Fireworks and dogs
by 555 - 07/04/20 07:52 PM
Cannot unscrew oil filter housing cap - BMW E46
by 97tbird - 07/04/20 07:21 PM
Are u a big fireworks person?
by ZZman - 07/04/20 06:53 PM
Honda Accord MAP sensor question
by Kira - 07/04/20 06:28 PM
Hy-Gard Shelf Life (Opened Bottle)
by viscous - 07/04/20 06:10 PM
Want to bet on my luck? (atf to "save" transmission)
by Snoman002 - 07/04/20 06:10 PM
Too Much Zinc = Corrosion?
by viscous - 07/04/20 06:00 PM
New vehicles with a 4 speed transmission?
by MrHorspwer - 07/04/20 04:57 PM
Inability to Choose
by Gene K - 07/04/20 01:53 PM
65 200 6 mustang running kinda hot
by old1 - 07/04/20 01:30 PM
Neo-protec GT em
by dervdave - 07/04/20 01:19 PM
Mannol 9929 Ester additive
by dervdave - 07/04/20 01:14 PM
2015 Corolla with 7k miles has “soft brakes”
by NHBFAN - 07/04/20 12:30 PM
Put Bilsteins on the Silverado
by bdcardinal - 07/04/20 12:19 PM
Hour meter - not moving?
by Serge - 07/04/20 11:52 AM
Was in a Parade today!
by sasilverbullet - 07/04/20 11:40 AM
Amsoil bypass kit ford 6.7 (BMK33)
by willypete - 07/04/20 11:39 AM
paolo9fla, SunnyB, Mullady76, Axia2, Johan1
71847 Registered Users
100 registered members (4WD, 97tbird, alarmguy, 2015_PSD, 87sammy, 555, 14 invisible), 1,444 guests, and 25 spiders.
Topics307,433
Posts5,310,926
Members71,847
What would keep a new head gasket from sealing? #5456135 06/17/20 02:31 PM
H
Hemispheres Offline OP
H
This happened a couple years ago but it's always bothered me.
I pulled a head on my buick and found cracks between the valves so I replaced them. The head gasket didn't take on the front cylinder bank. I cleaned the bolt holes, used copper spray a gasket and took extra care to line up the dowel pins and gently place the heads on the gasket. Even torqued the head bolts to 37 lb ft plus 120 degrees.
After firing it up and test driving it I noticed a substantial loss in power. I pulled the front head and found a lot of coolant in cylinder number 5. The rear cylinder bank sealed right up without any issues.
What could of caused that to happen?
2009 Buick LaCrosse (3800 Series III) - 137,000 miles.
PZ Plat HM/Mobil 1 HM
Bosch/Purolator/Mobil filters
Re: What would keep a new head gasket from sealing? [Re: Hemispheres] #5456137 06/17/20 02:33 PM
H
H
I also torqued the head bolts in sequence as per the service manual btw.
Re: What would keep a new head gasket from sealing? [Re: Hemispheres] #5456143 06/17/20 02:36 PM
M
mattd Online Content
Online Content
M
What’s the application? And why did you use the copper spray? IMO it isn’t mean to be used on modern MLS head gaskets. It’s meant for old flat head engines and copper gasket head gaskets.
2007 Ford F-350 4x4 6.0 PSD
ASE Master, L1, L2
Re: What would keep a new head gasket from sealing? [Re: Hemispheres] #5456144 06/17/20 02:38 PM
Astro14 Offline
Was the new head flat? Did you properly clean the block*? Did you clean the threads in the block*? Did your service manual suggest using that spray*? Does GM allow you to re-use the head bolts*?
*My quick search of Google on this topic suggests that you need to clean the block, chase the threads, use good gaskets (which means no spray ) and use NEW bolts.
Failure to follow those procedures will likely result in a gasket failure...and, of course, if the head itself isn't checked for flatness, that could cause it, too...
32 Packard 15W40
01 Volvo V70 T5 0W30 AMSOIL SS
02 Volvo V70 T5 0W30 Edge
02 Volvo V70 XC 0W40 Edge
05 MB S600 0W40 M1
Re: What would keep a new head gasket from sealing? [Re: mattd] #5456147 06/17/20 02:43 PM
H
H
3800 V6. There were very fine scratches in the sealing surface and someone suggested the gasket spray.
Re: What would keep a new head gasket from sealing? [Re: Astro14] #5456149 06/17/20 02:47 PM
H
H
The heads were milled 15 thousanths and I checked the block with a straight edge and feeler gauge. I took an old head bolt and cut grooves into to use as a cleaning tap and chased all the bolt holes in the block. Service manual did not suggest the spray, permatex did. I replaced all head bolts as they are torque to yield.
I also cleaned the block by using a white roloc pad followed by a fine 3m sanding sponge.
Re: What would keep a new head gasket from sealing? [Re: Hemispheres] #5456152 06/17/20 02:48 PM
spasm3 Online Happy
Online Happy
I would have even a new head checked to make sure the surface is flat. Check the deck too. Block and head must be clean. New bolts . What torque wrench? Is it's quality wrench? A cheap clicker may not be accurate enough for this. Lubed the head bolts?
13 elantra 84k 5w30 synpwr
17 mazda cx-5 19000 miles m1 0w30
Re: What would keep a new head gasket from sealing? [Re: spasm3] #5456155 06/17/20 02:52 PM
H
H
Didnt lube the head bolts since they went into the coolant jacket. Used an AC Delco digital torque reader for the first pass and a torque angle meter on the second pass.
Re: What would keep a new head gasket from sealing? [Re: Hemispheres] #5456167 06/17/20 03:06 PM
G
gonefishin Offline
G
What did you use on the head bolts in the coolant jacket? I just did a head gasket job a couple of months ago and had excellent results with this product:
Loctite head bolt and water jacket sealant. https://www.amazon.com/Loctite-1158514-Jacket-Sealant-50-milliliter/dp/B004QXL4F2
2015 Cadillac SRX
2014 BMW 528i
2004 Chevrolet Trailblazer 4.2
1969 Chevy Camaro
Re: What would keep a new head gasket from sealing? [Re: gonefishin] #5456168 06/17/20 03:07 PM
H
H
Originally Posted by gonefishin
What did you use on the head bolts in the coolant jacket? I just did a head gasket job a couple of months ago and had excellent luck with this product:
The bolts came with a sealer on the threads.
Re: What would keep a new head gasket from sealing? [Re: Hemispheres] #5456181 06/17/20 03:30 PM
K
Kawiguy454 Offline
K
Did you burp the coolant system once it was buttoned back up? Some older GM's has small bleeders to get the air out of the passages. Failure to bleed resulted in steam pockets that could ruin gasket seal. Don't ask me how i know this. sick
Re: What would keep a new head gasket from sealing? [Re: Hemispheres] #5456184 06/17/20 03:35 PM
PimTac Offline
Can you clarify what you replaced ?
2017 Mazda CX5
Mobil 1 Annual Protection 0w20
Roki OEM filter.
Re: What would keep a new head gasket from sealing? [Re: Kawiguy454] #5456191 06/17/20 03:42 PM
H
H
Yes I bled it.
Re: What would keep a new head gasket from sealing? [Re: PimTac] #5456192 06/17/20 03:42 PM
H
H
I got remanufactured heads.
Re: What would keep a new head gasket from sealing? [Re: Hemispheres] #5456199 06/17/20 03:50 PM
demarpaint Offline
The head could have been warped, the gasket damaged, dirt or foreign matter on the mating surfaces, torqued incorrectly, or at the wrong value, etc. Bottom line is it could have been a lot of things.
God Bless Our Troops
