Forums Migration
Please read this thread
Amsoil SS 5w30
by mpgo4th - 07/07/20 06:57 AM
Water/Coolant Contamination?
by nastyc5 - 07/07/20 06:53 AM
07 Tahoe trans fluid change.
by Anthony - 07/07/20 06:06 AM
Ravenol 15W40 Marine
by Realfine69 - 07/07/20 05:10 AM
2020 VW 0W20??
by Realfine69 - 07/07/20 05:06 AM
Who makes the O'reillys trans filters ??
by GMguy84 - 07/07/20 05:00 AM
[Seattle Craigslist] Cheap Pennzoil 5w20
by SlavaB - 07/07/20 02:14 AM
Best Synthetic Oil For Cleaning
by BlueOvalFitter - 07/06/20 11:18 PM
Make your predictions for 20 years from now...
by sloinker - 07/06/20 10:47 PM
Getting rid of carbon in exhaust ports?
by Spetz - 07/06/20 10:15 PM
Rotella Gas Truck 0W-20 VOA
by HDoilDude - 07/06/20 09:57 PM
Two Mobil 1 M1-110A filters. Different sizes
by Dallasmale1970 - 07/06/20 09:46 PM
BITOG forums migrating to Xenforo soon
by wwillson - 07/06/20 09:41 PM
Carburetors - I think I've learned to like them
by Kurtatron - 07/06/20 09:40 PM
Best fuel stabilizer/cleaner ?
by icemanrrc - 07/06/20 09:39 PM
Engine Restorer = Glittery oil?
by nastyc5 - 07/06/20 09:35 PM
MC FL-820S Cut Open
by BlueOvalFitter - 07/06/20 09:03 PM
Flat Back Diff Cover - Failures 🤔
by SavagePatch - 07/06/20 08:52 PM
VW 9M/9G Transmission fluid ?
by JswFL - 07/06/20 08:38 PM
sycboi, Chuck_Ellison, BakonBittz, ssoH, Sumpter_al
71869 Registered Users
83 registered members (86cutlass307, ABN_CBT_ENGR, 2010Civic, 2009Edge, AndyB, alarmguy, 13 invisible), 1,253 guests, and 30 spiders.
Topics307,536
Posts5,312,678
Members71,869
ADBV inlet and outlet!?!? #5455728 06/17/20 12:25 AM
DirtyOilGuy Offline OP
ok, so i was reading something and this guy says ""Changing the filter in my car to a version with both inlet and outlet anti drain valves made a difference on cold starts after sitting for 2 days, no light tapping for the second after starting."" is this a thing?! i know that some oil filters have an ADBV, and i guess i just assumed it was on one side only, and now that this guy said it this way i'm just NOW realizing that if they have an ADBV, then just naturally means it's always both inlet and outlet. anyone wanna clarify?
he also said ""Went from a Z88 to a Z157, otherwise identical filters.""
i tried googling z157, and well it wasn't as clear cut to find that filter. i dont know what brand that would be or if anyone makes that size.
thanks
Re: ADBV inlet and outlet!?!? [Re: DirtyOilGuy] #5455772 06/17/20 05:22 AM
L
Lubener Offline
L
You did not mention what vehicle you have. I never heard of such claims. The ADBV is just a nitrile or silcone flap, just one and can be seen through the multiple inlet holes.In some apps.there may not be a ADBV in the filter if the filter is positioned in such a way that drain back is not an issue. If you still have doubts, go with an OEM filter.
The "thinking" man's friend.
Re: ADBV inlet and outlet!?!? [Re: DirtyOilGuy] #5455949 06/17/20 10:02 AM
R
Rhymingmechanic Offline
R
I've never seen or heard of a filter with two ADBVs. That seems like a redundancy that would cut into profits. Maybe the poster was mistakenly referring to a filter with a bypass valve and an ADBV?
I found a Mopar cross-reference for the numbers you gave. Z88 is a "Coopers" filter and Z157 is a "GUD" filter. Both cross to Mopar 1AMFL00033. A photo of the Mopar filter does not show an ADBV on the open end.
Re: ADBV inlet and outlet!?!? [Re: DirtyOilGuy] #5455957 06/17/20 10:24 AM
Z
ZeeOSix Offline
Z
He's talking about filters with an "anti-siphon" valve in the center tube, which is essentially a second ADBV. There have been a few posted here in the past, but they are rarely seen.
