Forums Migration
Please read this thread
High Flow Thermostats
by Nick1994 - 07/12/20 02:51 AM
Hy-per Lube ZDDP Supplement 6pk $13.00
by alchargo - 07/11/20 10:38 PM
97 Civic HX valve cover pics
by CARJ - 07/11/20 10:22 PM
Time to ditch Speedplays
by UG_Passat - 07/11/20 10:03 PM
Dale L Nuzum
by Dalenuzum - 07/11/20 10:02 PM
*BANG* (Garage Door Spring)
by ctechbob - 07/11/20 09:40 PM
TPMS Sensors
by 92saturnsl2 - 07/11/20 09:16 PM
Chevron Delo 400 XSP 5W-30 XSP
by Gene K - 07/11/20 08:48 PM
LED retrofit for recessed can lights
by Donald - 07/11/20 07:08 PM
PP HM 5W-20 $15 at Wally
by Jackson_Slugger - 07/11/20 07:03 PM
Defeated by roll pin
by bcossa2001 - 07/11/20 06:56 PM
Dexron VI in place of Mercon LV?
by BigLee - 07/11/20 06:50 PM
89 c4 oil
by dogememe - 07/11/20 06:17 PM
Noticed the Titanium info.
by Farnsworth - 07/11/20 06:16 PM
FebiBilstein Parts
by willbur - 07/11/20 06:03 PM
Life goes on
by 53' Stude - 07/11/20 06:02 PM
Lubegard in a GM transfer case?
by BlakeB - 07/11/20 05:21 PM
Is MSO2 Liquid Moly OK in DIG NA engines
by JimPghPA - 07/11/20 03:10 PM
Rider Magazine Question
by Smoky14 - 07/11/20 02:38 PM
cadillactech, ILoveOil111, quantalume, SUmeme22, DaveCaddell
71910 Registered Users
38 registered members (A_A_G, Ausfahrt, 53' Stude, 2009Edge, bismic1, 5 invisible), 672 guests, and 23 spiders.
Topics307,747
Posts5,316,945
Members71,910
Best blend with these 3 oils. #5454504 06/15/20 02:38 PM
M
MoneyJohn Offline OP
M
2006 Sentra, ~114K on the odometer, takes 3quarts, no oil burning, or leaking.
3 years ago, I got a 12-pack of Miles Lubricants 5w-30 syn blend for really cheap, like $1.20/qt. I am on the last 3 bottles. Last week, a neighbor gave me an unopened 3-year-old 5-qt container of Castrol GTX High Mileage 5W-30 Synthetic Blend. He got it by mistake. He wanted synthetic.
I have 5qt each of Mobil 1 synthetic and Penn Plat. Both 5w-30 weights.
Before he gave me Castrol, I was planning to mix 2qt of Miles syn blend and a quart of Mobil. Planning Penn Plat in Forester that takes 5qts.
So how would you blend these oils? One quart of each for the next 3 years? Sentra gets a yearly oil change.
(P.S. - I know I am overthinking. I just want to make sure this the best strategy.)
Re: Best blend with these 3 oils. [Re: MoneyJohn] #5454513 06/15/20 02:47 PM
JohnnyJohnson Offline
The purpose and what do you expect in reality its going to gain you?
2004 Corolla 140744
Out: Pennzoil Platinum HM 5W-20 ST 4386
In: Valvoline Synpower Full Synthetic 5W-30 Purolator PureONE
2006 Duramax 77117
Out: T6 5W-40 XG9100 73909
In: Rotella Dino PH9100 11-3-19
Re: Best blend with these 3 oils. [Re: JohnnyJohnson] #5454522 06/15/20 02:59 PM
CT8 Offline
There is magic in the mixing.
2015 F150 2.7
2018 F350 6.2
Re: Best blend with these 3 oils. [Re: MoneyJohn] #5454523 06/15/20 03:00 PM
deoxy4 Offline
I would use the oldest stock first and blend as little as possible.
I don't think you would have a problem if you did blend.
Re: Best blend with these 3 oils. [Re: CT8] #5454529 06/15/20 03:14 PM
In my garage that magic is called getting rid of excess top off oil that didn't make it in the mower.
2004 Corolla 140744
2006 Duramax 77117
Re: Best blend with these 3 oils. [Re: MoneyJohn] #5454543 06/15/20 03:47 PM
K
krismoriah72 Offline
K
Sentra Takes 3 qts- Use the 3qts of Miles Lubricants.
Forester takes 5 qts- Use the 5qts of GTX, Mobil, and Penn Plat 3 different oil changes.
No blending needed.
If you dont like any of the oils give them away or do oil changes in familys cars... no need to overthink it.
Re: Best blend with these 3 oils. [Re: krismoriah72] #5454545 06/15/20 03:51 PM
O
OilReport99 Offline
O
No blending needed.
That was tough to figure out, wasn’t it.
2018 Ram 1500
Re: Best blend with these 3 oils. [Re: JohnnyJohnson] #5454693 06/15/20 07:29 PM
H
Hall Offline
H
Well, there are folks here who feel the need to make their own concoction of engine oil because they know better than the automakers and oil producers....
Re: Best blend with these 3 oils. [Re: Hall] #5454763 06/15/20 08:28 PM
7
77Se7en Offline
7
I've been mixing oils for about 25 years now. But not for the reasons you cited above.
Spiritual Intuitive / Whisperer-Medium (Involuntary & Non-Profit)
Valvoline ME, Mobil-1 EP & Pennzoil Ultra Platinum 5w30s
Re: Best blend with these 3 oils. [Re: JohnnyJohnson] #5454912 06/16/20 04:23 AM
M
M
This vehicle has been neglected a lot in the past. Since I started doing oil changes 3 years ago, it 'feels' like it is driving better. I also got a lot of maintenance done. Last month, the mechanic pulled a valve cover and mentioned that there is a little sludge. I don't want to clean the sludge aggressively, thinking maybe that will end up with more troubles (leaking?) The First idea was just to mix it with Mobil 1 so that it starts cleaning. After I got HM oil, I thought maybe I could mix these three to cover all the bases. I am not an expert like a few others here so I thought better ask if it makes sense.
These are my first 2 cars so still a novice when it comes to car experiences. I didn't want to belabor in the OP, hence didn't mention. That said, I definitely didn't expert such jerk reactions. It is a very helpful forum. I learned a lot, still learning new things every day but such reactions do not make it a friendly place to ask a question to learn. You genuinely ask a question but most reactions call you stupid.
Re: Best blend with these 3 oils. [Re: MoneyJohn] #5454963 06/16/20 06:57 AM
7
77Se7en Offline
7
Only takes three quarts?
I'd change that oil every 2k, until the time the dipstick remains clear for several hundred miles. I would also add an appropriate amount of Rislone to the oil, to slowly speed-up the cleaning process.
I would also shop for the largest fitting oil filter possible. Most-all of the Japanese filters in 2006-era, were small / infant-sized.
Re: Best blend with these 3 oils. [Re: 77Se7en] #5455251 06/16/20 01:20 PM
M
M
Thank you.
Re: Best blend with these 3 oils. [Re: MoneyJohn] #5455347 06/16/20 03:21 PM
G
Gene K Offline
G
Sentra
OCI #1 - 3 Qt Miles
OCI #2 - 3 Qt GTX-HM
OCI #3 - 2 Qt GTX-HM + Whatever comes along or SuperTech if all else fails.
Forester
OCI #1 PP
OCI #2 M1
Gene
2014 Mustang GT 5.0 SC - 675 bhp
ST Synthetic 10W30 / FL500S
2018 F150 4x4 3.5 EB
OEM Oil & Filter
2018 Lincoln MKX 3.7
OEM Oil & Filter
Re: Best blend with these 3 oils. [Re: Gene K] #5455407 06/16/20 04:51 PM
B
bbhero Offline
B
Good plan here I believe ^^^^^^^^
Nissan Altima 3.5 Coupe
Royal Purple 10w30+ Ceratec+ Carquest red 85358
"Treat your family like your friends and treat your friends like your family."
