Forums Migration
Please read this thread
High Flow Thermostats
by Nick1994 - 07/12/20 02:51 AM
Hy-per Lube ZDDP Supplement 6pk $13.00
by alchargo - 07/11/20 10:38 PM
97 Civic HX valve cover pics
by CARJ - 07/11/20 10:22 PM
Time to ditch Speedplays
by UG_Passat - 07/11/20 10:03 PM
Dale L Nuzum
by Dalenuzum - 07/11/20 10:02 PM
*BANG* (Garage Door Spring)
by ctechbob - 07/11/20 09:40 PM
TPMS Sensors
by 92saturnsl2 - 07/11/20 09:16 PM
Chevron Delo 400 XSP 5W-30 XSP
by Gene K - 07/11/20 08:48 PM
LED retrofit for recessed can lights
by Donald - 07/11/20 07:08 PM
PP HM 5W-20 $15 at Wally
by Jackson_Slugger - 07/11/20 07:03 PM
Defeated by roll pin
by bcossa2001 - 07/11/20 06:56 PM
Dexron VI in place of Mercon LV?
by BigLee - 07/11/20 06:50 PM
89 c4 oil
by dogememe - 07/11/20 06:17 PM
Noticed the Titanium info.
by Farnsworth - 07/11/20 06:16 PM
FebiBilstein Parts
by willbur - 07/11/20 06:03 PM
Life goes on
by 53' Stude - 07/11/20 06:02 PM
Lubegard in a GM transfer case?
by BlakeB - 07/11/20 05:21 PM
Is MSO2 Liquid Moly OK in DIG NA engines
by JimPghPA - 07/11/20 03:10 PM
Rider Magazine Question
by Smoky14 - 07/11/20 02:38 PM
cadillactech, ILoveOil111, quantalume, SUmeme22, DaveCaddell
71910 Registered Users
29 registered members (CPA1989, Ausfahrt, blufeb95, carviewsonic, celicaxx, 5 invisible), 572 guests, and 27 spiders.
Topics307,747
Posts5,316,936
Members71,910
John Deere LA110 Re-Power #5454571 06/15/20 04:40 PM
A
Astro_Guy Offline OP
A
My MIL has had this tractor since 2007. This is a single cylinder 19 HP Briggs powered machine. The head gasket went a few years ago and was replaced by the JD dealer. Over the weekend the machine "started smoking a lot and then started rattling loudly." Sounds catastrophic to me. She shut it off immediately and left it where it was. The dealer is picking it up tomorrow. I am just curious if it could be re-powered with a Harbor Freight Predator V-Twin, or if the mounting setup is completely different.
'01 Volvo V70XC, 255k, 5W-30 M1 EP
'16 Accord, 50k, 0W-20 M1 EP
Re: John Deere LA110 Re-Power [Re: Astro_Guy] #5454584 06/15/20 04:56 PM
R
Rand Offline
R
im sure it could be done but maybe not worth it, not exactly a classic tractor there.
1299 buys another box store throwaway.
https://www.homedepot.com/p/Troy-Bi...REC-_-pipsem-_-307458207-_-311264920-_-N
the Bronco is 1499 (sells for cheaper on sale)
or go look for a lightly used deere x300 series.
Re: John Deere LA110 Re-Power [Re: Astro_Guy] #5454596 06/15/20 05:04 PM
T
tundraotto Offline
T
id just match the shaft diameter and length with a chinese v-twin and keep going.
Re: John Deere LA110 Re-Power [Re: tundraotto] #5454620 06/15/20 05:35 PM
R
Rand Offline
R
factory is 1 cyl briggs.. adapting a v-twin takes time and patience esp.. when its a relative's tractor.
who knows if it even fits in the sheet metal.
and after you get all that to work.. you have 13 year old box store tractor around it.. its not terrible. but not exactly a deere 318, x300 etc either.
and that is if the factory engine isnt one of the goofy vertical models.
Re: John Deere LA110 Re-Power [Re: Astro_Guy] #5454660 06/15/20 06:30 PM
R
Rand Offline
R
new info it is a vertical engine. so the HF vtwin horizontal engine wont work.
https://engine4less.com/repower/JOHNDEERE/LA110.html
17.5hp replacement $599 and its plug in play.. might be worth it.
Re: John Deere LA110 Re-Power [Re: Astro_Guy] #5454665 06/15/20 06:43 PM
J
jeepman3071 Offline
J
The 22 HP vertical Predator engine will fit, as it should have the same bolt pattern, and has a 1" shaft. HF has them listed for $1000. That's way more than a replacement Briggs.
Check out Small Engine Warehouse and smallenginesurplus.com. You can find single cylinder Briggs from 13.5-18hp for less than $600. Sometimes they have a sale and you can get them for $450. Anything from that HP range should be fine for a 42" LA110. I repowered a neighbor's 42" Simplicity with a 13hp Briggs intek back in 2010 and it has been great.
Here's a 17HP for $440:
https://www.smallenginesurplus.com/briggs-stratton-31r9770054-p-3621.html
1998 Jeep Wrangler Sahara 4.0L/5MT (157k) - PHM 10w30, Wix 51085
2009 BMW 328i N51 (63k) - Liqui Moly 5w40, MANN HU816X
Re: John Deere LA110 Re-Power [Re: jeepman3071] #5454704 06/15/20 07:37 PM
FADEC Offline
13 year old tractor that was cheap to begin with. Sell it on Craigslist for $100 and buy a new one.
Re: John Deere LA110 Re-Power [Re: jeepman3071] #5454706 06/15/20 07:38 PM
A
A
Thanks Jeepman. I was just curious, and odds are that she will just replace it or opt for a lawn service. Now if only I could figure out a way to give her my D140 and get myself a water cooled diesel tractor. That would be sweet!
Re: John Deere LA110 Re-Power [Re: Astro_Guy] #5454726 06/15/20 07:56 PM
W
walterjay Offline
W
The next thing to go is the transmission. I would never consider a new engine. Put your hard earned money toward a new or much newer one.
Re: John Deere LA110 Re-Power [Re: jeepman3071] #5454777 06/15/20 08:46 PM
R
Rand Offline
R
Cool didnt know they had a vertical v-twin now.
and that website is cheap but for apples to apples its $504 shipped(but out of stock) vs $599
I was considering putting the horizontal v-twin into the 3000 hour jd316 we trail mow with.. but did valve job instead.
Re: John Deere LA110 Re-Power [Re: Rand] #5454974 06/16/20 07:11 AM
J
jeepman3071 Offline
J
Whoops, didn't realize it was out of stock. I do a lot of repowers for customers but haven't done a V-Twin Predator yet. The cost is just too much for most people. They would rather I throw in a used Briggs or Kohler V-Twin. There seems to be two schools of thought with my customers, either get it done cheap with a used engine, or the commercial mower guys buy a quality replacement like a Briggs Vanguard or Kawasaki. I've seen a few Honda V-Twin repowers on those Deeres, but not a Predator yet.
Re: John Deere LA110 Re-Power [Re: Astro_Guy] #5454975 06/16/20 07:13 AM
J
jeepman3071 Offline
J
If she does replace it, you could take it on as a project and make a bit of $. Find a used Briggs Intek on Facebook or Craigslist for $125-150, drop it in, and sell the machine for $500-600. It's literally a pulley, 4 mounting bolts, and a wire harness connector that holds those engines in. I can swap them in a half hour usually.
Re: John Deere LA110 Re-Power [Re: Astro_Guy] #5458482 06/20/20 12:16 PM
J
JTK Online Content
Online Content
J
I get it that a Predator V-twin will bolt up, but that's only a part of the picture.
Will the predator's exhaust system fit the frame? What about wiring connectors and throttle cable?
2019 Nissan Pathfinder SV
2019 Ram 1500 SLT, CC,4x4, Hemi.
2015 Nissan Versa 1.6 S
Re: John Deere LA110 Re-Power [Re: JTK] #5458604 06/20/20 03:46 PM
K
Kruse Offline
K
About two years ago, I purchased the HF 22HP Predator to replace a blown Kohler Courage engine on a Toro zero-turn lawn mower. At the time, I found a coupon to buy it for $549. I see the coupons for this engine have dried up and they now want $1000 for it.
The HF pros: The exhaust is already on it. It bolted right up to the frame. The electrical connectors clicked in place.
The HF cons: The throttle linkage needed to be replaced with a longer one. I don't know if the OP will need to do that or not.
IMO, if you can't get the cheaper price on the HF vertical, I'd try to find something else. Knowing HF, they could discontinue this engine and your replacement parts source could dry up instantly.
Re: John Deere LA110 Re-Power [Re: Kruse] #5458722 06/20/20 06:50 PM
J
JTK Online Content
Online Content
J
Yep. I get that, but on most riding mower chassis, the exhaust is routed through and below the tractor's frame. Maybe you can unbolt the factor predator exhaust and route it that way too. I dunno.
