Forums Migration
Please read this thread
Any 47RH Transmission Experts? CTD Ram
by JHZR2 - 07/12/20 04:58 PM
WM Magna1 10w30 gallon $5
by 2strokeNorthstar - 07/12/20 04:55 PM
I found a WWII movie for yinz to watch.
by JimPghPA - 07/12/20 04:45 PM
Jackpoint Jackstand Review
by RamFan - 07/12/20 03:03 PM
Lesabre Brake fluid capacity
by Ihatetochangeoil - 07/12/20 02:56 PM
Baking Cookies in the Car - 2.0
by Nick1994 - 07/12/20 02:17 PM
Dealer ruined my transmission!!!!
by John344 - 07/12/20 02:04 PM
Wax / Sealer Recommendations
by 92saturnsl2 - 07/12/20 01:45 PM
Horrible Duramax Aftermarket Filter Mod
by ToadU - 07/12/20 01:29 PM
Japan unveils timeline for indigenous fighter jet program
by gathermewool - 07/12/20 12:27 PM
NEW Rotella T6 15w40
by ToadU - 07/12/20 11:54 AM
2001 Silverado 1500 4x4 Alignment Concerns
by Blang - 07/12/20 11:37 AM
Full Synthetic for ATS V
by cadillactech - 07/12/20 11:33 AM
Gasoline engine oil in a diesel engine?
by LeslieX - 07/12/20 11:32 AM
Can I use IPA 70% to clean windshield?
by painfx - 07/12/20 09:47 AM
The Heat is on
by Snagglefoot - 07/12/20 07:39 AM
Working on your car
by CourierDriver - 07/12/20 07:35 AM
My last two cars were direct injection
by Railrust - 07/12/20 06:52 AM
Slick122, Ford4life76, Patrick_Hall1988, Ron1948, cadillactech
71914 Registered Users
91 registered members (A_Spruce, Averroes, Audios, 2strokeNorthstar, 2004tdigls, 2010Civic, 8 invisible), 2,022 guests, and 29 spiders.
Topics307,767
Posts5,317,423
Members71,914
2006 TSX Rad flush - has non-Honda fluid #5456450 06/17/20 10:23 PM
J
JeffKeryk Offline OP
J
When the water pump was replaced a few years ago, green radiator fluid was used.
Some cheap idiot used the green stuff. Don't ask me how I know.
I wanna do a flush and use Honda fluid. The radiator drain will get most of the fluid, but some will remain in the block.
Should I fill with distilled water, get it hot and drain a 2nd time?
Remember, in sunny CA a little over diluted fluid is not an issue.
Or no big deal, just add the Honda fluid and go.
Thanks for your guidance.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: 2006 TSX Rad flush - has non-Honda fluid [Re: JeffKeryk] #5456457 06/17/20 10:33 PM
E
E150GT Offline
E
If it were me id flush a few times with distilled water. Maybe even remove the thermostat to do the flush and replace with a new OE thermostat after.
Since I'm pretty anal about the coolant I wouldnt buy 50/50. You can get Toyota red concentrate or pentofrost concentrate to make the correct mixture.
1984 Mercedes-Benz 300SD - 100k
1995 F150 XL 4.9 reg cab 5MT - 253k 5w30
2016 Mazda6 Touring 6MT - 81k 5w30
2006 Buick Lucerne CXL 3.8 50k 5w30
Re: 2006 TSX Rad flush - has non-Honda fluid [Re: JeffKeryk] #5456483 06/17/20 11:27 PM
N
NoNameJoe Offline
N
Are you sure it's cheap green stuff? Honda Type 2 used to be a dark green that can look deceptively bright green in the sun. If it looks like gatorade it's probably the cheap stuff, any darker than that is probably Type 2.
If your mission is to get it all out the closest you can probably do is what E150GT said. Also look to see if your engine has a block drain, Honda puts them on their other engines so I don't see why it wouldn't, that would put the kibosh on your problem quickly.
2015 Civic LX Coupe
Re: 2006 TSX Rad flush - has non-Honda fluid [Re: E150GT] #5456571 06/18/20 06:13 AM
DuckRyder Offline
Originally Posted by E150GT
If it were me id flush a few times with distilled water. ...
Yup until it runs clear. 6-10 gallons usually does it.. Heater on full hot.
Robert
  • 2019 Volkswagen Jetta R-Line
  • 1972 F100 Ranger XLT (445FE/C6/9” 3.50 Truetrac)
  • 2002 Ford Ranger XLT 4D Supercab 3.0L
Re: 2006 TSX Rad flush - has non-Honda fluid [Re: JeffKeryk] #5456595 06/18/20 06:59 AM
supton Offline
I thought heaters were full flow these days, and instead used flaps in the HVAC case to adjust temperature.
2011 Toyota Camry, base, 2.5L/6MT, 206k
2010 Toyota Tundra DC, 4.6L/6AT, 160k
2003 CRV, 2.4L/4AT, 161k
1999 Toyota Camry LE, 2.2L/4AT, 225k
Re: 2006 TSX Rad flush - has non-Honda fluid [Re: JeffKeryk] #5456751 06/18/20 09:50 AM
B
bulwnkl Offline
B
I forget which engine the TSX uses. Honda’s J series V6 has a block drain bolt. Without draining the block (and water pump and hoses), there will be quite a lot of old fluid left in there. For my part, I’m not nearly so scared of ‘regular’ antifreeze as some are, but still if you’re looking to remove what’s in there and replace it with Honda-branded fluid, you should drain the block, pump, and lines (or flush with lots of distilled). If you don’t do this, you might have as much as half the system capacity un-drained.
I use speech recognition frequently. Please excuse any consequent grammatical or typographical errors.
Re: 2006 TSX Rad flush - has non-Honda fluid [Re: bulwnkl] #5457043 06/18/20 03:13 PM
J
J
K24. I believe there is a block drain in the rear above the oil filter.
You guys talked me outta the easy way.
Thanks to all.
2018 Lexus RX450h
2006 Acura TSX
Re: 2006 TSX Rad flush - has non-Honda fluid [Re: supton] #5457119 06/18/20 04:51 PM
DuckRyder Offline
It very well could be. Not sure about Honda, the Ranger for instance has a heater control valve. Never hurts.
Robert
Re: 2006 TSX Rad flush - has non-Honda fluid [Re: supton] #5457526 06/19/20 08:31 AM
G
Gebo Offline
G
That is very interesting. With all my stuff 2007 or earlier, would this apply to me as well?
'98 LEX LS400 310K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 75K
Shell Gas and Truck 5w-30
Amsoil OE 10w-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: 2006 TSX Rad flush - has non-Honda fluid [Re: JeffKeryk] #5457532 06/19/20 08:36 AM
G
Gebo Offline
G
Please drain the block, too.
Me, being a knucklehead, would do one drain and refill with Honda Fluid. Run it and then do another drain and fill with Honda Fluid.
I would be concerned as to how low my concentration would be if I did my flushes with distilled water knowing I could only add 50:50 back.
Probably wouldn't matter but I can afford a couple extra gallons of Honda Fluid AND I keep my cars for a long time.
'98 LEX LS400 310K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 75K
Amsoil OE 10w-30
