Forums Migration
Please read this thread
Nokian Entyre C/S
by Robster - 07/09/20 06:00 AM
Corolla Cross
by wemay - 07/09/20 05:51 AM
Pennzoil strikes again with PDS (Euro 5W40)
by edyvw - 07/09/20 01:44 AM
Extra Load tires - Firmer ride?
by Spetz - 07/09/20 12:34 AM
make sure to use a software firewall
by 2004tdigls - 07/08/20 11:02 PM
Castrol 0w40 without LL-01 in BMW S63
by propellerhead78 - 07/08/20 09:59 PM
Automated key duplicators
by y_p_w - 07/08/20 09:59 PM
0W20 vs 5W20 base oils
by aquariuscsm - 07/08/20 09:39 PM
Shell Rotella T6 Multi Vehicle 5w30
by SummitX670 - 07/08/20 08:56 PM
Silicone rubber valve cover gaskets?
by Spetz - 07/08/20 07:59 PM
Back Up Camera
by Redright9 - 07/08/20 07:53 PM
Good Jackstands?
by 2015_PSD - 07/08/20 07:17 PM
Harbor Freight recalls more jack stands
by FordBroncoVWJeta - 07/08/20 07:11 PM
can a family of 4 use 34k gallons
by WhyMe - 07/08/20 05:26 PM
305 SBC Starter Grinding
by WA1DH - 07/08/20 05:19 PM
Ever hit a water meter with your riding mower?
by bchannell - 07/08/20 05:10 PM
Oil Recommendation 2020 GR Supra (Z4 har har)
by afree - 07/08/20 04:21 PM
Failing A/C compressor
by mb32 - 07/08/20 04:14 PM
PQIA 3 5W-30's 1 0W-20
by Jackson_Slugger - 07/08/20 03:35 PM
Sledstorm1, Wishiwereaskibum, snowshew, Tenderness, SummitX670
71888 Registered Users
72 registered members (alarmguy, BigCahuna, 77Se7en, ABN_CBT_ENGR, 07hemi, 2002 Maxima SE, 9 invisible), 1,120 guests, and 41 spiders.
Topics307,629
Posts5,314,523
Members71,888
Headlights #5455279 06/16/20 02:02 PM
R
rdevans89 Offline OP
R
Have a 2006 Mazda 3, it has been cared for well, but over time the headlight covers were showing their age. Have tried various polishes and even 3000 gr. sandpaper. But the slight yellowing seemed to remain. So tried armor all headlight wipes. They worked pretty well, you can see the yellowing on the cloth coming off. Now it's not perfect, but it did work in making the covers look almost new again. Followed up with some liquid flitz polish and some wax. All in all a good simple process. Cheers.
Re: Headlights [Re: rdevans89] #5455286 06/16/20 02:12 PM
L
Lenny5160 Offline
L
I've only used the Sylvania restoration kit, but have been very happy with the initial result as well as how they look two years later.
Re: Headlights [Re: rdevans89] #5455306 06/16/20 02:38 PM
Donald Online Content
Online Content
You need multiple grades of abrasiveness. After done, you need to put a coating on them to protect from future damage.
2015 Ford F-250 w/Powerstroke
Re: Headlights [Re: rdevans89] #5455322 06/16/20 02:55 PM
G
Gebo Offline
G
Is there a "best" way to restore headlights that we can do at home? I used some Brake Fluid per someone's recommendations and I'm impressed. Not enough to do it again but nevertheless, impressed.
'98 LEX LS400 310K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 75K
Shell Gas and Truck 5w-30
Amsoil OE 10w-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: Headlights [Re: rdevans89] #5455328 06/16/20 03:01 PM
K
Kawiguy454 Offline
K
For all the time, effort and products you'll need to buy for a moderate improvement just get new lenses on FleaBay for a song. Even cheapo CH ones are surprisingly decent quality crystal clear plastic lens and good reflectors close to OEM.
Re: Headlights [Re: rdevans89] #5455349 06/16/20 03:22 PM
B
buck91 Offline
B
I've had excellent results using blue magic polish on a 3in wheel with my drill. Pretty equal results between a wool and a foam cutting disc.
2018 F150 Screw 4x4 2.7L Ecoboost
2011 F150 Scab 4x4 5.0L
1996 Mustang GT 5spd/ragtop
Re: Headlights [Re: rdevans89] #5455398 06/16/20 04:41 PM
J
JeffKeryk Offline
J
I have used a few different things including kits. They all work pretty well.
Wifey wanted her 2006 TSX done; my paint guy offers this service for $150. Other places are as cheap as $50 I believe.
Alex did a freakin' outstanding job, guaranteed for 1 year.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: Headlights [Re: rdevans89] #5455465 06/16/20 06:01 PM
1
14Accent Offline
1
A true headlight restoration can't really be done with over the counter products. At work, I have a full 3m kit that I use. It starts with 500 grit, then 800, then a wet sand with 1000 and 3000. After that I use a 3m machine polish to get the finer scratches out and then a polish to make them shine like new.
That being said, it doesn't always work. Some headlights are just too far gone to restore, and I've also had some that had weird plastic that literally melted when sanding with the 500 grit. And no, it wasn't user error.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
1980 Honda CB900C - 15k mile cream puff
Re: Headlights [Re: rdevans89] #5455625 06/16/20 09:33 PM
samven Offline
I have gone through the 800, 1000, 2000, 3000, polish and wax on my 03 Ram truck headlights trying to get a bit more light on the ground. It has cleared them up and they look OK but its a lot of work. I will try the wipes and see if I can preserve the clarity with them a bit longer before going back through the sanding thing. I am also going to try a brighter bulb
Has anyone tried the acetone wipe, I read about it but acetone can be really destructive to plastic and I have been afraid to do it.
Re: Headlights [Re: buck91] #5455839 06/17/20 07:17 AM
SatinSilver Offline
I think I’ll try this option next. Where did you get the 3 inch wheel and wool pad from?
Re: Headlights [Re: Kawiguy454] #5459486 06/21/20 10:10 PM
T
tbm5690 Offline
T
I agree, except if you have HID or LED the cheapos are usually nowhere near OEM quality.
2014 Acura MDX Tech SH-AWD
2014 Nissan Maxima SV Sport/Tech
2007 Honda Shadow Spirit VT1100C
Re: Headlights [Re: rdevans89] #5462522 06/25/20 03:35 PM
B
BAJA_05 Offline
B
Two months ago I tried for the first time the 3M Heavy Duty Headlight Restoration Kit with clear coat. The kit was 23 plus tax and comes with 3 different grade sanding dics and another disc you wet and sand to finish before clear coating. I was happy with the results after a good hour of work at least. Now, lets just see how long it lasts overall. Been there done that with the different toothpastes,compounds,etc... Ordered this kit from Amazon.
2017 VW Jetta SE TSI 1.4L Turbo (hers)
PP Euro 0W40 & FU (48K)
2008 Acura TL 3.2L PPHM 0W20 & FU (117K)
2005 Subaru Baja AWD 2.5L N/A 5spd.
T6 MV 5W30 & FU (103K)
2000 Ram 4X4 5.2L (93K) T6 MV 5W30 & FU
Re: Headlights [Re: SatinSilver] #5467186 07/01/20 03:13 PM
R
Razorsharpe Offline
R
Just get one of the kits from Wal Mart. I have used 3M and Sylvania. Both worked well. Follow the directions carefully for the best results. Not difficult at all.
2015 Subaru WRX, 35K, AMSOIL Signature Series 0W-40
2002 Honda S2000, 50K, Castrol Edge 0W-40 A3/B4
2015 Mazda 6, 77K, Castrol Syntec Hi-Mileage 5W-30
2010 Honda Civic, 37K, Amsoil Sig Series 5W-30
Re: Headlights [Re: rdevans89] #5470144 07/05/20 01:18 PM
J
JLawrence08648 Offline
J
I've gone up to 7,000 grit. I bought a whole series of grits off eBay? Amazon?
I've also used a convertible top plastic window cleaner polish, worked well using a buffer.
2019 Hyundai Santa Fe SEL Plus, 2.4
1992 Acura Vigor GS, 2.5
