missing. The rollers are still there and the cage is intact. ow this may be the same type of failure that takes out the input and input planet bearings but by the time I see those everything is destroyed.
FWIW, the Ford truck trannies fail but in no discernable pattern beyond converter failures, and the same thing with the Mopar trucks. I see the Mopar next-most-often to the GM's.
Basically, do what makes you feel good and just drive it. If it blows up don't be overly surprised, if it doesn't then well and good.
