Forums Migration
Please read this thread
DIY Injector cleaning - What cleaner?
by Spetz - 07/13/20 12:50 AM
Rock Auto promo code
by daves66nova - 07/12/20 11:09 PM
05 Dodge 4.7 L head gasket blown again
by vwmaniaman - 07/12/20 09:44 PM
How come every vehicle’s MPG computer is off?
by OppositeLocK - 07/12/20 09:37 PM
Glock Gen 5 .40 Caliber
by BlueOvalFitter - 07/12/20 08:34 PM
Help me determine if my CVT fluid has been changed
by Dallasmale1970 - 07/12/20 08:01 PM
Hyundais, Hyundais, Hyundais!
by csandste - 07/12/20 07:57 PM
Traveller's (WPP) $10.99 - 5 QT
by Gene K - 07/12/20 07:26 PM
PEAK 10X or Peak Global Lifetime
by pbm - 07/12/20 07:25 PM
Nio stock. How high will it go?
by motor_oil_madman - 07/12/20 05:34 PM
AAP Rotella Gas Truck Clearance
by Sam_Julier - 07/12/20 05:32 PM
Any 47RH Transmission Experts? CTD Ram
by JHZR2 - 07/12/20 04:58 PM
WM Magna1 10w30 gallon $5
by 2strokeNorthstar - 07/12/20 04:55 PM
I found a WWII movie for yinz to watch.
by JimPghPA - 07/12/20 04:45 PM
Jackpoint Jackstand Review
by RamFan - 07/12/20 03:03 PM
Lesabre Brake fluid capacity
by Ihatetochangeoil - 07/12/20 02:56 PM
Baking Cookies in the Car - 2.0
by Nick1994 - 07/12/20 02:17 PM
Dealer ruined my transmission!!!!
by John344 - 07/12/20 02:04 PM
Mark_C, fxxkat, Ajreitano, Slick122, Ford4life76
71917 Registered Users
48 registered members (Best F100, Bailes1992, Astro_Guy, 77GrandPrix, 87sammy, 5 invisible), 958 guests, and 27 spiders.
Topics307,781
Posts5,317,737
Members71,917
Trigger Polishing #5455136 06/16/20 11:09 AM
BlueOvalFitter Offline OP
Just recently I installed a Galloway trigger in my SD9. I had already installed an APEX spring kit in it about 2 years ago. That brought the trigger pull down to 5 lbs. from almost 7.5 lbs. Polishing the trigger bar, sear, and adding the new trigger brought the trigger pull down to 4.75 lbs. Not only is the trigger pull smooth as silk, it shoots a lot better, more accurate.
Next is my G21 and all of my M&P's. I didn't realize a polished trigger would work out so well. Had I known this I would have polished ALL of my gun triggers a long time ago.
2007 F150, XL, 4.2 V6
5W30 Amsoil Signature Series Oil
NAPA GOLD 1516 Oil Filter
Re: Trigger Polishing [Re: BlueOvalFitter] #5455145 06/16/20 11:15 AM
Astro14 Offline
I’ve polished the trigger (and associated sliding parts) on my Glocks.
No real change in weight, but much smoother and a more crisp break. Very worthwhile time spent.
I haven’t gone that deep into any of my S&W automatics (5906, 4006, 4506) but perhaps I should...
I installed a factory upgrade trigger in my Sig P227. It’s very nice.
I polished every part in my wife’s Walther CCP - virtually no difference.
C’est la vie...
32 Packard 15W40
01 Volvo V70 T5 0W30 AMSOIL SS
02 Volvo V70 T5 0W30 Edge
02 Volvo V70 XC 0W40 Edge
05 MB S600 0W40 M1
Re: Trigger Polishing [Re: BlueOvalFitter] #5455151 06/16/20 11:24 AM
K
Kawiguy454 Offline
K
There's also some videos on polishing the feed ramp into the barrel. May as well do while you're in there. When you look very closely you may see burrs and nicks that can be polished out to reduce possible jam.
Re: Trigger Polishing [Re: BlueOvalFitter] #5455200 06/16/20 12:11 PM
7
77Se7en Offline
7
Does that SD9 wear a manual safety?
Spiritual Intuitive / Whisperer-Medium (Involuntary & Non-Profit)
Valvoline ME, Mobil-1 EP & Pennzoil Ultra Platinum 5w30s
Re: Trigger Polishing [Re: 77Se7en] #5455273 06/16/20 01:51 PM
No it doesn't.
Re: Trigger Polishing [Re: BlueOvalFitter] #5455378 06/16/20 04:06 PM
ABN_CBT_ENGR Offline
Just be REAL CAREFUL
Trigger pull ( depending on specific model) is a relative arrangement between the contact angles ( and geometry), depth of contact (called length of pull in guns) surface finish ( referred to smoothness) and in some cases multiple included angles/dimensions from camming of parts.
polishing ( by definition a surface finish without removing mass) helps but make sure none of the other parameters change- it can creta a very dangerous situation.
Also, some weapons use soft metals or plating so polishing can create other issues too.
Just be careful and I recommend strongly using dychem and making a contact proof too. ( make sure there is always full engagement and no geometry change)
Re: Trigger Polishing [Re: ABN_CBT_ENGR] #5455408 06/16/20 04:53 PM
Thanks ACE.
Before l did any polishing to my SD9 trigger l watched BOO KOO videos on the subject. Everything you stated was explained in detail in some of the better videos. These are the ones l paid attention to more than the others. I also kept very detailed notes on every step of my polishing procedure.
Also, l was going to use FLITZ but instead l used TURTLE WAX heavy duty rubbing compound. I did a trial run on my Glock 5.5 lb. connector that l replaced with a ZEV 3.5 lb. connector. It come out with a mirror shine.
thumbsup
Re: Trigger Polishing [Re: BlueOvalFitter] #5455522 06/16/20 07:01 PM
If you really would like to learn this, here's the short method but guaranteed to produce quality safe results.
Read up on machine design and notching ( that's the sub field) to get geometry, throw, creep, contact pattern, engagement glide and so forth.
Buy a bench block, some drill rod and brass key stock in 1/2 and 1/4 ( soft enough to file easy for learning and big enough to see critical details and nuances without significant magnification but too soft for any hard locking)
If you don't do CAD or drafting, Visio works very well- center distances and notch angles ( along with run) and the arc are the critical parts to define.
Learn the fit and geometry first then drill holes and measure the function of the notch ( copy a gun part- just oversize)
Learn big then you can do small easily.
Pretty soon you can modify any trigger on any gun ( within reason) and do it safely.
Re: Trigger Polishing [Re: ABN_CBT_ENGR] #5455735 06/17/20 12:48 AM
Thank you Sir. I will definitely read up on it.
Re: Trigger Polishing [Re: BlueOvalFitter] #5455923 06/17/20 09:16 AM
B
bulwnkl Offline
B
Excellent input from A_C_E. Glad to see you’re taking the time to learn about this stuff, BlueOval, rather than just breaking out the Dremel (DO NOT EVER use a Dremel on a trigger or fire control).
I use speech recognition frequently. Please excuse any consequent grammatical or typographical errors.
Re: Trigger Polishing [Re: BlueOvalFitter] #5455950 06/17/20 10:05 AM
F
Fattylocks Offline
F
I did trigger work on my Mini-14.
Studied the group under my 10x loupe.
Saw tool marks.
Went at them very delicately with the appropriate pattern file. Finished off with a 1/4' hard Arkansas stone.
Results? Golden. Pull weight didn't seem to change much but a much cleaner, crisper break.
94 Caprice Wagon Daily driver sold
05 Focus Wagon 2.0 Duratech city car sold
05 Mustang GT Convertible sold
05 P71 ex Homeland Security
12 Ford Explorer XLT Base
11 Nissan Titan SV King cab 4x4
Re: Trigger Polishing [Re: BlueOvalFitter] #5456163 06/17/20 03:03 PM
7
77Se7en Offline
7
You arren't carrying it in your pocket.... are you? The SD9 pics look like it's a little too large for pockets.
Re: Trigger Polishing [Re: bulwnkl] #5456241 06/17/20 04:37 PM
Actually you can ( but don't use it freehand, no human being can hold it properly)
My "proof of concept' was a locked Dremel with a cross slide vise- the "Dremel" worked but the weak spot was those stones available simply cannot be properly trued and balanced to do that level of precision work.
We would up using Norton stones for the tool sharpener on a tapered bng shaft with 0.000 backlash. ( basically made a scaled down precision surface grinder)
The design is for small pump/hydraulic components but it will do sears
My strongest recommendation is to not attempt freehand stuff (Yeah I know there are people who can hand grind tooling almost perfectly but they are the exception, not the rule and nobody is likely to get killed from a improperly worked "hair lathe tool")
Use jigs, proper measuring tools, dychem and good optics
Re: Trigger Polishing [Re: BlueOvalFitter] #5456414 06/17/20 08:52 PM
B
bulwnkl Offline
B
I agree that one _can_ use a power tool, but only in theory when talking about a Dremel-type. You cited good reasons why one should NEVER use a Dremel on a trigger or fire control, even clamped in a fixture. (-: Too, it's far too easy for the average joe (and many I've met who claim to be gunsmiths) to overheat a part with a dremel due to its high speed, and wreck heat treatment.* That may not be pertinent, but sometimes it is.
*This _shouldn't_ ever be an issue with trigger parts, since there should not be a call for removing that much material unless there was an egregious manufacturing error. However, I've seen people do things just this dumb.
Re: Trigger Polishing [Re: bulwnkl] #5456683 06/18/20 08:32 AM
I'm so glad you said that- I see you have been there too once or twice
I have to "fix" previous jobs all too much
I almost exclusively wet grind so that's not an issue on my end but on many modern guns they have a soft stamping that's been either plated or just surface hardened. People mess that up then it has all the structural strength of machining wax- those are the dangerous ones
