Forums Migration
Please read this thread
Nio stock. How high will it go?
by motor_oil_madman - 07/12/20 05:34 PM
AAP Rotella Gas Truck Clearance
by Sam_Julier - 07/12/20 05:32 PM
Any 47RH Transmission Experts? CTD Ram
by JHZR2 - 07/12/20 04:58 PM
WM Magna1 10w30 gallon $5
by 2strokeNorthstar - 07/12/20 04:55 PM
I found a WWII movie for yinz to watch.
by JimPghPA - 07/12/20 04:45 PM
Jackpoint Jackstand Review
by RamFan - 07/12/20 03:03 PM
Lesabre Brake fluid capacity
by Ihatetochangeoil - 07/12/20 02:56 PM
Baking Cookies in the Car - 2.0
by Nick1994 - 07/12/20 02:17 PM
Dealer ruined my transmission!!!!
by John344 - 07/12/20 02:04 PM
Wax / Sealer Recommendations
by 92saturnsl2 - 07/12/20 01:45 PM
Horrible Duramax Aftermarket Filter Mod
by ToadU - 07/12/20 01:29 PM
Japan unveils timeline for indigenous fighter jet program
by gathermewool - 07/12/20 12:27 PM
NEW Rotella T6 15w40
by ToadU - 07/12/20 11:54 AM
2001 Silverado 1500 4x4 Alignment Concerns
by Blang - 07/12/20 11:37 AM
Full Synthetic for ATS V
by cadillactech - 07/12/20 11:33 AM
Gasoline engine oil in a diesel engine?
by LeslieX - 07/12/20 11:32 AM
Can I use IPA 70% to clean windshield?
by painfx - 07/12/20 09:47 AM
The Heat is on
by Snagglefoot - 07/12/20 07:39 AM
fxxkat, Ajreitano, Slick122, Ford4life76, Patrick_Hall1988
71916 Registered Users
95 registered members (4WD, 2015_PSD, 379KITTY, 53' Stude, 2004tdigls, 2003f7, 13 invisible), 1,960 guests, and 30 spiders.
Topics307,771
Posts5,317,458
Members71,916
2002 Ranger GEM - Requires programming? #5454173 06/15/20 06:37 AM
DuckRyder Offline OP
Getting conflicting info again.
Does the GEM require programing in a 2002 Ranger, the new one is not the same part number, but is a Ford reman specified for the truck.
I believe FORscan will retrieve the programming from the bad one... maybe
Robert
  • 2019 Volkswagen Jetta R-Line
  • 1972 F100 Ranger XLT (445FE/C6/9” 3.50 Truetrac)
  • 2002 Ford Ranger XLT 4D Supercab 3.0L
Re: 2002 Ranger GEM - Requires programming? [Re: DuckRyder] #5454313 06/15/20 10:06 AM
B
beast3300 Offline
B
It requires a PMI.
'03 Regal GS L67: PPUP 5w30/FU3980
'03 Sable Duratec QS conv 5w20/NAPA Gold
'03 Lesabre Val PP 10w30/TG3387A
'07 LaCrosse L26: QS HM 5w30/TG3387A
ASE L1 MT
Re: 2002 Ranger GEM - Requires programming? [Re: DuckRyder] #5454387 06/15/20 12:13 PM
bdcardinal Offline
Step 1 from the FSM:
CAUTION: Prior to removal of the generic electronic module (GEM), it is necessary to upload module configuration information to the diagnostic tool. This information needs to be downloaded into the new module once installed. For additional information, refer to Section 418-01.
1995 Ford Mustang GT
2003 Chevy Silverado 2500
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: 2002 Ranger GEM - Requires programming? [Re: DuckRyder] #5454388 06/15/20 12:16 PM
Thanks guys! Hopefully FORScan will do it.
Robert
Re: 2002 Ranger GEM - Requires programming? [Re: DuckRyder] #5454421 06/15/20 12:50 PM
G
getawheel Offline
G
FORScan will definitely do it, but you will probably need an active Extended License if you don't already have one. They're free and only take a few minutes to get.
You will want to save the "as-built" data from the original GEM and then write the saved as-built file to the new GEM.
I've done at least a dozen of them, FORScan makes it pretty simple. If you run into any problems with the procedure, feel free to PM me or post back here and I can walk you through it.
1993 Ford Mustang 2.3L/5-speed, 32k
2002 Ford Ranger 3.0L/5R44E, 255k
2002 Honda CR-V AWD 2.4L/5-speed, 170k
2006 Jaguar XJ8 Vanden Plas 4.2L, 103k
Re: 2002 Ranger GEM - Requires programming? [Re: getawheel] #5459179 06/21/20 12:26 PM
Appreciate the assistance!
I was able to do it with FORScan.
It really was pretty easy.
See also other thread.
Robert
