Forums Migration
Please read this thread
I found a WWII movie for yinz to watch.
by JimPghPA - 07/12/20 04:45 PM
Jackpoint Jackstand Review
by RamFan - 07/12/20 03:03 PM
Lesabre Brake fluid capacity
by Ihatetochangeoil - 07/12/20 02:56 PM
Baking Cookies in the Car - 2.0
by Nick1994 - 07/12/20 02:17 PM
Dealer ruined my transmission!!!!
by John344 - 07/12/20 02:04 PM
Wax / Sealer Recommendations
by 92saturnsl2 - 07/12/20 01:45 PM
Horrible Duramax Aftermarket Filter Mod
by ToadU - 07/12/20 01:29 PM
Japan unveils timeline for indigenous fighter jet program
by gathermewool - 07/12/20 12:27 PM
NEW Rotella T6 15w40
by ToadU - 07/12/20 11:54 AM
2001 Silverado 1500 4x4 Alignment Concerns
by Blang - 07/12/20 11:37 AM
Full Synthetic for ATS V
by cadillactech - 07/12/20 11:33 AM
Gasoline engine oil in a diesel engine?
by LeslieX - 07/12/20 11:32 AM
Can I use IPA 70% to clean windshield?
by painfx - 07/12/20 09:47 AM
The Heat is on
by Snagglefoot - 07/12/20 07:39 AM
Working on your car
by CourierDriver - 07/12/20 07:35 AM
My last two cars were direct injection
by Railrust - 07/12/20 06:52 AM
High Flow Thermostats
by Nick1994 - 07/12/20 02:51 AM
Hy-per Lube ZDDP Supplement 6pk $13.00
by alchargo - 07/11/20 10:38 PM
Slick122, Ford4life76, Patrick_Hall1988, Ron1948, cadillactech
71914 Registered Users
84 registered members (2004tdigls, 2010Civic, Alaskanmont, Aichiguy, 53' Stude, 87sammy, 8 invisible), 2,102 guests, and 44 spiders.
Topics307,766
Posts5,317,416
Members71,914
Subaru CVT TCC Lockup Fix - Done #5455556 06/16/20 08:06 PM
deanm11 Offline OP
In case it helps anyone - on our original owner 159k mile 2012 Impreza, the dreaded 0700 and 2764 codes were thrown a couple weeks back. (think they throw 2763 sometimes. Car was stumbling coming to a stop as well, kind of like the converter was stuck locked, but I also cleaned up a bad idle at the sime timeby cleaning the throttle body, so unsure if the stumble was the same problem. The trans worked perfect at speed even with all the dash lights that went off. It even was flashing overtemp trans but it really couldn't have been.
In the redesigned '12 Impreza, this is the second generation 'TR580' CVT. In this unit, at least I think '13 back, there are two known problems. One is the torque converted itself physically has a thrust washer that goes bad and impedes release of lockup. Reman torque converters are available with a full on bearing in place of the washer.
The more common, I believe, problem is the TCC solenoid in the valve body. The valve body is removable from the engine compartment, firewall area (its below a cover plate on top of trans.) Take out the air tube, 'dog bone' and you can pretty much go at it. Subaru only sells a complete valve body and then does expensive fluid service and computer learning.. reportedly minimum bill of $1500.
Aftermarket has the TCC solenoid for $100-$150. I bought the one on Amazon even though it was more expensive, just in case, due to specific reports of successful uses of that one. There's ones on ebay closer to $100 and some other places. Book labor to R&R the valve body is just over 2 hours and I was pretty close on that part. I ended up spending a lot of time on the solenoid replacement but there's nothing all that hard and you are not taking the valve body apart but just some bolts, removing a plate that holds down 4 of the solenoids. When you take the access cover plate off, beware there are two pin-dowels so after bolt removal you need to pry up- I hadn't know so I banged the cover a bit, thinking it was stuck to the mating surface.
My old solenoid didn't 'ohm out' bad at all actually. Spec is about 12 ohms and some fails apparently are low impedance. Some warned it also may only be bad when hot, and then possibly 'open', and I did seem impedance going a little high with a heat gun, but only like 15 ohms. Regardless, the fix seems to be 100%. Because of the top access, there is no or negligible fluid loss - I didn't adjust it for the trace loss. Picture is of the back or down side of the valve body with the hold down plate and the TCC solenoid out. There is a bit of trickiness with the wires - at first it looks hard wired and that may be even one of the excuses Subaru uses for selling only a complete valve body. But three small screwdrivers carefully pries a cap off, revealing spade terminals.
2012 Subie Impr 2.0 142k M1EP 0w20 7.5k
2002 Tahoe 5.3 171k 5w30 syn 7.5k
Re: Subaru CVT TCC Lockup Fix - Done [Re: deanm11] #5455571 06/16/20 08:23 PM
R
Rand Offline
R
Impressive how these seem to be getting more serviceable as time goes on.
It's beyond what I would want to do.. though it might be within limit of what I would attempt and succeed at.
Re: Subaru CVT TCC Lockup Fix - Done [Re: Rand] #5455621 06/16/20 09:27 PM
M
Miller88 Offline
M
Subaru is pretty eager to warranty them out. "Oh you have a small pan seep, new CVT for you!" or in the case of the torque converter or valve body, immediate replacement. However, what Subaru usually doesn't see is the complete failure that the Nissan units were having. In a lot of cases, getting the thing working again is user serviceable.
I believe that is because Subaru uses separate lubricant for the differential. Just a theory, though, based off of what I have been seeing when people tear them down.
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: Subaru CVT TCC Lockup Fix - Done [Re: deanm11] #5455771 06/17/20 05:21 AM
W
WyrTwister Offline
W
Congrats ! :-)
Best wishes
Wyr
God bless
Re: Subaru CVT TCC Lockup Fix - Done [Re: deanm11] #5455835 06/17/20 07:09 AM
B
benjy Offline
B
owners are the beta testers even now as Subaru wants an untouched unit if in warranty so they can learn how to improve problematic CVT's! 3 pedals ALWAYS for me although conventional automatics are generally reliable.
Re: Subaru CVT TCC Lockup Fix - Done [Re: benjy] #5456746 06/18/20 09:44 AM
M
Miller88 Offline
M
Ironic, but I've always sought out manual transmissions. And I've had more problems with manuals over the years than automatics oddly enough.
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
