Cannot unscrew oil filter housing cap - BMW E46
by 97tbird - 07/04/20 07:21 PM
Are u a big fireworks person?
by ZZman - 07/04/20 06:53 PM
Honda Accord MAP sensor question
by Kira - 07/04/20 06:28 PM
Hy-Gard Shelf Life (Opened Bottle)
by viscous - 07/04/20 06:10 PM
Want to bet on my luck? (atf to "save" transmission)
by Snoman002 - 07/04/20 06:10 PM
Too Much Zinc = Corrosion?
by viscous - 07/04/20 06:00 PM
New vehicles with a 4 speed transmission?
by MrHorspwer - 07/04/20 04:57 PM
Inability to Choose
by Gene K - 07/04/20 01:53 PM
65 200 6 mustang running kinda hot
by old1 - 07/04/20 01:30 PM
Neo-protec GT em
by dervdave - 07/04/20 01:19 PM
Mannol 9929 Ester additive
by dervdave - 07/04/20 01:14 PM
2015 Corolla with 7k miles has “soft brakes”
by NHBFAN - 07/04/20 12:30 PM
Put Bilsteins on the Silverado
by bdcardinal - 07/04/20 12:19 PM
Hour meter - not moving?
by Serge - 07/04/20 11:52 AM
Was in a Parade today!
by sasilverbullet - 07/04/20 11:40 AM
Amsoil bypass kit ford 6.7 (BMK33)
by willypete - 07/04/20 11:39 AM
Should I buy a "B" Temperature tire for 2016 Pilot?
by oily boyd - 07/04/20 11:15 AM
paolo9fla, SunnyB, Mullady76, Axia2, Johan1
71847 Registered Users
83 registered members (555, 4WD, Astro14, 77GrandPrix, 55hambone, 97tbird, 13 invisible), 1,485 guests, and 25 spiders.
Topics307,432
Posts5,310,899
Members71,847
BMW 650 GranCoupe X-Drive Rear diff oil #5454512 06/15/20 02:46 PM
J
jackliu Offline OP
J
I want to drain and replace my rear differential fluid on my BMW 650 XDrive, from my research BMW uses Hypoid Axle Oil G1 (BOT448) P/N: 83 22 2 295 532 which is a 75W85 GL-4 oil, I want to try out the Redline 75W85 oil, however, it is a GL-5 oil, even tho on the redline website it says it is compatible with the BMW 75W85 GL-4 oil even included the BMW part number, from more research online, some say that one should not be using GL-5 oil in GL-4 car because it has sulfur which could cause wear, experts please do chime in. As well is Redline oil a superior product compared to BMW gear oil? or are there other suggestions and why?
Re: BMW 650 GranCoupe X-Drive Rear diff oil [Re: jackliu] #5454553 06/15/20 04:03 PM
O
oldhp Offline
O
I would have no problem using RedLine 75W85 in my BMW. Dodge HellCats use 75W85 gear oil. If it's good enough for a 707HP car, I would say it's good enough for the BMW. GL5 is made for hypoid differential's.
"None of us are getting out here alive...drink that beer...eat that pizza...drive that Hot Rod"
"When others cut you down, remember where they came from."
"I don't run...........I just quietly wait"
Re: BMW 650 GranCoupe X-Drive Rear diff oil [Re: jackliu] #5454563 06/15/20 04:19 PM
M
MCompact Offline
M
BMW used to spec GL4 oils for their manual transmissions because GL5 oils attacked the bronze synchros. I'd just buy the BMW oil. FWIW, I never touched the diffs on my E83, and it ran fine past 198k miles. The guy I sold it to has had no issues the three years he's owned it.
Mine:
2014 M235i
2009 Cooper Clubman
1999 Wrangler Sahara
1995 318ti Club Sport
Wife's:
2015 X1 xDrive28i M Sport
Son's
2009 328i
Buy what makes you smile...
Re: BMW 650 GranCoupe X-Drive Rear diff oil [Re: jackliu] #5454579 06/15/20 04:50 PM
A
Audios Offline
A
I would stick with whats recommended, is it the active diff with the clutch plates?
2002 VW Golf TDI-T5 10/30
2007 Mercedes GL320 CDI-T6 5/40
2005 BMW M3 BMW-Twin Power 10/60
2003 BMW M5-M1 15/50
1998 BMW M3/4/5-M1 10/40
Re: BMW 650 GranCoupe X-Drive Rear diff oil [Re: Audios] #5454729 06/15/20 08:00 PM
J
jackliu Offline OP
J
I have no idea lol
