Forums Migration
Please read this thread
High Flow Thermostats
by Nick1994 - 07/12/20 02:51 AM
Hy-per Lube ZDDP Supplement 6pk $13.00
by alchargo - 07/11/20 10:38 PM
97 Civic HX valve cover pics
by CARJ - 07/11/20 10:22 PM
Time to ditch Speedplays
by UG_Passat - 07/11/20 10:03 PM
Dale L Nuzum
by Dalenuzum - 07/11/20 10:02 PM
*BANG* (Garage Door Spring)
by ctechbob - 07/11/20 09:40 PM
TPMS Sensors
by 92saturnsl2 - 07/11/20 09:16 PM
Chevron Delo 400 XSP 5W-30 XSP
by Gene K - 07/11/20 08:48 PM
LED retrofit for recessed can lights
by Donald - 07/11/20 07:08 PM
PP HM 5W-20 $15 at Wally
by Jackson_Slugger - 07/11/20 07:03 PM
Defeated by roll pin
by bcossa2001 - 07/11/20 06:56 PM
Dexron VI in place of Mercon LV?
by BigLee - 07/11/20 06:50 PM
89 c4 oil
by dogememe - 07/11/20 06:17 PM
Noticed the Titanium info.
by Farnsworth - 07/11/20 06:16 PM
FebiBilstein Parts
by willbur - 07/11/20 06:03 PM
Life goes on
by 53' Stude - 07/11/20 06:02 PM
Lubegard in a GM transfer case?
by BlakeB - 07/11/20 05:21 PM
Is MSO2 Liquid Moly OK in DIG NA engines
by JimPghPA - 07/11/20 03:10 PM
Rider Magazine Question
by Smoky14 - 07/11/20 02:38 PM
cadillactech, ILoveOil111, quantalume, SUmeme22, DaveCaddell
71910 Registered Users
24 registered members (Char Baby, ctechbob, Ausfahrt, d00df00d, 4 invisible), 608 guests, and 33 spiders.
Topics307,747
Posts5,316,944
Members71,910
Impressed with the Harbor Freight ball joint press set #5456422 06/17/20 09:15 PM
Chris142 Offline OP
My Jeep needed ball joints. Something we do not get into where I work. Checked with some local shops we deal with and decided that the $70 for the ball joint press kit was a bargain. One of those " if It only works once" things.
Now the Toyota Fj needed ball joints. Same thing. I am too cheap to pay what they want to install them.
Out came the $70 tool and a couple hrs out of my day. Got the passenger side upper and lower installed as those were very bad. Will do the other side next week.
I did have to fanagle with adaptors and use a big socket as the kit did not have the correct size adapter for the upper on the toyota. Still saved me $800+ in labor.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Impressed with the Harbor Freight ball joint press set [Re: Chris142] #5456492 06/18/20 12:21 AM
R
Reddy45 Offline
R
OK weird I had the exact same need for a larger "adapter" ring on my HF set. I think I ended up renting a BJ press from AutoZone that had the larger ring and was able to get the job done that way.
But yeah the quality on the HF unit seems about on par with the OEM branded one I rented from AZ.
Just make sure you grease those threads!
Re: Impressed with the Harbor Freight ball joint press set [Re: Chris142] #5456498 06/18/20 12:40 AM
Dave9 Offline
If it only needs to work once, get the loaner tool from Autozone or Advance Auto.
"Quality" is an elusive thing at HF. One specimen of widget will be fine. The next may have show-stopping defect(s).
Re: Impressed with the Harbor Freight ball joint press set [Re: Chris142] #5456508 06/18/20 01:28 AM
F
faltic Offline
F
Had a simular experance. Needed to change lower A arms on a Honda. The $27 Harbor Freight ball joint tool I used pulled the passenger side no problem. Pulling out the driver side I thought it would break, it did not. If I remember the whole job cost me under $150 tool + parts. No idea how much I saved. It's just how I operate. Thank you Harbor Freight and Rock Auto.
19 Tacoma 3.5 2wd AT. Under 3k
17 Highlander 3.5 2wd AT 20k+
19 Suziki S40 Boulevard 4 miles
07 EX250 21k+
11 PCX 125 5K+
Re: Impressed with the Harbor Freight ball joint press set [Re: Chris142] #5456517 06/18/20 01:55 AM
daves87rs Offline
Seems like they do well for a cheap tool...
2020 Chevrolet Trax LS
2019 Chevrolet Equinox LS
2006 Chevrolet Cobalt LS
2004 Chevrolet Cavalier (project)
Re: Impressed with the Harbor Freight ball joint press set [Re: Dave9] #5456532 06/18/20 03:58 AM
dlundblad Offline
No thanks.
I rented a ball joint press years ago and it turned out to be broken. Same with a fuel pressure gauge I rented last month. A bad fuel pressure gauge also acts like a bad fuel pump.
If I need a tool for a job, it’s worth buying too.
03 Jeep WJ 4.0 208k
02 Volvo S60 2.4T 199k
97 Chevy Blazer 4.3 175k
04 Audi A4 3.0 210k
Re: Impressed with the Harbor Freight ball joint press set [Re: Chris142] #5456536 06/18/20 04:16 AM
justintendo Offline
theres usually another boxed kit available that has nothing but sleeves and adapters. often costs about as much as the press itself, but worth having...maybe hf has that as well.
13 escape 2.0 awd mobil 1 10w30ep
08 fusion 2.3 mtx mobil 1 5w30ep/redline mt90
96 f150 4.9 2wd mtx mobil 1 10w30hm/redline ps fluid
99 kaw zrx 1100 redline 10w40
many husqvarnas 5w40 t6 rotella
Re: Impressed with the Harbor Freight ball joint press set [Re: Chris142] #5456583 06/18/20 06:41 AM
Z
Zaedock Offline
Z
I have a Matco press kit. I've always had everything I've needed to get the job done.
2019 Escape EB AWD/2016 KIA Optima SXL 2.0L Turbo/2012 F150 Ex-cab 5.0L
1992 YJ "The Heep"/2015 Chrysler 200 Limited
1975 Ford Bronco/1959 Willys CJ5/Tube Rock crawler / John Deere 750 Tractor
Re: Impressed with the Harbor Freight ball joint press set [Re: Chris142] #5456592 06/18/20 06:53 AM
Silverado12 Offline
I did ball joints once and rented the tool from Autozone. It was really good and had all the different sized sleeves.
12 Chevy Silverado ext. cab LS, 2WD 4.3 auto
18 Mustang GT 5.0 auto
07 Harley Dyna Street Bob 96 c.i. 6 sp.
00 Mustang GT auto
Re: Impressed with the Harbor Freight ball joint press set [Re: Zaedock] #5456597 06/18/20 07:03 AM
Chris142 Offline OP
I looked at that. $800! If I did front end work often I could see the need for buying a quality kit.
Re: Impressed with the Harbor Freight ball joint press set [Re: Dave9] #5456601 06/18/20 07:06 AM
Chris142 Offline OP
Never available here. People rent it and do not return it or the waiting list is too long.
Re: Impressed with the Harbor Freight ball joint press set [Re: Chris142] #5456650 06/18/20 08:05 AM
Delta Offline
How well did it work on the FJ? My Taco (same setup as the FJ) is going to be due for some suspension work within a year and id rather not send it to a shop for that work.
'17 VW GTI 2.0T - 6MT - 22K - Motul X-Cess 5w40
'15 Camry SE - 2.5 - 27K - Edge 0w20
'09 Tacoma TRD Offroad 4x4 - 4.0 - 142K - Valvoline MEO 5w30
Re: Impressed with the Harbor Freight ball joint press set [Re: dlundblad] #5456923 06/18/20 12:28 PM
Dave9 Offline
No thanks.
Then take it back and get a different one. If breakage was too common then they would switch to a different supplier. I've used them many times and a couple there were pieces missing when I went to get it, so I just always inspect the kit before leaving with it.
If you buy discount tools, you also risk it breaking but then a lot more hassle to get a replacement that you probably don't want because your confidence in the brand is gone, if they won't issue a refund without a hassle and if it's mail-order or warranty replacement then "somebody" is paying return shipping. Depends on where you bought it and how long ago, and of course if a short warranty has expired, you eat the loss.
Guess it could also depend on how far away an Autozone or Advance Auto is, here there are 3 within 3 miles that I drive by daily and for a while one of the Autozones was open 24/7.
Re: Impressed with the Harbor Freight ball joint press set [Re: Dave9] #5456962 06/18/20 01:12 PM
supton Offline
Where I live it's 15 minutes to a NAPA (that closes by noon on Sat and 5 during the week?), another 5-10 to AAP, another 15 after to get to Autozone and a bunch of stores. If I drive in the opposite direction it is more like 30 minutes to get to several stores.
I can see the reason to avoid cheap tools but man would I be mad to drive all the way only to find a rented tool was busted.
2011 Toyota Camry, base, 2.5L/6MT, 206k
2010 Toyota Tundra DC, 4.6L/6AT, 160k
2003 CRV, 2.4L/4AT, 161k
1999 Toyota Camry LE, 2.2L/4AT, 225k
Re: Impressed with the Harbor Freight ball joint press set [Re: Chris142] #5457214 06/18/20 07:06 PM
F
ford46guy Offline
F
Tons of AAP stores and they have plenty of tools to rent. If you don't like the kit, they can have a brand new one tomorrow. I don't know how they make money loaning those things for free.
95 Tbird V8 240K PP SYNTH ULTRA 5W30
98 MGM 160K M1 HM 5W20
96 Explorer EB V6 159K PP SYNTH HM 5W30
95 Conti 155K MC 5W20
11 GS350 90K PP HM 5W30
