Code
Hours    .   Hrs       Hrs
on unit    on unit  on unit
 24.9           58       66
hours       hours      Hours
on oil       on oil    on oil
24.9          34           8
Fe           27      21    6
Cr            1       0    0
Ni            0       0    0
Al            9       5    3
Cu            3       1    0
Pb            0       0    0
Sn            0       0    0
Cd            0       0    0
Ag            0       0    0
V             0       0    0
Si            9       5    2
Na           18       5    6
K             0       3    0
Ti           27     103  106
Mo           41       2    1
Sb            0       0    0
Mn            0       0    0
Li            1       0    0
B             6      75   94
Mg          861     327  305
Ca         1228    1816 1904
Ba            4       0    0
P          1019    1000 1086
Zn         1170    1146 1182
Fuel dil    2.2     3.3  2.1
Soot        <.1     <.1  <.1
Water       <.1     <.1  <.1
Vis 100 C  12.5    12.3 13.3
As noted, the oil only has 8 hours on it but it has been one year since the last change. Given the low capacity (1.6 qts) and the lack of a filter I didn't want to stretch things out. Hopefully it will get more use this year.
The answer to 80% of BITOG questions: Read the book, follow directions.
Changing oil is not maintenance. Maintenance is the science of inspecting equipment to find and fix things before they break.
