Forums Migration
Please read this thread
HF JACK-STAND RECALL EXPANDED
by demarpaint - 07/07/20 08:15 AM
Five Euro Car Myths?
by BMWTurboDzl - 07/07/20 07:46 AM
Trust Funds
by stockrex - 07/07/20 07:28 AM
3 on the tree
by Chris142 - 07/07/20 07:21 AM
ROCKAUTO selling old expired stock.
by nicholas - 07/07/20 07:21 AM
Amsoil SS 5w30
by mpgo4th - 07/07/20 06:57 AM
Water/Coolant Contamination?
by nastyc5 - 07/07/20 06:53 AM
07 Tahoe trans fluid change.
by Anthony - 07/07/20 06:06 AM
Ravenol 15W40 Marine
by Realfine69 - 07/07/20 05:10 AM
2020 VW 0W20??
by Realfine69 - 07/07/20 05:06 AM
Who makes the O'reillys trans filters ??
by GMguy84 - 07/07/20 05:00 AM
[Seattle Craigslist] Cheap Pennzoil 5w20
by SlavaB - 07/07/20 02:14 AM
Best Synthetic Oil For Cleaning
by BlueOvalFitter - 07/06/20 11:18 PM
Make your predictions for 20 years from now...
by sloinker - 07/06/20 10:47 PM
Getting rid of carbon in exhaust ports?
by Spetz - 07/06/20 10:15 PM
Rotella Gas Truck 0W-20 VOA
by HDoilDude - 07/06/20 09:57 PM
Two Mobil 1 M1-110A filters. Different sizes
by Dallasmale1970 - 07/06/20 09:46 PM
BITOG forums migrating to Xenforo soon
by wwillson - 07/06/20 09:41 PM
Carburetors - I think I've learned to like them
by Kurtatron - 07/06/20 09:40 PM
JDMorgan, sycboi, Chuck_Ellison, BakonBittz, ssoH
71870 Registered Users
89 registered members (4WD, 86cutlass307, aba4430, ABN_CBT_ENGR, 77GrandPrix, 2015_PSD, 6 invisible), 1,579 guests, and 29 spiders.
Topics307,541
Posts5,312,722
Members71,870
Supertech SAE 30 Oil Any Good? #5454939 06/16/20 06:09 AM
M
MJ_Massey Offline OP
M
Hello,
I found this oil at my oval Walmart and never seen it before - not sure if I’ve just missed it or it’s new/repackaged. Anyhow, I use a straight 30 in my Kohler K series and Onan garden tractors and wondering how well this would work. I’m currently using John Deere Torq-Guard SAE 30 and like it.
The 5 litre jug is labelled Diesel Engine Oil SAE 30 with API service CF-2/SG. The Kohler manual says go with an SAE 30 with an SG rating so this will definitely fit the bill. Is anyone using this oil? Any thoughts on this stuff and if it’s any good? I’d switch over to it as it is quite a bit cheaper and I perform oil changes often.
Thanks
Re: Supertech SAE 30 Oil Any Good? [Re: MJ_Massey] #5454941 06/16/20 06:15 AM
caprice_2nv Offline
Originally Posted by MJ_Massey
Hello,
Thanks
I bought this in the 18.9L barrel, thinking maybe I'd use it in all 3 vehicles in the hot summer months, but the lack of specs of information I could find on it led me to use it only as a very inexpensive flush oil....so I could leave the high quality oil filter on a second go, without leaving any old oil in the engine. Drain, then put about 4qts back in, run for a half a minute and drain again. Then put my quality synthetic in.
Maybe if it had been an sn rated sae 30 or something, but I couldn't find anything here about it. I did actually leave it in the Caprice and it's running fine on it. I'll change it when the temperature starts to drop.
84 Olds Cutlass - 350 Olds
83 Chevy Caprice - 305 Sbc
05 Silverado 1500 4wd - 4.8/4L60E
79 Honda CX500
Re: Supertech SAE 30 Oil Any Good? [Re: MJ_Massey] #5454945 06/16/20 06:21 AM
doolah02 Offline
It's a decent oil for the price, I bought a 15W40 1 gal jug yesterday at Wal-mart for $9.97.
Mobil Delvac Super 1300 was 10.97. Super Tech is just as good in my opinion.
Re: Supertech SAE 30 Oil Any Good? [Re: doolah02] #5454953 06/16/20 06:46 AM
4WD Online Confused
Online Confused
Might want to compare the list of builder approvals, which one is factory fill on the DMax, and which one is in CAT drums.
Re: Supertech SAE 30 Oil Any Good? [Re: 4WD] #5454954 06/16/20 06:48 AM
caprice_2nv Offline
Also that 15w40 maybe the sn rated not SG. This SG CF 30 weight meets the spec of my 1983 Caprice and 76 Olds 350 but not many modern engines. The bottle even warns that it may not protect any vehicle newer than 1996 against wear and sludge or something along those lines.
79 Honda CX500
Re: Supertech SAE 30 Oil Any Good? [Re: caprice_2nv] #5454958 06/16/20 06:52 AM
4WD Online Confused
Online Confused
I was buying SuperTech SAE-HD30 for misc things … it’s actually SN Plus … but appears to be going away.
Seemed like a great product but must have been a slow mover.
Re: Supertech SAE 30 Oil Any Good? [Re: MJ_Massey] #5454969 06/16/20 07:04 AM
Chris142 Online Content
Online Content
That oil is designed with the old 2 stroke Detroit Diesels in mind.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Supertech SAE 30 Oil Any Good? [Re: caprice_2nv] #5454972 06/16/20 07:08 AM
M
M
Good to know. Yes, the bottle does say “Warning: not suitable for use in gasoline engine built after 1993. May not provide adequate protection against build-up if engine sludge, oxidation, or wear.”
Sounds like you are located in Ontario as well?
Re: Supertech SAE 30 Oil Any Good? [Re: Chris142] #5454973 06/16/20 07:11 AM
4WD Online Confused
Online Confused
Re: Supertech SAE 30 Oil Any Good? [Re: Chris142] #5455013 06/16/20 08:09 AM
CT8 Offline
DD 2 strokes use a 40 wt.
2015 F150 2.7
2018 F350 6.2
Re: Supertech SAE 30 Oil Any Good? [Re: MJ_Massey] #5455026 06/16/20 08:30 AM
K
kschachn Online Content
Online Content
K
That is because it is API SG and SG is an obsolete license.
You can find better, something that is a monograde but API SN or even SN PLUS.
1994 BMW 530i, 253K
1996 Honda Accord, 289K
1999 Toyota Sienna, 437K
2000 Toyota ECHO, 290K
Re: Supertech SAE 30 Oil Any Good? [Re: MJ_Massey] #5455138 06/16/20 11:12 AM
N
Normac Offline
N
My local Walmart has SuperTech 30-wt that isn’t diesel rated in the OPE section, but I didn’t look to see what the specs were. Next time I’m there, I’ll investigate further.
True victory does not come from defeating an enemy, true victory comes from giving love and changing an enemies heart.
Re: Supertech SAE 30 Oil Any Good? [Re: MJ_Massey] #5455288 06/16/20 02:13 PM
chainblu Offline
I would absolutely use it in my OPE with complete confidence.
Re: Supertech SAE 30 Oil Any Good? [Re: MJ_Massey] #5455371 06/16/20 03:52 PM
caprice_2nv Offline
Yes, Kingston Ontario. I was looking for information on this stuff a couple weeks ago after I bought it at Walmart. I'd probably trust the sn plus stuff a lot more, since it actually has to meet modern specs.
79 Honda CX500
Re: Supertech SAE 30 Oil Any Good? [Re: MJ_Massey] #5455470 06/16/20 06:08 PM
B
bchannell Offline
B
I'd be ok with it in any OPE. Older specs are normally higher ZDDP etc
