FJC Foaming Evaporator Cleaner Review
by Reddy45 - 07/04/20 12:10 AM
Ford 351W oil filter best value
by alex16 - 07/03/20 11:12 PM
Super tech euro 5w40 - Canada
by Johan1 - 07/03/20 10:19 PM
Strangers show up for vet's funeral.
by simple_gifts - 07/03/20 09:44 PM
Troybilt tb22ec refuses to run correctly
by Dogred08 - 07/03/20 09:43 PM
Harbor Freight Nitrile gloves
by 1978elcamino - 07/03/20 09:04 PM
Did anyone get a 25% coupon for July 4th?
by 1978elcamino - 07/03/20 08:58 PM
05 4.6 Northstar crank sensor re learn?
by cknight49090 - 07/03/20 08:40 PM
In the year 2049...
by eljefino - 07/03/20 08:05 PM
2-year old oil 124 Spider
by DAC17 - 07/03/20 07:57 PM
New to us van
by ram_man - 07/03/20 07:22 PM
original '05 Chrysler trans pan gasket material ?
by visitor - 07/03/20 06:16 PM
rock auto can't ship to Calif????
by 928 - 07/03/20 06:04 PM
2001 Silverado 1500 T-Case Fluid
by Blang - 07/03/20 05:53 PM
Nasty Car wreck
by ford46guy - 07/03/20 05:53 PM
Best style of condenser?
by ddeflyer - 07/03/20 05:17 PM
Advance Auto now selling Die Hard Batteries
by Kira - 07/03/20 05:01 PM
Ontario Nuclear update - Part 2
by OVERKILL - 07/03/20 04:36 PM
Is this totaled?
by NoNameJoe - 07/03/20 04:23 PM
Johan1, MrMoneyMcLube, JeffAR, ThaKid22, Speedeuphoria
71843 Registered Users
54 registered members (AlienBug, BAJA_05, 94astro, AndyB, Astro14, alarmguy, 6 invisible), 1,065 guests, and 39 spiders.
Topics307,398
Posts5,310,374
Members71,843
Page 1 of 4 1 2 3 4
New Engines and Oil Life Monitors #5455307 06/16/20 02:38 PM
G
Gene K Offline OP
G
I know everyone is really passionate about this but how about a reasoned discussion shall we.
I noticed my 2014 Mustang (5.0 with traditional Port EFI & 8 quart sump that averaged well over 20 mpg) called for a 10,000 mi oci by the IOLM.
A 2014 F150 3.5EB (GDI, Turbos, 6 qt sump and 16 mpg) also called for 10,000 mi oci by IOLM.
A 10,000 mi analysis on MC Blend from the Mustang was difficult to tell from the virgin sample.
A 6,000 mi sample of Mobil 1 from the EB looks like it's been shredded. Low-7's cSt in viscosity, near 10% fuel contamination and 6x the iron level and half the TBN of MC Blend in the 5.0 at 10,000 mi
Given these "challanges" is the consensus still to follow the oil life monitor? I will admit a 10,000 mi OCI on Synthetic on my newer F150 18 3.5EB would make me more nervous than a 20,000 mi OCI on conventional in my 14 5.0 Mustang.
What is the consensus on modern GDI Turbo engines with moderate oil capacity, modest mpg and a fairly aggressive IOLM program?
Follow the IOLM or change earlier?
Gene
2014 Mustang GT 5.0 SC - 675 bhp
ST Synthetic 10W30 / FL500S
2018 F150 4x4 3.5 EB
OEM Oil & Filter
2018 Lincoln MKX 3.7
OEM Oil & Filter
Re: New Engines and Oil Life Monitors [Re: Gene K] #5455311 06/16/20 02:44 PM
W
wbwanzer Offline
W
I would change earlier.
Re: New Engines and Oil Life Monitors [Re: Gene K] #5455315 06/16/20 02:48 PM
Bryanccfshr Offline
50%
2018 Trd Pro 4Runner
2018 Tacoma off-road
Dealer 0w20 to M1 0w40 FS -it depends
Re: New Engines and Oil Life Monitors [Re: Gene K] #5455318 06/16/20 02:53 PM
M
Miller88 Offline
M
My parents had a Ford Escape with the oil life monitor, but I'm not sure it actually did any monitoring. Just reset and go off very 7500 miles. Of course they changed it before 7500 miles, my father isn't a big fan of GDI engines and longer drain intervals.
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: New Engines and Oil Life Monitors [Re: Gene K] #5455324 06/16/20 02:58 PM
4WD Offline
I don’t have the turbo but have DI in a 5.3L GM on 0w20. At 40% remaining ... changed my $5 filter and that makes room for a quart of HD30 ... $8 & 10 mins ...will finish the OLM
Re: New Engines and Oil Life Monitors [Re: Gene K] #5455327 06/16/20 03:00 PM
G
Gebo Offline
G
Change way earlier.
I only have an OLM on the church van. If I went by it we would change our oil about every 7 years.
'98 LEX LS400 310K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 75K
Shell Gas and Truck 5w-30
Amsoil OE 10w-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: New Engines and Oil Life Monitors [Re: Gebo] #5455333 06/16/20 03:04 PM
G
Gene K Offline OP
G
Originally Posted by Gebo
Change way earlier.
All my IOLM default to 365 days if you are a low miler.
After three two-day open track events within just a few weeks my Mustang called for a 1700 mi OCI so I'm fairly certain it actually does actually do something (I had previously thought it had a 3,000 mi minimum just like the 10,000 mi maximum but apparently not).
Gene
OEM Oil & Filter
OEM Oil & Filter
Re: New Engines and Oil Life Monitors [Re: Gene K] #5455343 06/16/20 03:17 PM
supton Offline
Sounds like you have data to justify earlier change (or a reason to find better oil). So I'd definitely do that.
As to the oil life monitors, I'm pretty sure that the OEM's are putting in no small work into them. So I don't know what the problem is--seems like they ought to be good and conservative. That or maybe Ford doesn't think the wear and tear on the oil is that bad--we might think it awful, they might think, gee, it's worn out oil--what did you expect?--don't you feel good about getting all you could out of that oil?
2011 Toyota Camry, base, 2.5L/6MT, 206k
2010 Toyota Tundra DC, 4.6L/6AT, 160k
2003 CRV, 2.4L/4AT, 161k
1999 Toyota Camry LE, 2.2L/4AT, 225k
Re: New Engines and Oil Life Monitors [Re: Gene K] #5455344 06/16/20 03:17 PM
Danno Offline
Especially with Ford, I would never go with the OLM, if you want to keep the car past warranty.
Ford provides zero goodwill past warranty and even in warranty their warranty coverage can be difficult to get.
Ford's goal is to minimize perceived maintenance costs to potential onwers with the 10,000 mile OCI and to get cars past warranty.
1st hand experience in buying and maintaining 1,000s of Fords for a large private fleet.
If they were my cars, no more than 5,000 mile (or less if OLM calls for it) OCI with SN+, SG, D1G2 oil with appropriate Ford rating on the bottle.
2019 Jeep Grand Cherokee Summit 5.7L Hemi
2019 RAV4 Limited Hybrid
2016 Sorento SX V6 AWD
2010 Mazda 3 2.0L
Re: New Engines and Oil Life Monitors [Re: supton] #5455345 06/16/20 03:19 PM
4WD Offline
What best oil is going to handle that much fuel ?
Re: New Engines and Oil Life Monitors [Re: Gene K] #5455346 06/16/20 03:21 PM
Z
ZeeOSix Offline
Z
I know the Ford 2015+ OLMs will count down ~2% per week even if the vehicle isn't driven. If the vehicle sat for a year without ever being started, the OLM would go from 100% to 0%.
Re: New Engines and Oil Life Monitors [Re: Gene K] #5455354 06/16/20 03:27 PM
B
BigCahuna Offline
B
My thought on OLM's is, they are just a hours in use timer. It doesn't know, or care what type of oil your using. I can reset the olm on my wife's Equinox, any time I want and it will rest the timer. When it goes another 5k mile's, it will tell you to change the oil again. I feel it's just a reminder for people that never give changing their oil a thought. If it actually could tell if you need to change it, you shouldn't be able to reset it unless you changed the oil.,,,
Re: New Engines and Oil Life Monitors [Re: BigCahuna] #5455362 06/16/20 03:35 PM
supton Offline
That's not really an OLM then, that sounds more like a maintenance light instead. Two of my cars have the same light, and I'm supposed to change the oil every other time (5k rotations, 10k OCI's). I'm actually ok with that. But from what I've read here, other makes do have OLM's that take into account idle time and gas through the motor (heavy operation burns more gas and shortens OCI).
Re: New Engines and Oil Life Monitors [Re: Gene K] #5455363 06/16/20 03:36 PM
Cujet Offline
What you've noticed about EB engines is spot on. I've been saying this for years on BITOG. I have a first gen EB and noticed these things back in 2011. Every so often I post about it. So it came as no surprise when "mistreated" EB engines started showing up for timing chain replacements. Not to mention the near constant troubles with cam phasers.
An honest assessment of what is going on in modern engines really does point to the need to manage oil and viscosity better than simply going with the OLM and viscosity requirement. Those who make the statement that the "manufacturer knows best" give nothing more than "lip service" to the fact that the manufacturer is in the business of selling new vehicles, and not in the business of keeping them running beyond their "useful lives" They are also in the business of performing repairs. The fact that they last as long as they do has a lot to do with competition and EPA/environmental requirements.
Re: New Engines and Oil Life Monitors [Re: Gene K] #5455365 06/16/20 03:40 PM
JohnnyJohnson Offline
I'm just mystified how I ever got over 140K miles out of my 2004 Corolla S without one.
2004 Corolla 140560
Out: Pennzoil Platinum HM 5W-20 ST 4386
In: Valvoline Synpower Full Synthetic 5W-30 Purolator PureONE
2006 Duramax 77117
Out: T6 5W-40 XG9100 73909
In: Rotella Dino PH9100 11-3-19
Page 1 of 4 1 2 3 4
