Planes fly over white house after speech
by 1978elcamino - 07/04/20 10:16 PM
Code reader advice
by 53' Stude - 07/04/20 10:05 PM
People driving less / motor oil prices?
by 1978elcamino - 07/04/20 10:02 PM
Fireworks and dogs
by 555 - 07/04/20 07:52 PM
Cannot unscrew oil filter housing cap - BMW E46
by 97tbird - 07/04/20 07:21 PM
Are u a big fireworks person?
by ZZman - 07/04/20 06:53 PM
Honda Accord MAP sensor question
by Kira - 07/04/20 06:28 PM
Hy-Gard Shelf Life (Opened Bottle)
by viscous - 07/04/20 06:10 PM
Want to bet on my luck? (atf to "save" transmission)
by Snoman002 - 07/04/20 06:10 PM
Too Much Zinc = Corrosion?
by viscous - 07/04/20 06:00 PM
New vehicles with a 4 speed transmission?
by MrHorspwer - 07/04/20 04:57 PM
Inability to Choose
by Gene K - 07/04/20 01:53 PM
65 200 6 mustang running kinda hot
by old1 - 07/04/20 01:30 PM
Neo-protec GT em
by dervdave - 07/04/20 01:19 PM
Mannol 9929 Ester additive
by dervdave - 07/04/20 01:14 PM
2015 Corolla with 7k miles has “soft brakes”
by NHBFAN - 07/04/20 12:30 PM
Put Bilsteins on the Silverado
by bdcardinal - 07/04/20 12:19 PM
SilentC, paolo9fla, SunnyB, Mullady76, Axia2
71848 Registered Users
47 registered members (Bfrost99, Alaskanmont, Alex38, bdcardinal, ABerns, 3 invisible), 877 guests, and 24 spiders.
Topics307,436
Posts5,311,032
Members71,848
Mike L trans cooler on gas engine #5454866 06/15/20 11:14 PM
R
Redright9 Offline OP
R
Hello, I would like to upgrade my transmission cooler in my '03 GMC 1500HD.. It has the 6.0L with the 4L80E trans.. I put an aftermarket one in that is a little larger but not fully satisfied with its performance. It has done better than stock, but still want something better. It seems the best cooler is the "Mike L" cooler, but it is for the diesels. I have asked may people and trans shops if it would work with the gas engine trucks, but everyone says they dont know.. So I am going to ask here. Anyone use a Mike L cooler? does anyone know if it would work on a gas truck?
Re: Mike L trans cooler on gas engine [Re: Redright9] #5454873 06/15/20 11:43 PM
clinebarger Online Content
Online Content
Allison 1000's have 1/2" cooler lines opposed to 3/8" on your 4L80E. I usually use a Trucool LDP 20K on trucks like yours & Setrab on higher end stuff.
2001 Chevy Camaro L92/4L80E
Re: Mike L trans cooler on gas engine [Re: Redright9] #5454907 06/16/20 03:57 AM
K
KneeGrinder Offline
K
You could call Mike and ask him, he answers his phone (714) 870-7300
I put a Ford 6.0L cooler in my Ford 7.3L, same deal, 7.3L was 3/8", I used brass adapters 3/8" to 1/2" no leaks for 15 years. The 6.0L cooler is huge!
08 Tribeca 90k PUP 5w30
06 Accord 137k PP 0w20
03 Acura CL-S 90k M1 AP 5W20
02 Acura TL-S 241k ST 5W30
02 Accord EX 155k PP 0W20
02 K3500 99k M 1 ESP 5w40
00 F350 139k M 1300 15w40
Re: Mike L trans cooler on gas engine [Re: KneeGrinder] #5454910 06/16/20 04:08 AM
R
R
I did call a while ago, I was told "I don't know, sorry"... I didnt feel like buying one to look and see..
Re: Mike L trans cooler on gas engine [Re: Redright9] #5454977 06/16/20 07:24 AM
T
thastinger Offline
T
Your main concern would be whether the gas and diesel trucks have the same mounting points for the cooler, other than that, you may have to buy some line adapters etc.
Re: Mike L trans cooler on gas engine [Re: Redright9] #5455086 06/16/20 09:58 AM
ls1mike Offline
I put a Tru Cool 40k on my 2500HD. I will send you photos when I get home. The install should be almost identical.
Just tooling around temps were 100 to 130. Towing 7800 lbs in 95 to 100 degree heat up long grades I never saw over 180
Mike
00 Trans Am WS6 5.7 LS1
17 Silverado 3500HD 6.0
14 Caprice PPV 6.0
15 Malibu LTZ Turbo
12 Passport TT
Re: Mike L trans cooler on gas engine [Re: Redright9] #5455483 06/16/20 06:23 PM
ls1mike Offline
I found them.
This is in my old 02 2500HD, should be almost identical to your truck. I was really happy with it.
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
Mike
14 Caprice PPV 6.0
15 Malibu LTZ Turbo
12 Passport TT
Re: Mike L trans cooler on gas engine [Re: Redright9] #5455526 06/16/20 07:04 PM
ls1mike Offline
I know that doesn't answer your question, but the trucool works really well with the 6.0, lots of people use it.
What makes you not satisfied with the cooler you have now?
Mike
14 Caprice PPV 6.0
15 Malibu LTZ Turbo
12 Passport TT
Re: Mike L trans cooler on gas engine [Re: Redright9] #5455583 06/16/20 08:34 PM
P10crew Offline
Your not plumbing it through the radiator and then through the aftermarket cooler are you mike?
Re: Mike L trans cooler on gas engine [Re: Redright9] #5455594 06/16/20 08:51 PM
P10crew Offline
OP why wouldn’t it work on a gas truck?
My latest 4l80E core was in an express van with a Duramax.
Earls makes trans cooler fittings for the 4l80 that convert the stock fittings to 3/8 AN. Then just run you 1/2” lines to the cooler. I think it wold work just fine. Or am I missing something here.
Re: Mike L trans cooler on gas engine [Re: P10crew] #5455608 06/16/20 09:02 PM
ls1mike Offline
I am or it wouldn't get warm enough in winter. In fact the factory hookup to the cooler is straight from the stock trans line.
The other is stock, cut, flared and then as you can see the hose connects from that to the cooler.
Running around town it stays between 120 to 130. Towing in summer 165, on the long grades in the desert in Washington 180ish turning 3800 to 4500 rpm running at 65mph. That is a combined weight of about 15,600lbs scaled.
The larger cooler kept it cool longer and cooled off much quicker than the stock and previous aftermarket cooler I had.
Stock cooler VS first aftermarket cooler. These are tiny compared to 40K trucool
[Linked Image]
[Linked Image]
Most 6.0 guys run it just like this because you just run the stock lines.
Mike
14 Caprice PPV 6.0
15 Malibu LTZ Turbo
12 Passport TT
Re: Mike L trans cooler on gas engine [Re: Redright9] #5455622 06/16/20 09:27 PM
P10crew Offline
Ah ha. I’ve wanted to ask CLine about this for quite some time.
I installed a 20k cooler on my 90 700r4 but I ditched the line through the rad.
The first thing my daddyo did to any tow rig that we got was install a giant cooler and ditch the line to the rad.
Zero tranny problems that I recall and we towed race cars many a thousands of miles during the summer months.
Re: Mike L trans cooler on gas engine [Re: Redright9] #5455626 06/16/20 09:35 PM
P10crew Offline
We need some sort of diverter valve that based on ambient temp it could divert oil away from the rad.
Re: Mike L trans cooler on gas engine [Re: P10crew] #5455640 06/16/20 09:53 PM
ls1mike Offline
A thermostatic bypass. They make them for just this purpose. Do you need one? I have one you can have. Brand new.
Mike
14 Caprice PPV 6.0
15 Malibu LTZ Turbo
12 Passport TT
Re: Mike L trans cooler on gas engine [Re: Redright9] #5455659 06/16/20 10:33 PM
P10crew Offline
Lol no my hot rods are all ran directly to the cooler.
The 1 time that I pulled through the mountains with my new 6.0 tranny oil temp only got to 145 as I remember.
What brand is that valve?
