3.8 grand caravan or 3.6?
We are looking at 2 used minivans one is a 2010 107,000 miles with the 3.8 looks clean the other is a 13 town and country with the 3.6 almost exact miles the t/c is $2400 more than the grand caravan sxt.
I've seen plenty of 3.8 over the years some with very high miles and others with major issues and severely neglected. I've seen a couple head gaskets on the 3.8 but once again they were older and neglected. The 3.6l I haven't seen a bunch from but I've heard of rocker arm and camshaft issuers. Which engine would you prefer? Any personal experience with either? Which would you go with? Thanks everyone!
I think the early 3.6 might have had a few issues. The 3.6 is a sweet motor though. It revs nice and is smooth. I have no experience with the 3.8. I would probably go with the 3.6 for ease of getting parts. The 3.6 is in so many fca vehicles pickings are ripe.
I'd get the 3.8. All of them ive seen at walmart took some real abuse and they still keep trucking along. The earlier 3.6 id stay away from. The newer ones are awesome though.
I don't have any experience with the 3.6 but there are two Chrysler vans within my extended family with the 3.3 and 3.8 and both are at or near 200,000 miles with very poor maintenance done to them and they are still surviving.
Yep. My parents 2004 with the 3.3 is somehow still living at almost 190k. And yes, original transmission that's only seen one flush (jiffy lube) in its life.
I really like the 3.6, very smooth. 2011-2013's did have the extended warranty added to one of the cylinder heads, and the oil filter housing changed around that year or 2014.
I'd go with the 3.6L. When you consider 10,000,000 of the first generation 3.6L engines were made, IMO issues with them seem to get blown out of proportion. If possible I'd look at 2014 or newer.
I would probably go with the van that less options and in better shape.
The 3.6 will run better all around, but the money savings on the 3.8 would pay for the increased gas bill (and any oil consumption it may have). Pretty sure both these are 6 speed autos? Early 3.6's could have a bad cylinder head--but most of them should have been replaced by now. I'd rather have the 3.6 for increased HP and mpg but the 3.8 has more than proven its ability to pile on miles and get the job done.
Oh the 3.6's do commonly break oil cooler housings--I don't know what the cost is to replace but it's a common issue.
I've had both in T&C minivans. A 3.8 in a 2007, and a 3.6 in a 2011. Dad's girlfriend has a 2011 T&C 3.6 with 180,000 miles.
Both performed just fine. The 3.8 started burning oil at the 80,000 mile mark, despite documented timely oil changes throughout its life. Disappointing.
Sure, the 3.6 performs better, but the problem with the 3.6 model isn't really the engine itself. TIPM failures on both (one remote started itself inside a closed garage attached to a house). Rear AC failure on one. Both of these are $1500+ to fix. One TIPM failure also led to rental car costs. Rust around the wheel openings on the body. Typical Chrysler issues.
There's a known head failure issue on the 3.6, I haven't seen it on either one.
You don't want a 08-10 model with the 4.0... unless you want to deal with a timing belt. Had a friend trade one with a 4.0 in, as it had a bad TIPM. It was his wife's van, and it would randomly stall and not restart.
I'd go with either one. Only issue with the 3.3/3.8 was intake manifold gaskets after they get some age on them (and possible corrosion of the aluminum intake). The 3.6 is just like everyone said, some occasional issues on early ones. Likely pretty rare.
We had a 2010 3.8 Town & Country, 2 stroke motor, unless you keep check oil, used +1 quart every 3,000 miles. Run
How old was it? It's not really that high--I'd be miffed in a new mill, but TBH I think most OEM's will tell you that up to a quart per 1,500 miles is "normal". That I think is kinda severe--but after 100k is on the clock I'm not sure that a qt/1k is that bad. Annoying for sure.
The 3.6 will have much more power than the 3.8. Don't the Chrysler minivans have transmission problems?
If you can find one, get a 4-cylinder Sienna. About the same power as the 3.8 Caravan, but much easier to work on and no transmission problems!
But if you like the Chrysler vans, the 2013 3.6 will be better since it has much more power and is newer, so less rust or chance of rust.
Which ever is cleaner and for the $ you want to spend.
The 2013 will have larger and better rear brakes. I believe even the 2010 should have the 62TE 6spd transmission. I wouldn't go for the 2010 if it does not.
Like said, there isn't anything wrong with the old pushrod 3.8L V6 other than it being underpowered in this application and not as fuel efficient as the pentastar.
Van started oil consumption @ 38,000 miles stayed same till loss @ 145,000 miles . I thought the vintage design would have been more robust too. Changed PCV valve every 25,000 miles no effect on consumption. Yes if you have the discipline to monitor/check it will run fine. Front brakes would not go more than 30,000 miles, know issue. Random no start, had to get Vertical Visions kit for TIPM/TPIM. Lots of rattles too after 75,000 miles.
