My car was pulling to the left after a wheel alignment.
I took it back to the alignment shop and the guy said to swap the 2 front tires left to right.
I did so and now it pulls a bit to the right.
So it suggests the tires were causing this.
I have checked the tires, they look fine and tread depth as well as pressure is the same.
What about the tires could be causing this pull?
Tires are 6 year old Pirelli P7s with good tread amount remaining.
