Forums Migration
Please read this thread
AAP Rotella Gas Truck Clearance
by Sam_Julier - 07/12/20 05:32 PM
Any 47RH Transmission Experts? CTD Ram
by JHZR2 - 07/12/20 04:58 PM
WM Magna1 10w30 gallon $5
by 2strokeNorthstar - 07/12/20 04:55 PM
I found a WWII movie for yinz to watch.
by JimPghPA - 07/12/20 04:45 PM
Jackpoint Jackstand Review
by RamFan - 07/12/20 03:03 PM
Lesabre Brake fluid capacity
by Ihatetochangeoil - 07/12/20 02:56 PM
Baking Cookies in the Car - 2.0
by Nick1994 - 07/12/20 02:17 PM
Dealer ruined my transmission!!!!
by John344 - 07/12/20 02:04 PM
Wax / Sealer Recommendations
by 92saturnsl2 - 07/12/20 01:45 PM
Horrible Duramax Aftermarket Filter Mod
by ToadU - 07/12/20 01:29 PM
Japan unveils timeline for indigenous fighter jet program
by gathermewool - 07/12/20 12:27 PM
NEW Rotella T6 15w40
by ToadU - 07/12/20 11:54 AM
2001 Silverado 1500 4x4 Alignment Concerns
by Blang - 07/12/20 11:37 AM
Full Synthetic for ATS V
by cadillactech - 07/12/20 11:33 AM
Gasoline engine oil in a diesel engine?
by LeslieX - 07/12/20 11:32 AM
Can I use IPA 70% to clean windshield?
by painfx - 07/12/20 09:47 AM
The Heat is on
by Snagglefoot - 07/12/20 07:39 AM
Working on your car
by CourierDriver - 07/12/20 07:35 AM
fxxkat, Ajreitano, Slick122, Ford4life76, Patrick_Hall1988
71916 Registered Users
93 registered members (53' Stude, 4.8 Silverado, 2004tdigls, A310, 2strokeNorthstar, 4WD, 11 invisible), 1,958 guests, and 27 spiders.
Topics307,769
Posts5,317,439
Members71,914
2009 Impala blend door actuator? #5455260 06/16/20 01:30 PM
R
ron350 Online Content OP
OP Online Content
R
I am looking for the best replacement blend door actuator motor for a 2009 Impala.
I replaced two blend door actuators on the car 4 years ago with new Delco’s #1574122 and now one of those has striped its gear. I checked both blend doors when I replaced the actuator’s and both doors turned freely.
Has any one found a replacement actuator that will last longer than a Delco?
ron350
Re: 2009 Impala blend door actuator? [Re: ron350] #5455261 06/16/20 01:33 PM
O
OilReport99 Offline
O
Dorman 604-108
2018 Ram 1500
Re: 2009 Impala blend door actuator? what did they use before they started using [Re: ron350] #5455275 06/16/20 01:57 PM
E
edwardh1 Offline
E
seems a lot of GM blend door issues
These products are all new every year?? They are a revolution!!! Razor blades, mens shirts, TVs, wiper blades, gutter guards, hearing aids... according to the ads. But also all new last year
Re: 2009 Impala blend door actuator? what did they use before they started using [Re: ron350] #5455445 06/16/20 05:41 PM
Dave9 Offline
The Dorman probably has a lifetime warranty, but otherwise it seems like all the aftermarket fail as quickly as the OEM do. Some people have luck opening them and rotating the gear past the stripped portion to reuse them.
Re: 2009 Impala blend door actuator? what did they use before they started using [Re: ron350] #5455462 06/16/20 05:57 PM
1
14Accent Offline
1
I highly doubt there's a difference, if the Delco ones are failing that quick just put in whatever is cheapest.
Funny, in 185k miles I only had to replace 2 actuators on my mom's old Impala: the recirc and the driver's blend. As far as GM's go, that car was amazingly reliable electrical-wise. I did have to replace the multi-function switch at about 150k to cure random hi-beam activation but that was it. Never a window regulator, door lock actuator, nothing.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
1980 Honda CB900C - 15k mile cream puff
Re: 2009 Impala blend door actuator? what did they use before they started using [Re: ron350] #5455554 06/16/20 08:05 PM
N
nwjones18 Offline
N
I can tell you that the Acdelco's in the 05 Cadillac I had were Denso's and looked exactly like the blend door motor in my wife's CRV design wise. I replaced all 4 in the Caddy (required removing the entire dash and carrier) and the temp motor in the CRV (easy access). I think they're just failure prone. Denso is usually the 'good stuff'
2016 Ram 1500 5.7 Hemi 30k QSUD 5w-20 Mopar filter
2008 Honda CRV 125K QSUD 5w-20 Fram ultra
2007 Mazda 3 2.3 130k 5w-30 syn-blend Denso filter
1988 F-150. 4.9 I6 251k. 10w-40 QSHM Motorcraft FL1A
Re: 2009 Impala blend door actuator? what did they use before they started using [Re: ron350] #5455601 06/16/20 08:55 PM
T
TheLawnRanger Offline
T
The Dormans have lasted about a year for me at the most on the one to the left of the glove compartment. I have an ac delco that I haven't put in. I unplugged the old one for the summer since I have no need to change to heat. The least one has lasted is a few days.
The more you change them the less time they last. I've even ordered the "tougher" gear from amazon to put into a new actuator. It lasted a week. I've learned that it won't click while running if you don't move to the coldest or hottest setting. However, it will click off and on all day and drain the battery.
2011 Impala
2012 Colorado
2018 Buick Encore
Oil: 5w30 synthetic
Re: 2009 Impala blend door actuator? what did they use before they started using [Re: ron350] #5455616 06/16/20 09:15 PM
N
nwjones18 Offline
N
On mine the gear isn't what failed, they had worn through the little conductive track that I assume is how they could tell what position they were in. This would cause them to chatter or get stuck and confused...
Re: 2009 Impala blend door actuator? what did they use before they started using [Re: ron350] #5455687 06/16/20 11:15 PM
J
john_pifer Online Content
Online Content
J
Garbage components from GM.
Blend door actuators, blower motor resistors, fuel pumps, water pumps, alternators, starters, power steering pumps...
That’s why I refuse to own one. I don’t want to get nickled & dimed to death.
07 Tacoma V6 - M1 EP 5W-30, Fram Ultra, 10K OCIs, 228K
18 Civic HB 1.5T 6MT (Wife's) - PPPP 10W-30, OEM filter
07 Yamaha R1 - Rotella T6 5W-40, Bosch 3300
07 Yamaha YZ-250, Klotz, Rotella
Re: 2009 Impala blend door actuator? what did they use before they started using [Re: ron350] #5455753 06/17/20 03:14 AM
G
GMBoy Offline
G
I won't use anything electrical from Dorman. Lock and hvac actuators fail the most with dorman.
Re: 2009 Impala blend door actuator? what did they use before they started using [Re: ron350] #5455759 06/17/20 04:08 AM
O
OilReport99 Offline
O
They all fail, but I’ve had better luck with Dorman than with AC Delco actuators.
2018 Ram 1500
Re: 2009 Impala blend door actuator? what did they use before they started using [Re: ron350] #5455794 06/17/20 06:02 AM
H
HemiBenny Offline
H
Ah yes, what we called the mating call of the Chevy Impala. On an early, cool morning at the auto auction, if you stop and listen closely, you'll hear it, Thump...........thump.........thump........thump. In response from another section of the lot you hear, thump ,thump, thump, thump...
2011 Ram 1500 5.7l
Shell RGT 5w20 / Fram TG2 oil filter
2015 Chrysler 200 2.4l multiar
Shell RGT 0w20 / Fram Ultra Guard XG10060
2016 Buick Encore 1.4l
Shell RGT 5w30 / Fram Extra guard CH10246
Re: 2009 Impala blend door actuator? what did they use before they started using [Re: john_pifer] #5455885 06/17/20 08:28 AM
M
MarkM66 Offline
M
Wheel bearings, timing chains.....
Re: 2009 Impala blend door actuator? what did they use before they started using [Re: ron350] #5455943 06/17/20 09:44 AM
R
OP Online Content
R
Thanks The LawnRanger that eliminates the gear sold on Amazon. It is sad that no one makes a metal replacement gear.
ron350
