How To Remove Overspray On Aluminum Wheels?
by NDL - 07/02/20 07:16 AM
Gas Buddy Card to pay?
by Redright9 - 07/02/20 04:35 AM
Pentosin Mania
by Snagglefoot - 07/01/20 11:30 PM
Spills. Synthetic vs petrolium
by Chris142 - 07/01/20 10:35 PM
Michelin Pilot Sport All-Season 4
by FordFocus - 07/01/20 10:04 PM
NGK Ruthenium Spark Plugs
by Deontologist - 07/01/20 07:49 PM
Ram Truck Speaker Upgrade Questions
by edhackett - 07/01/20 07:41 PM
OLM SCREWED UP
by demarpaint - 07/01/20 06:12 PM
Have Valvoline European 5w-40. Use in Cummins?
by RetiredGuyOR - 07/01/20 06:06 PM
Change in evaporation rate over time?
by mosschops - 07/01/20 05:56 PM
17 Golf overzealous OLM/Minder
by lawrencerd - 07/01/20 04:24 PM
First cell phone
by Chris142 - 07/01/20 04:08 PM
Motorcraft FL836 Specifications
by viscous - 07/01/20 03:41 PM
Chipmunks - Damit.
by PontiacHO - 07/01/20 03:37 PM
27/18k portable genset oil.
by 1978elcamino - 07/01/20 03:31 PM
Saw a new BMW and had to do a double take.
by wemay - 07/01/20 02:55 PM
bigmike323, SolsticeSHO, Bazza32, Klink_II, williamshrader
71828 Registered Users
93 registered members (1978elcamino, ArrestMeRedZ, 2015_PSD, 64bawagon, alarmguy, anpconnors, 6 invisible), 1,268 guests, and 24 spiders.
Topics307,377
Posts5,309,603
Members71,828
2010 Escape Driver's seat Bolt/Nut sizes? #5454537 06/15/20 03:35 PM
9
97tbird Offline OP
9
I need to remove my driver's seat. so In the pic below, 1 and 3 (fronts are called BOLTS while the rear 2 are called NUTS in that diagram).
I tried as hard as I could on the WWW but couldn't find info re: the SIZE and type of Bolts for the front, and the SIZE and type of "nut" for the rear.
This is a 2010 Escape, Driver;s power seat.
Thanks, IA
[Linked Image from nicksmustangranch.com]
Sufficiently Caffeinated...
Cars: 1997 Thunderbird v8 sports(sold), 2003 Elantra GLS (totaled at 225k), 2005 BMW 330Ci ZHP, 2014 Mazda 6 Touring, 2010 Ford Escape Limited v6 AWD
Re: 2010 Escape Driver's seat Bolt/Nut sizes? [Re: 97tbird] #5454550 06/15/20 04:00 PM
Chris142 Online Content
Online Content
13mm or 15mm wrench.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: 2010 Escape Driver's seat Bolt/Nut sizes? [Re: 97tbird] #5454551 06/15/20 04:01 PM
skyactiv Offline
Don't call a dealer, get upset and start a thread when they wont shout out the sizes needed.
Me: 18' Elantra Sport 6 speed manual
The rude guy that points out reality
Re: 2010 Escape Driver's seat Bolt/Nut sizes? [Re: 97tbird] #5454552 06/15/20 04:01 PM
R
ryster Offline
R
I believe the front are 15mm bolts. Not sure what the rear size is. Be careful and remember to depower the car so the airbags do not explode.
2015 Chevrolet Equinox LT AWD
3.6L V6
Re: 2010 Escape Driver's seat Bolt/Nut sizes? [Re: 97tbird] #5454560 06/15/20 04:13 PM
bdcardinal Offline
Saved OP a phone call. This is the specs it would give us for any piece of hardware.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: 2010 Escape Driver's seat Bolt/Nut sizes? [Re: 97tbird] #5454587 06/15/20 04:56 PM
E
eljefino Offline
E
bdadmirals' answer is technically correct, in that a bolt is described by its thread diameter and pitch.
OP probably wants the head socket sizes.
Re: 2010 Escape Driver's seat Bolt/Nut sizes? [Re: 97tbird] #5454591 06/15/20 05:00 PM
dogememe Offline
On my 2010 Escape I had to remove the bolts at the front of the passenger seat to install my Ram Mount for my laptop. It uses a large Torx, I forget what size. But anyway I replaced it with a regular hex bolt because I remove it and reinstall it quite frequently.
2010 Ford Escape 2.5 ~104K Miles: AMSOIL Signature Series 0W-30, Wix Filter.
2001 Chevy Suburban 5.3 ~292K Miles: Valvoline Maxlife 10W-30, ACDelco Filter.
Re: 2010 Escape Driver's seat Bolt/Nut sizes? [Re: 97tbird] #5454600 06/15/20 05:05 PM
M
mk378 Offline
M
I really don't get these threads. How hard is it to look at the bolt on your car and try a few sockets on it?
On a 2004 F-250 the front bolts are T-55 Torx and the back nuts 19mm.
Re: 2010 Escape Driver's seat Bolt/Nut sizes? [Re: 97tbird] #5454648 06/15/20 06:08 PM
9
97tbird Offline OP
9
Thanks everyone.
The driver's seat doesn't have the Torx. (only the passenger seat does and it 's a Torx PLUS 55, not a regular Torx on the Escape) That info is somehow readily available on the the web, but for the driver's side, was not the case.
The reason I asked was I DID try the sockets I had and none of them matched the front bolts. I also noticed i am missing 2 sockets from my toolbox. So I thought I'd better check the size to be sure I am borrowing / getting the correct sockets I need.
Again, thanks for everyone's answers - i think I can now have a good ballpark idea of what sockets I will need, very probably a 15mm as several have said, for the fronts.
