How To Remove Overspray On Aluminum Wheels?
by NDL - 07/02/20 07:16 AM
Gas Buddy Card to pay?
by Redright9 - 07/02/20 04:35 AM
Pentosin Mania
by Snagglefoot - 07/01/20 11:30 PM
Spills. Synthetic vs petrolium
by Chris142 - 07/01/20 10:35 PM
Michelin Pilot Sport All-Season 4
by FordFocus - 07/01/20 10:04 PM
NGK Ruthenium Spark Plugs
by Deontologist - 07/01/20 07:49 PM
Ram Truck Speaker Upgrade Questions
by edhackett - 07/01/20 07:41 PM
OLM SCREWED UP
by demarpaint - 07/01/20 06:12 PM
Have Valvoline European 5w-40. Use in Cummins?
by RetiredGuyOR - 07/01/20 06:06 PM
Change in evaporation rate over time?
by mosschops - 07/01/20 05:56 PM
17 Golf overzealous OLM/Minder
by lawrencerd - 07/01/20 04:24 PM
First cell phone
by Chris142 - 07/01/20 04:08 PM
Motorcraft FL836 Specifications
by viscous - 07/01/20 03:41 PM
Chipmunks - Damit.
by PontiacHO - 07/01/20 03:37 PM
27/18k portable genset oil.
by 1978elcamino - 07/01/20 03:31 PM
Saw a new BMW and had to do a double take.
by wemay - 07/01/20 02:55 PM
bigmike323, SolsticeSHO, Bazza32, Klink_II, williamshrader
71828 Registered Users
99 registered members (ARCOgraphite, 555, Arrechera, 2K2AcuraTL, 2015_PSD, Astro14, 10 invisible), 1,446 guests, and 35 spiders.
Topics307,317
Posts5,308,870
Members71,828
Gas Power Washer Leaking Water #5454573 06/15/20 04:42 PM
M
maverickfhs Offline OP
M
So have two gas Simpson power washers(MSV3024, MSVK2723) both have the same pump and are leaking/sprinkling from the pump area once the pressure washer has turned on.
Is there a way to weld/silicone/solder or do anything to fix the leak or pretty much pump replacement is needed?
Pump is more than the worth of the washers right now, thanks for the help thumbsup
2006 Civic EX 209K/AT
2006 Acura TSX 199K/AT
2007 Accord VP 154K/AT
Re: Gas Power Washer Leaking Water [Re: maverickfhs] #5454612 06/15/20 05:24 PM
T
tundraotto Offline
T
pumps can be repackecked.....some bypass valves can be replaced.....you will have to find out if the pumps have rebuildable valves....if they dont...probably cheaper to get a replacement pump.
over 30 seconds off the trigger will start harming the pump as the water will overheat in the bypass. Full throttle, all the time - like a weed-eater.
Re: Gas Power Washer Leaking Water [Re: maverickfhs] #5454697 06/15/20 07:33 PM
N
nascarnation Offline
N
Cracks in the housing due to water freezing in winter are very common because pumps don't drain well.
If that's your issue, they are pretty much unrepairable without replacing the cracked housing.
My neighbor tried to JB Weld his and it was a waste of time, instant fail.
