Gas Buddy Card to pay?
by Redright9 - 07/02/20 04:35 AM
Pentosin Mania
by Snagglefoot - 07/01/20 11:30 PM
Spills. Synthetic vs petrolium
by Chris142 - 07/01/20 10:35 PM
Michelin Pilot Sport All-Season 4
by FordFocus - 07/01/20 10:04 PM
NGK Ruthenium Spark Plugs
by Deontologist - 07/01/20 07:49 PM
Ram Truck Speaker Upgrade Questions
by edhackett - 07/01/20 07:41 PM
OLM SCREWED UP
by demarpaint - 07/01/20 06:12 PM
Have Valvoline European 5w-40. Use in Cummins?
by RetiredGuyOR - 07/01/20 06:06 PM
Change in evaporation rate over time?
by mosschops - 07/01/20 05:56 PM
17 Golf overzealous OLM/Minder
by lawrencerd - 07/01/20 04:24 PM
First cell phone
by Chris142 - 07/01/20 04:08 PM
Motorcraft FL836 Specifications
by viscous - 07/01/20 03:41 PM
Chipmunks - Damit.
by PontiacHO - 07/01/20 03:37 PM
27/18k portable genset oil.
by 1978elcamino - 07/01/20 03:31 PM
Saw a new BMW and had to do a double take.
by wemay - 07/01/20 02:55 PM
Seems like there is less activity on BITOG
by SLO_Town - 07/01/20 02:21 PM
Rock Auto horrible customer service
by cknight49090 - 07/01/20 02:09 PM
RetiredGuyOR, BretBouer, JKMark, Tugcan, George_Robert
71821 Registered Users
28 registered members (BigGeo, Alaskanmont, AlienBug, caprice_2nv, Char Baby, 4WD, 3 invisible), 606 guests, and 27 spiders.
Topics307,389
Posts5,309,631
Members71,821
Flushing cooling system with bad water pump #5454619 06/15/20 05:34 PM
bdcardinal Offline OP
So I bought a 2003 Chevy 2500 referenced in this thread here. The cooling system is questionable at best. Meaning the overflow has some gooey stuff in the bottom. It needs a water pump but I also wanted to flush the cooling system. So the issue is, as soon as I pour anything into the bottle it comes right out the weep hole in the pump. My plan is to swap the pump over, but not the new hoses, maybe even guy the t-stat housing that is in there and run it with no t-stat. Then flush the system with a cleaner, I have the Liquimoly stuff as well as citric acid. Then install the new hoses, t-stat, new reservoir, cap, and fresh coolant. The truck came with a free Gates pump, lien sale so I got other interesting things as well. If the flushing takes out the pump I will get a AC Delco one. I already have new belts, tensionors, and a 145amp alternator.
So what does everyone thing about the plan? It is a bit extra work, but I want to do this sort of correct.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Flushing cooling system with bad water pump [Re: bdcardinal] #5454633 06/15/20 05:50 PM
E
E150GT Offline
E
That's pretty much how I'd do it. My last flush I did on the Buick with distilled water and I took the thermostat out to speed the process up
1984 Mercedes-Benz 300SD - 100k
1995 F150 XL 4.9 reg cab 5MT - 253k 5w30
2016 Mazda6 Touring 6MT - 81k 5w30
2006 Buick Lucerne CXL 3.8 50k 5w30
Re: Flushing cooling system with bad water pump [Re: bdcardinal] #5454791 06/15/20 09:10 PM
I
Ihatetochangeoil Offline
I
Thanks to Trav, I learned that he uses 1 lb citric acid per gallon of distilled water. I mixed prior to adding to cooling system. I also removed the thermostat during the flush process. And I got a little more (BITOG radical)?
I purchased a 110v electric water pump meant for RV use from eBay, an 1 1/2" X 1 1/2" X 5/8" Tee from etrailer sales and spliced it into my lower (intake) radiator hose and feed from a 5 gallon bucket. I adjusted the pump pressure down to 17 psi so as not to explode my cooling system. I bought a couple 1 1/4" plumbing test plugs; plugged the disconnected top radiator hose and set up a 3/4" hose to drain from the thermostat output housing, I started the engine, used my electric pump to maintain a flow of distilled water thru the engine and let it drain (thru the thermostat output) and my connected hose into another bucket until it ran clear.
I admit that with my pump purchase, fittings, hoses, clamps, 27 gallons of distilled water, etc., I've spent about the same amount of money as a wallet flush at a dealer, but now I'm all set to do it next time (with additional fluid purchases).
Re: Flushing cooling system with bad water pump [Re: bdcardinal] #5454808 06/15/20 09:31 PM
1
14Accent Offline
1
Your plan sounds good to me. The new pump won't mind the crud it's circulating, you're just using it to your advantage. As long as you do a full and complete flush, the new pump will be fine when you're done.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
1980 Honda CB900C - 15k mile cream puff
Re: Flushing cooling system with bad water pump [Re: bdcardinal] #5455224 06/16/20 12:40 PM
N
nthach Offline
N
Throw the Gates pump on, and then do a cleaning cycle with dishwasher detergent or a similar alkaline detergent with low foam to get rid of the grease and oil in the cooling loop, rinse with water, then citric or oxalic acid to get rid of rust and scale. One school of thought is to use a sump pump to move the cleaning solution and rinse water for as long as possible without running the engine.
I wonder if the LSx-based Vortecs are as prone to IMG failures as the older ones too. I think Fel-Pro has a stainless steel and FKM gasket for those too.
Re: Flushing cooling system with bad water pump [Re: 14Accent] #5456114 06/17/20 02:15 PM
DGXR Offline
These are my thoughts exactly.
1995 Corvette coupe LT1 6-speed
2006 Tacoma 2.7 Base SR5 AC
2003 Honda XR400R
1999 Yamaha YZ400FL
Re: Flushing cooling system with bad water pump [Re: bdcardinal] #5456350 06/17/20 06:50 PM
K
Kruse Offline
K
My thought would be to throw the Gates water pump into the scrap bin and use an OEM or at least a ACDelco professional water pump, but that's just me, I guess.
Re: Flushing cooling system with bad water pump [Re: bdcardinal] #5458493 06/20/20 12:38 PM
Attacked the job last night. Obviously there is an oil leak somewhere. I got everything cleaned off as much as possible and got the new pump mounted. I used new bolts from ICT Billet for the water pump. Also got the new 145amp alternator mounted. I got the ACDelco, actually Gates, HD belts as well as new ACDelco tensionors and idlers, which had Gates paperwork in them as well. There should have been 4 clips holding the fan shroud halves together, but there were only 3 and all were different. I got the new belts routed and then called it a night. I was fighting darkness and an unhappy back. When I get off of work today I will try to finish the job tonight.
As far as cleaning the timing cover, I used a combination of brake cleaner, brushes, a MATCO scraper, and Motorcraft Metal Surface Prep Wipes.
Also the Y shaped heater hose broke right at the Y fitting when I was taking it off the old pump, not really ideal for my plan. Also there was some yellowing looking coolant that came out when I opened the floodgates. Still debating how this will all go.
Also of note, whoever was in this before does not understand that host clamps come in many sizes. They just used the giant ones and the tails were hanging out cutting up my arms in the process.
Re: Flushing cooling system with bad water pump [Re: bdcardinal] #5458546 06/20/20 02:22 PM
Fifth87 Offline
Definitely advocate for the Citric Acid approach mentioned by Trav. Worked wonders on my Caliber.
Looks good what you've accomplished so far, look forward to the end of the story.
87 Chevy Caprice wagon 109K ST 10W-40/ACDelco filter
95 Oldsmobile Cutlass Ciera 80K ST 5W-30/ACDelco filter
09 Dodge Caliber SXT 71K Castrol 5W-20/WIX filter
Re: Flushing cooling system with bad water pump [Re: Fifth87] #5458577 06/20/20 03:13 PM
Found this at work. I remember buying it for service years ago and it hasn't been touched since.
Re: Flushing cooling system with bad water pump [Re: bdcardinal] #5458856 06/20/20 11:24 PM
What's the saying, 1 step forward, 2 steps back? So I went to pull the heater hose connectors off to replace them, and of course they fell apart. Good news, I was smart and ordered new ones. Bad news, I am really good at Ford and Mazda parts and not GM, got the wrong ones. So those will be in on Monday. I put the new overflow bottle in, so that went well.
I then decided to change the spark plugs. That wasn't too bad, except the wires fell apart taking them off so I had to dig those off. I ordered the 748HH wires that are supposed to be 10.5" but I think they were missboxed. They were shorter than the ones I took off the truck and those were really tight between the coils and wires. O well, ordered more for Monday.
Re: Flushing cooling system with bad water pump [Re: bdcardinal] #5461134 06/23/20 10:26 PM
Got it all back together tonight, filled with just water to get it burped. It looked good so I added a bottle of the Liqui Moly radiator flush to start cleaning. The heat was really hot, and the AC was really cold, so that part was great. Then I noticed a drip under the truck. Checked further and it was from where the thermostat housing goes against the water pump. Shut the truck off and let it cool a bit, then went to check the bolts. The bottom one was loose, went ti snug it up with a short 1/4" ratchet and got tight, then loose..... At least I am really fast at taking it all apart now frown Going to get an ACDelco pump and hopefully get it all together tomorrow.
Re: Flushing cooling system with bad water pump [Re: bdcardinal] #5461558 06/24/20 03:05 PM
B
Barkleymut Offline
B
At least you know what needs to be done now...have fun tomorrow. And remember, friends don't let friends drive Chevy's.
09 Vue 2.4L 4spd AT/ 09 Flex 3.5L / 96 F150 5.0 5speed / 07 Mustang GT auto
Re: Flushing cooling system with bad water pump [Re: bdcardinal] #5461624 06/24/20 04:40 PM
Got the new/updated/latest and greatest pump in today from my Motorcraft/ACDelco vendor. I already had the updated t-stat. Hopefully all goes well tonight.
Lesson for anyone reading, when you do something like this, fill it with water first, you can always drain the water and put in the coolant later.
Re: Flushing cooling system with bad water pump [Re: bdcardinal] #5461905 06/24/20 11:23 PM
It runs!!! No leaks. I just refilled with water for now. Changed the oil too. Going to drive it a bit and then will drain the water out of the radiator and will see how it looks.
