Forums Migration
Please read this thread
Silver Windshield Sun Shades
by rrretiree7 - 07/08/20 02:04 AM
Castrol Edge PIck-Up
by Gene K - 07/08/20 01:51 AM
Safety kleen seals.
by Chris142 - 07/07/20 10:58 PM
I do a full detail everything 2 or 3 years.
by SLO_Town - 07/07/20 09:59 PM
Oil Recommendation 2020 GR Supra
by afree - 07/07/20 09:51 PM
I need to drive it more...
by SLO_Town - 07/07/20 09:43 PM
Pennzoil
by BlueOvalFitter - 07/07/20 09:07 PM
100k 06 Fusion 2.3
by Aichiguy - 07/07/20 08:13 PM
CHINA
by buster - 07/07/20 07:52 PM
Darker varnish spot on rocker arm
by Spetz - 07/07/20 07:29 PM
AC Delco Dexron VI $18.76 a Gallon Amazon
by Matt1980 - 07/07/20 07:17 PM
ALS labs change in fuel dilution test
by LotI - 07/07/20 06:50 PM
Archery high tech
by CourierDriver - 07/07/20 06:42 PM
Odd filter issue
by fatrap314 - 07/07/20 06:33 PM
Lexus IS 350 AWD 2016 0W-20
by hotp4nts182 - 07/07/20 06:14 PM
Duh-- Didn't know there was a SIM card.
by csandste - 07/07/20 03:54 PM
Running 40 PSI vs 35
by Mr_Luke - 07/07/20 03:05 PM
Kidney Filtration-Secondary Effects???
by TravlinTech - 07/07/20 02:41 PM
fatrap314, hotp4nts182, LeslieX, Mayuraj, thexeve
71876 Registered Users
21 registered members (ChristianBerg, DaHen, Ctopher, 07hemi, 4 invisible), 807 guests, and 24 spiders.
Topics307,583
Posts5,313,562
Members71,876
Page 1 of 3 1 2 3
Ranger fails to restart after hard braking #5455129 06/16/20 10:58 AM
B
brages Offline OP
B
Vehicle: 1997 Ford Ranger, 2.3L "Lima", manual transmission. 265k miles, no CEL, runs fine.
My son has had two incidents driving this truck. Both times, he stopped suddenly when a light turned yellow in order not to run the red. The engine died (my guess is that it died because he was braking hard and left it in gear, but I do not know). The truck then failed to restart. It will crank and crank but not show signs of beginning to start.
The first time this happened, I tried a bunch of stuff and after I switched the fuses between the headlights and the fuel pump, it started running and ran fine. The fuse wasn't blown, though, so I think it was just random that it started working.
The second time this happened, I tried fiddling with the fuses, fuel pump relay, and inertia switch. I jumpered the inertia switch connector to bypass it. Still no start. So I would rule out fuses, relays, and the inertia switch.
I pressed on the schrader valve to check fuel pressure. Fuel pressure was low. Then I had my son turn the key on. A little more fuel dribbled out for a couple of seconds then stopped. Off then on, a little more. Tried it again, a geyser of fuel shot out. Then, after that, the truck ran fine again.
A clue: this truck has quirk where if has been sitting for a few minutes or more, when you try to start it, it revs up for a couple seconds, then dies. On your second try, it will start normally. Or if you turn the key on for a couple of seconds before starting, it will start just fine. So there is *something* suspect in the fuel delivery.
I have replaced the fuel pump, fuel filter, and and fuel injectors in this truck. None of these had an effect on the starts-then-dies problem (I was hoping they would).
The second time this happened, the tank was about 1/4 full. I don't remember how full it was when this happened the first time. Both incidents happened in the same area, maybe 3-4 miles away from our house, after leaving our house. So the truck was mostly warmed up, but hadn't been driven long when it happened.
I'm telling him just to go through on the yellow, but I'd like to get this fixed, lol.
Re: Ranger fails to restart after hard braking [Re: brages] #5455131 06/16/20 11:01 AM
B
brages Offline OP
B
After this happened the first time, I figured it was just something flaky with the inertia switch. But the second time, I ruled out the inertia switch.
My new theory is that the hard braking with 1/4 tank caused the pump to suck air briefly, and for some reason (a leak somewhere?) it had a very hard time re-priming itself afterwards.
Also I am thinking about replacing the fuel regulator because i suppose it could be the reason the fuel pressure apparently drops when the truck is turned off.
Re: Ranger fails to restart after hard braking [Re: brages] #5455133 06/16/20 11:04 AM
R
ragtoplvr Offline
R
Your fuel pump is failing. Under hard break with tank near empty it get s uncovered and sucks air. then when you restart it is bound up and will not start.
Test, see if this happens with a full tank. Lots of bad things happen when you drive on the last 1/4 tank.
Rod
Re: Ranger fails to restart after hard braking [Re: brages] #5455135 06/16/20 11:09 AM
K
Kira Offline
K
I do not know your engine/vehicle one bit.
Is it the case that your FPR has a vacuum line on it?
If so pull it off and if there's fuel in the vacuum line the FPR is bad.
I've read that on boards.
edit: A list of bad things which can happen due to driving at or below 1/4 tank would be a smart thing to make.
All I've heard of is that there may be less fuel to cool the pump.
With today's ethanoled gas there's no collection of crud at the bottom of the tank (I have heard).
What else can be bad?
A big slosh of gas can break a cheap baffle free?
Re: Ranger fails to restart after hard braking [Re: brages] #5455137 06/16/20 11:11 AM
B
brages Offline OP
B
No fuel in the vacuum line for FPR and it seems to work correctly with a fuel pressure gauge attached.
Re: Ranger fails to restart after hard braking [Re: brages] #5455142 06/16/20 11:14 AM
Dave9 Offline
^ Meh, every single tank of gas, I drive below 1/4 tank, including on a '98 Explorer which probably has the exact same factory pump, but not necessarily the same tank.
I am going to assume your son is not an idiot ( wink ) and took it out of gear to try to start it. Pressing on the fuel rail valve is only the start, more definitive would be to check the pressure. If I remember that era correctly, it probably uses a return (to tank) fuel system with a lower pressure than modern vehicles, around 35PSI.
The question is whether the replacement pump is working properly. If so, still check fuel pressure at the rail, it could be the pressure regulator. If (as above) I recall this generation correctly, the regulator is on the fuel rail at the return line portion, not built into the sending unit in the tank. I could be wrong. shrug
Re: Ranger fails to restart after hard braking [Re: ragtoplvr] #5455143 06/16/20 11:15 AM
B
brages Offline OP
B
Rod
That is an interesting idea. You think that when it sucks air, it immediately overheats and seizes, then after it cools off a bit, it starts running OK?
I'm planning on pulling the bed off for some frame rust work (sigh), so that might be a good time to experiment with making the fuel pump run dry.
Re: Ranger fails to restart after hard braking [Re: Dave9] #5455146 06/16/20 11:17 AM
B
brages Offline OP
B
I am going to assume your son is not an idiot ( wink ) and took it out of gear to try to start it. Pressing on the fuel rail valve is only the start, more definitive would be to check the pressure. If I remember that era correctly, it probably uses and return fuel system with a lower pressure than modern vehicles, around 35PSI.
Your memory is mostly correct. I think the pressure is closer to 40.
Both times when this happened, my son called me and I got it started after messing around with different stuff for 15-30 minutes or so.
Re: Ranger fails to restart after hard braking [Re: brages] #5455147 06/16/20 11:18 AM
Dave9 Offline
A new pump especially, should not have any problem from a brief moment of sucking air, and at 1/4 tank, it isn't all that likely that merely coming to a stop would cause air instead of fuel. Steep slope stop maybe, but not on fairly flat ground.
Re: Ranger fails to restart after hard braking [Re: brages] #5455149 06/16/20 11:20 AM
B
brages Offline OP
B
One problem I have is that I have not duplicated this issue. I don't really want to get stuck away from home in a dead truck and I don't want to be slamming on my brakes in the neighborhood. But I suppose if I can figure out how to reproduce the problem, it will help figure it out.
Re: Ranger fails to restart after hard braking [Re: brages] #5455162 06/16/20 11:35 AM
R
ragtoplvr Offline
R
Too bad Click and Clack no longer perform. RIP Tom. This would make a fun "stump the chump".
Rod
Re: Ranger fails to restart after hard braking [Re: brages] #5455194 06/16/20 12:03 PM
I
irad Offline
I
I think it is a fuel cutoff momentum switch. Something similar happened to my mother's Grand Marquis. I drove thirty miles to her disabled car, reached in the trunk, reset the red switch and told her to drive to her house.
Re: Ranger fails to restart after hard braking [Re: brages] #5455204 06/16/20 12:17 PM
T
thastinger Offline
T
Think your fuel pump "impact" reset switch is under the carpet on the passenger side, up high on the firewall, this would be my main suspect.
Re: Ranger fails to restart after hard braking [Re: ragtoplvr] #5455205 06/16/20 12:19 PM
B
brages Offline OP
B
Rod
Yeah, I loved that show and grew up listening to it as a kid. As I learned more about cars, I started disagreeing with their diagnoses more frequently, LOL
Re: Ranger fails to restart after hard braking [Re: thastinger] #5455208 06/16/20 12:22 PM
B
brages Offline OP
B
That is what I was thinking after the first time, but there are several reasons I think it is not the inertia switch:
1. The first time it happened, the truck began running again without the inertia switch being reset.
2. The second time it happened, I tried to reset the inertia switch and it wasn't tripped.
3. The second time it happened, I manually tripped then reset the inertia switch and it didn't fix it.
4. The second time it happened I bypassed the inertia switch with a jumper wire and it didn't fix it.
Page 1 of 3 1 2 3
