Planes fly over white house after speech
by 1978elcamino - 07/04/20 10:16 PM
Code reader advice
by 53' Stude - 07/04/20 10:05 PM
People driving less / motor oil prices?
by 1978elcamino - 07/04/20 10:02 PM
Fireworks and dogs
by 555 - 07/04/20 07:52 PM
Cannot unscrew oil filter housing cap - BMW E46
by 97tbird - 07/04/20 07:21 PM
Are u a big fireworks person?
by ZZman - 07/04/20 06:53 PM
Honda Accord MAP sensor question
by Kira - 07/04/20 06:28 PM
Hy-Gard Shelf Life (Opened Bottle)
by viscous - 07/04/20 06:10 PM
Want to bet on my luck? (atf to "save" transmission)
by Snoman002 - 07/04/20 06:10 PM
Too Much Zinc = Corrosion?
by viscous - 07/04/20 06:00 PM
New vehicles with a 4 speed transmission?
by MrHorspwer - 07/04/20 04:57 PM
Inability to Choose
by Gene K - 07/04/20 01:53 PM
65 200 6 mustang running kinda hot
by old1 - 07/04/20 01:30 PM
Neo-protec GT em
by dervdave - 07/04/20 01:19 PM
Mannol 9929 Ester additive
by dervdave - 07/04/20 01:14 PM
2015 Corolla with 7k miles has “soft brakes”
by NHBFAN - 07/04/20 12:30 PM
Put Bilsteins on the Silverado
by bdcardinal - 07/04/20 12:19 PM
SilentC, paolo9fla, SunnyB, Mullady76, Axia2
71848 Registered Users
21 registered members (bernardch, bbhero, edyvw, dishdude, 77GrandPrix, Avery4, 2 invisible), 768 guests, and 26 spiders.
Topics307,436
Posts5,311,045
Members71,848
Minimum coolant for corrosion protection? #5454894 06/16/20 02:01 AM
A
Avery4 Online Content OP
OP Online Content
A
Hello everyone, I am wondering what the minimum percentage of coolant required for effective corrosion protection is. I live in the south and good cooling is much more important here than freeze protection since it hardly ever gets below freezing and I park my car in my garage overnight, so I really don’t need any freeze protection. What would be the minimum amount of coolant that could be used while still providing effective corrosion protection? Thanks in advance!
Re: Minimum coolant for corrosion protection? [Re: Avery4] #5454896 06/16/20 02:05 AM
Char Baby Offline
They work hank-in-hand. If you raise one, you raise the other and visa-versa.
Retired 6 yrs now & lovin' it
'15 Nissan Altima 2.5 SV
'15 Honda Civic 1.8 LX
Re: Minimum coolant for corrosion protection? [Re: Char Baby] #5454902 06/16/20 03:06 AM
Char Baby Offline
What I mean is; a stronger concentration of coolant/antifreeze benefits both the cooling ability as well as the overheating ability. A weaker concentration lessens both as well.
That's why a 50/50 mix of coolant and distilled water is a good starting place. If you live where the outside temperatures are at the extremes then you may want to move to a 60 coolant/40 water mix. This will aid in both cooling & overheating. I have heard of people going to a 70/30 mix in e.g., Death Valley, CA or The Twin Cities, MN
Re: Minimum coolant for corrosion protection? [Re: Avery4] #5454934 06/16/20 05:56 AM
SpitFire6 Offline
Hi,
If freeze protection is not a concern & you want maximum cooling efficiency, water is the best. Water alone will provide zero corrosion protection.
In the summer I have run water with corrosion inhibitor added. I think the brand I used was recommended at 2% dilution so 1 litre lasts a long time.
Cheers,
Iain.
PS.
https://www.morrislubricantsonline.co.uk/ankorsol-anti-corrosion-fluid.html
2002 206 CC 2L 4Cyl. 0W40 FS
1972 Spit 2L5 6Cyl. 0W40 FS
Re: Minimum coolant for corrosion protection? [Re: Avery4] #5455005 06/16/20 07:59 AM
P
pbm Offline
P
In most North American climates a 50/50 mix of coolant and water will suffice. In extreme cold a 60/40 will insure
not freezing up if it goes below -34*F. In climates that never see freezing temps a 40/60 might cool a bit better
because of the additional water content. In any case I wouldn't go below 40/60 or above 70/30....IIRC the coolant
manufacturers even recommend this....
'Journalism is Dead'
Re: Minimum coolant for corrosion protection? [Re: Avery4] #5455007 06/16/20 08:04 AM
T
thastinger Offline
T
With DISTILLED water, 90/10
Re: Minimum coolant for corrosion protection? [Re: Avery4] #5455009 06/16/20 08:06 AM
DriveHard Offline
My understanding is pure water cools the best...next best alternative is to use Water Wetter and no "antifreeze" at all. Water Wetter is supposed to have the corrosion protection you need.
https://www.redlineoil.com/waterwetter
Smile, it increases your face value
2013 Fiat 500 Abarth mod heavy (my DD)
2018 Alfa Romeo Stelvio TI Sport (wife's)
2011 Silverado Crew Cab LT 6.2L/6spd (tow pig)
2007 Nissan Xterra (trail toy)
Re: Minimum coolant for corrosion protection? [Re: Avery4] #5455016 06/16/20 08:16 AM
Davejam Offline
Generally the recommendation is absolutely not to go below 30%coolant. Because below that boiling point is significantly reduced and corrosion risk is increased.
So, shooting for 40% coolant in hot weather climates is perfectly safe.
If you really want to push it, 30-40% range is likely safe.
If we're talking high elevation or some very specific situation you may want to proceed with more caution as boiling can become a bigger concern.
Re: Minimum coolant for corrosion protection? [Re: Avery4] #5455031 06/16/20 08:37 AM
Snagglefoot Offline
Corrosion Protection is important. Trying to skimp on it will come to light if you ever have to pay to have a heater core replaced. Also, as stated, the boiling point is raised with concentration.
If you want the job done right......do it yourself.
Re: Minimum coolant for corrosion protection? [Re: Avery4] #5455039 06/16/20 08:41 AM
K
kschachn Offline
K
Do not use water with water wetter or another additive. Use the coolant recommended by the manufacturer for your vehicle, and at least the minimum concentration stated on the container or in the owner's manual. There is zero reason to use water with the wetter additive in this application. Do not go below the concentration the manufacturer specifies.
1994 BMW 530i, 253K
1996 Honda Accord, 289K
1999 Toyota Sienna, 437K
2000 Toyota ECHO, 290K
Re: Minimum coolant for corrosion protection? [Re: Avery4] #5455191 06/16/20 12:02 PM
K
Kawiguy454 Offline
K
I will never touch water wetter again. Google "Brown Gunk" and find that as the product breaks down it turns into a brown greasy gunk that hangs around even after flushes. I know because i did it.
That said If heat is an issue your thermostat will have more to do with heat in the engine that the coolant you use to remove it. 20-30% coolant is good enough IMO.
Re: Minimum coolant for corrosion protection? [Re: kschachn] #5455229 06/16/20 12:44 PM
G
Gebo Offline
G
+1
'98 LEX LS400 310K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 75K
Shell Gas and Truck 5w-30
Amsoil OE 10w-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: Minimum coolant for corrosion protection? [Re: Char Baby] #5455265 06/16/20 01:35 PM
A
OP Online Content
A
Actually plain water is the best coolant, antifreeze decreases its heat transfer ability. From a cooling standpoint, the only benefit to using a coolant mix instead of water is a higher boiling point. However, in a modern car with a pressurized system, this isn't as critical as it used to be back in the days of unpressurized cooling systems. For example, I have a 19 PSI radiator cap, which raises the boiling point of plain water to about 258 degrees. Adding 50% coolant would increase the boiling point by about 15 degrees to around 273 degrees. However, the reality is the coolant should never get anywhere near either of those temps. And if it does get that hot and the driver doesn't take action, they are taking a serious risk of destroying the engine regardless of what the cooling system is filled with. Despite what Evans waterless coolant says, just because the coolant can handle the heat without boiling doesn't mean that the engine can.
Re: Minimum coolant for corrosion protection? [Re: Avery4] #5455303 06/16/20 02:35 PM
Davejam Offline
Just to expand on what I said earlier...and perhaps some clarification
You will get corrosion protection to as low as 10% coolant.
But not enough for the product to be guaranteed to X miles/years, or even to provide the same corrosion protection needed for shorter intervals.
I don't think there is much information out there on this as they really don't want you to venture that far from 50/50.
And the improvement in heat transfer from small changes in concentration are not significant really.
So, again 40/60 is safe. And most concentrates will provide information on that.
I wouldn't feel that concerned about 35-40%, but would start to worry below that.
Re: Minimum coolant for corrosion protection? [Re: Avery4] #5455669 06/16/20 10:48 PM
F
FordCapriDriver Offline
F
Febi-Bilstein indicate on their coolant bottles that 30% Coolant - 70% Water is the minimum for appropriate corrosion protection.
Here in Spain though most Auto Parts Stores sell 10% , 30% and 50% Premix.
I work at one and the 50% hardly sells, 30% a little more, 10% by far the most popular.... people seem to think that because it only drops below freezing at night for a few weeks in Jan-Feb that they can just run water or cheap horrible green Phosphate-Borate IAT coolant in a modern car...
1975 Ford Capri II Ghia 3000 V6 - 315k, Repsol Elite Super 20W-50
1988 Ford Escort XR3i Cabrio - 110k, Valvoline Maxlife 10W-40
