Forums Migration
Please read this thread
Pennzoil strikes again with PDS (Euro 5W40)
by edyvw - 07/09/20 01:44 AM
Extra Load tires - Firmer ride?
by Spetz - 07/09/20 12:34 AM
make sure to use a software firewall
by 2004tdigls - 07/08/20 11:02 PM
Castrol 0w40 without LL-01 in BMW S63
by propellerhead78 - 07/08/20 09:59 PM
Automated key duplicators
by y_p_w - 07/08/20 09:59 PM
0W20 vs 5W20 base oils
by aquariuscsm - 07/08/20 09:39 PM
Shell Rotella T6 Multi Vehicle 5w30
by SummitX670 - 07/08/20 08:56 PM
Silicone rubber valve cover gaskets?
by Spetz - 07/08/20 07:59 PM
Back Up Camera
by Redright9 - 07/08/20 07:53 PM
Good Jackstands?
by 2015_PSD - 07/08/20 07:17 PM
Harbor Freight recalls more jack stands
by FordBroncoVWJeta - 07/08/20 07:11 PM
can a family of 4 use 34k gallons
by WhyMe - 07/08/20 05:26 PM
305 SBC Starter Grinding
by WA1DH - 07/08/20 05:19 PM
Ever hit a water meter with your riding mower?
by bchannell - 07/08/20 05:10 PM
Oil Recommendation 2020 GR Supra (Z4 har har)
by afree - 07/08/20 04:21 PM
Failing A/C compressor
by mb32 - 07/08/20 04:14 PM
PQIA 3 5W-30's 1 0W-20
by Jackson_Slugger - 07/08/20 03:35 PM
fl22 benefit over zerex?
by avi1777 - 07/08/20 02:51 PM
Brake Won't Bleed
by Gebo - 07/08/20 02:43 PM
Sledstorm1, Wishiwereaskibum, snowshew, Tenderness, SummitX670
71888 Registered Users
36 registered members (bfleeman, bbhero, CapriRacer, blufeb95, Bailes1992, Brian123), 843 guests, and 34 spiders.
Topics307,627
Posts5,314,504
Members71,888
2011 Kia Soul 2.0L Timing Belt broke, way to assess damage? #5456159 06/17/20 03:01 PM
M
MoreCowbellAz Offline OP
M
The above mentioned car just had the timing belt break, car has $185k on it, the belt had 90k. This is an interference engine, so there may well be valve or piston damage. Replacing the belt itself is going to run $1,100 even if there's no other damage.
My question is, is there a way to assess if the engine was damaged further? I'm not sure I want to put $1,100 into it, no way a remanufactured engine for even more money, but even if I sell the car as-is I'd like to be able to tell people it does or does not have valve/piston damage. The car is at a Pep Boys, wouldn't have been my choice but that's where they towed it when it broke down one evening (daughter's car).
I'm really disappointed with this, the belt was coming up on a replacement interval (Kia recommends 90k), but no way should it have just let go at 4yrs and BARELY 90k on it.
Any other options you guys can send my way? I'm all ears.
07 Toyota RAV4 2.4L
07 Toyota Prius Touring
00 Harley Road King Classic
20 Toyota RAV4 Hybrid (mine to maintain)
Re: 2011 Kia Soul 2.0L Timing Belt broke, way to assess damage? [Re: MoreCowbellAz] #5456162 06/17/20 03:03 PM
slacktide_bitog Offline
If it's an interference engine, the engine is toast cry
Make sure your next car has a timing chain smile
Re: 2011 Kia Soul 2.0L Timing Belt broke, way to assess damage? [Re: MoreCowbellAz] #5456174 06/17/20 03:17 PM
supton Offline
https://www.kiasoulforums.com/threads/change-your-timing-belt.25961/
This particular thread indicates piston damage--I'm guessing the valve snapped after being hit, and the debris damaged the piston. Back when I had my TDI though a number of people got lucky and no piston damage--but as a rule, a rebuilt/reman/whatever head was called for, as valves were bent. I think you're out at least a head.
Probably the least you could so is buy/borrow a borescope and go in through the sparkplugs to see what the carnage looks like. Pull all plugs. I'm guessing that the crank can be turned by hand, and I would check the cylinder walls for scoring. Piston damage and/or scored walls, and it's time for a new engine. If all is still attached, then maybe a new head.
2011 Toyota Camry, base, 2.5L/6MT, 206k
2010 Toyota Tundra DC, 4.6L/6AT, 160k
2003 CRV, 2.4L/4AT, 161k
1999 Toyota Camry LE, 2.2L/4AT, 225k
Re: 2011 Kia Soul 2.0L Timing Belt broke, way to assess damage? [Re: MoreCowbellAz] #5456190 06/17/20 03:42 PM
N
nwjones18 Offline
N
I thought if a timing belt broke on an interference engine then damage was a 100% sure thing.. I know the tensioner breaking on the chain on the Cadillac Northstar 100% ruined it..
2016 Ram 1500 5.7 Hemi 30k QSUD 5w-20 Mopar filter
2008 Honda CRV 125K QSUD 5w-20 Fram ultra
2007 Mazda 3 2.3 130k 5w-30 syn-blend Denso filter
1988 F-150. 4.9 I6 251k. 10w-40 QSHM Motorcraft FL1A
Re: 2011 Kia Soul 2.0L Timing Belt broke, way to assess damage? [Re: MoreCowbellAz] #5456195 06/17/20 03:45 PM
T
Trav Offline
T
Pop the head and have a look see, I have seen them totally shot with cylinder damage and some that just needed a few valves with no piston/wall damage. No point in guessing have a look.
Re: 2011 Kia Soul 2.0L Timing Belt broke, way to assess damage? [Re: MoreCowbellAz] #5456239 06/17/20 04:36 PM
R
Rand Offline
R
usually its not the belt the breaks but a pulley.. since they only replace the belt at the first interval.
the belt might go longer but a pulley(with 180k miles in your case) blows up and takes out the belt.
but onto your question.. you might well win the lottery and have no damage.. but the odds are not good.
but as Trav said it might be relatively minor to total pile of scrap.
Re: 2011 Kia Soul 2.0L Timing Belt broke, way to assess damage? [Re: MoreCowbellAz] #5456250 06/17/20 04:44 PM
B
BigCahuna Offline
B
My wife had a 2000 Kia Sportage that had the timing belt break. It was our fault because the manual said to change it at 60k. The mechanic tried to say i was an interference motor, but it wasn't. He thru a new belt on without doing anything else and it fire up and ran fine. It had about 104k on it when the original belt broke. I would check to be sure it's toast befre spending a ton of money on a old car with high miles on it.,,,
Re: 2011 Kia Soul 2.0L Timing Belt broke, way to assess damage? [Re: MoreCowbellAz] #5456278 06/17/20 05:17 PM
M
mk378 Offline
M
Take the valve cover off and rotate the cam to see if any valves don't come all the way up. If you see that, there's definitely a problem. If they all seem to work, you can do a leakdown test with no timing belt.
Re: 2011 Kia Soul 2.0L Timing Belt broke, way to assess damage? [Re: MoreCowbellAz] #5456280 06/17/20 05:18 PM
Nick1994 Offline
$1100 to replace the timing belt on a 4 cylinder? They’re ripping you off.
2015 Hyundai Genesis 5.0L 63k Dealer Bulk SynBlend 5w20 & OEM
2000 Toyota Camry 2.2L 239k Mobil Delvac 15w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 150k Rotella Gas Truck 5w30 & Wix
Re: 2011 Kia Soul 2.0L Timing Belt broke, way to assess damage? [Re: MoreCowbellAz] #5456296 06/17/20 05:30 PM
N
nicholas Offline
N
Not always.
I had 1 break in an old honda while at a red light.
No damage done.
New belt and water pump. I was back on the road.
The 91s were bullet proof.
2019 2.0T Santa Fe
2010 3.5 Santa Fe
Re: 2011 Kia Soul 2.0L Timing Belt broke, way to assess damage? [Re: MoreCowbellAz] #5456303 06/17/20 05:34 PM
Saabist Offline
Friends don't let friends get their cars serviced at Pep Boys. (Not even minor maintenance, let alone major repairs!)
Unfortunately the engine is probably toast but as others have said, inspect the damage - if very lucky maybe just some damaged valves.
Timing chains are much better, usually last the life of the car. (Mine has over 350K miles and is still good.)
Re: 2011 Kia Soul 2.0L Timing Belt broke, way to assess damage? [Re: MoreCowbellAz] #5456326 06/17/20 05:58 PM
M
M
I don't really have access to the car to do much work like pull the valve cover, bore scope, etc, so I'm kind of stuck. I'm just trying to help out my daughter in a jam. I talked to them, they're going to check it out with a bore scope and see if there's any signs of contact. If so, I doubt it's worth putting a reman head on it, but I'll look into that if that's the deal. If there's piston or cylinder damage, no way. If by some miracle nothing was damaged maybe new timing and serpentine belts and pulleys would be worth it just to get another 1-2 years out of it, but I'm not even 100% sure of that because she drives a lot of miles and I don't want her breaking down. Hence, just gathering my thoughts and getting some insight and opinions.
07 Toyota RAV4 2.4L
Re: 2011 Kia Soul 2.0L Timing Belt broke, way to assess damage? [Re: MoreCowbellAz] #5456379 06/17/20 07:29 PM
Nick1994 Offline
Call another shop and ask for cost to replace timing belt, that sounds way too steep to me.
My Camry's belt broke last August and my mechanic charged me $476.77 to replace it along with the idler bearings/pulley, new water pump, and new coolant.
Re: 2011 Kia Soul 2.0L Timing Belt broke, way to assess damage? [Re: Nick1994] #5456384 06/17/20 07:34 PM
N
Nitronoise Offline
N
my old hyundai 2.7 was only 600 bucks for belt tensioner and waterpump your getting ripped
07 Ford Freestyle 166K
06 Honda Acord EX 133K
02 Ford Tarus 123K
00 Buick Regal SC 144K
95 Goldwing 28K
Re: 2011 Kia Soul 2.0L Timing Belt broke, way to assess damage? [Re: MoreCowbellAz] #5456446 06/17/20 10:18 PM
cronk Offline
A kia 2.0 is a very simple engine to do a timimg belt on. I did my Spectra a few years ago myself, did a complete kit, belt, tensioner, idler pulley and water pump. In my home garage with no left or fancy equipment, i had it done in a few hours taking my time.
I think $1100 is very steep.
I think you may be further ahead getting it out of pep boys and get to a reputable indy garage for a 2nd opinion.
2008 Ford F350
2008 Kia Spectra
2011 Nissan Quest
1986 Pontiac Trans Am
1940 Ford 9N Tractor
Amsoil lubes and filters!
