Gas Buddy Card to pay?
by Redright9 - 07/02/20 04:35 AM
Pentosin Mania
by Snagglefoot - 07/01/20 11:30 PM
Spills. Synthetic vs petrolium
by Chris142 - 07/01/20 10:35 PM
Michelin Pilot Sport All-Season 4
by FordFocus - 07/01/20 10:04 PM
NGK Ruthenium Spark Plugs
by Deontologist - 07/01/20 07:49 PM
Ram Truck Speaker Upgrade Questions
by edhackett - 07/01/20 07:41 PM
OLM SCREWED UP
by demarpaint - 07/01/20 06:12 PM
Have Valvoline European 5w-40. Use in Cummins?
by RetiredGuyOR - 07/01/20 06:06 PM
Change in evaporation rate over time?
by mosschops - 07/01/20 05:56 PM
17 Golf overzealous OLM/Minder
by lawrencerd - 07/01/20 04:24 PM
First cell phone
by Chris142 - 07/01/20 04:08 PM
Motorcraft FL836 Specifications
by viscous - 07/01/20 03:41 PM
Chipmunks - Damit.
by PontiacHO - 07/01/20 03:37 PM
27/18k portable genset oil.
by 1978elcamino - 07/01/20 03:31 PM
Saw a new BMW and had to do a double take.
by wemay - 07/01/20 02:55 PM
Seems like there is less activity on BITOG
by SLO_Town - 07/01/20 02:21 PM
Rock Auto horrible customer service
by cknight49090 - 07/01/20 02:09 PM
RetiredGuyOR, BretBouer, JKMark, Tugcan, George_Robert
71821 Registered Users
28 registered members (BigGeo, Alaskanmont, AlienBug, caprice_2nv, Char Baby, 4WD, 3 invisible), 606 guests, and 27 spiders.
Topics307,389
Posts5,309,631
Members71,821
Passenger side tires wearing faster #5454058 06/14/20 10:22 PM
CharlieJ Offline OP
The tires on the passenger side both front and rear of my Mazda 3 are wearing out at a faster rate than the driver side tires. All tires are wearing evenly, just that the passenger tires are wearing faster. I had an alignment when I bought the current tires, around 15k miles ago, never hit anything. The passenger side tires are at the wear indicators while the driver side has about 1/3 life left.
Any idea why this would happen? Thinking of my driving routines, most of my turning are left hand turns.
'07 Mazda3 2.3 : Shell Rotella Gas TRUCK 5w-30
'84 Mazda Rx-7 : Valvoline Maxlife 10w-30
Re: Passenger side tires wearing faster [Re: CharlieJ] #5454062 06/14/20 10:29 PM
JohnnyJohnson Offline
At the wear bars in 15,000? What is the make of these tires? Are you the only one driving this car?
2004 Corolla 140556
Out: Pennzoil Platinum HM 5W-20 ST 4386
In: Valvoline Synpower Full Synthetic 5W-30 Purolator PureONE
2006 Duramax 77117
Out: T6 5W-40 XG9100 73909
In: Rotella Dino PH9100 11-3-19
Re: Passenger side tires wearing faster [Re: CharlieJ] #5454074 06/14/20 10:40 PM
O
oldhp Offline
O
Sounds like a NASCAR alignment. banana
"None of us are getting out here alive...drink that beer...eat that pizza...drive that Hot Rod"
"When others cut you down, remember where they came from."
"I don't run...........I just quietly wait"
Re: Passenger side tires wearing faster [Re: CharlieJ] #5454118 06/15/20 01:07 AM
Nick1994 Offline
Get a tread depth gauge on Amazon, there's currently one for $2.78. This way you can accurately measure each part of the tire to see if the wear is even or not, which looks can be deceiving.
2015 Hyundai Genesis 5.0L 62k Dealer Bulk SynBlend 5w20 & OEM
2000 Toyota Camry 2.2L 239k Mobil Delvac 15w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 150k Rotella Gas Truck 5w30 & Wix
Re: Passenger side tires wearing faster [Re: CharlieJ] #5454192 06/15/20 07:17 AM
B
BigCahuna Offline
B
Re: Passenger side tires wearing faster [Re: CharlieJ] #5454214 06/15/20 07:59 AM
CapriRacer Offline
I suspect we are dealing with an alignment issue that was corrected 15,000 miles ago, but since the tires weren't changed, the tires wore a new pattern on top of the old bad pattern.
To correct this, buy a new set of tires and just to be sure, get an alignment. Get the printouts, and look at them before you pay. Check to make sure everything is in spec. Many alignment shops won't tell you they didn't put everything in spec because that would require extra cost items.
CapriRacer
Visit my web site: www.BarrysTireTech.com
Re: Passenger side tires wearing faster [Re: CharlieJ] #5454248 06/15/20 08:56 AM
G
Gebo Offline
G
Do you just do a front to back rotation?
And do what Nick1994 said. A gauge can help you catch problems before you see problems.
Without trying to appear as a smart aleck, I don't put a lot of faith in alignment shop readouts. Here is my story and I'm
sticking with it. I had a problem with the right rear alignment on my LS430. It was fixed and taken back in for a new
alignment by another company 3 days later. Every tire read differently. Somehow the front toe had gotten out of spec.
Both were uniformly the same amount out of spec. Now as I type, I am wondering if the tech entered the correct car?
My LS430 doesn't have air shocks. Hmm...
If I had plenty of money and time, I would like to do an experiment where I drive onto 5 or so alignment machines and
compare their printouts.
If you are lucky, you may be able to find an older guy that knows how to align without a "computer." I found one here
that "everybody" uses.
'98 LEX LS400 310K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 75K
Shell Gas and Truck 5w-30
Amsoil OE 10w-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: Passenger side tires wearing faster [Re: CharlieJ] #5454264 06/15/20 09:20 AM
supton Offline
How hard do you corner? If stuff flies off the dashboard that might be a reason for the tire life.
Might want to start doing a cross rotation, and often with this sort of tire life (not every 7,500 that is).
What kind of tires are we talking about? If they are sticky (or cheap) this might be the expected life.
2011 Toyota Camry, base, 2.5L/6MT, 206k
2010 Toyota Tundra DC, 4.6L/6AT, 160k
2003 CRV, 2.4L/4AT, 161k
1999 Toyota Camry LE, 2.2L/4AT, 225k
Re: Passenger side tires wearing faster [Re: CharlieJ] #5454295 06/15/20 09:39 AM
Danh Offline
Any chance the passenger’s side of the car is always in the sun when you check tire pressure? In Florida this could make a difference, accelerating wear due to low pressure on that side as temperatures equalize.
Re: Passenger side tires wearing faster [Re: CharlieJ] #5454308 06/15/20 09:51 AM
A
Aredeeem Offline
A
Is your wife a little on the chunky side? Since my divorce I only have to do tire rotations every 40k and my mileage has improved 4 miles a gallon.
Re: Passenger side tires wearing faster [Re: CharlieJ] #5454960 06/16/20 06:55 AM
L
Lubener Offline
L
The crown of the road and more pot holes are usually on the right side which is why the right side tires may wear at a faster rate than the left ones. You say they are all wearing evenly so that would rule out an alignment issue.
The "thinking" man's friend.
Re: Passenger side tires wearing faster [Re: JohnnyJohnson] #5455050 06/16/20 09:02 AM
CharlieJ Offline OP
Dunlop Direzza DZ102. I’m the only one driving.
Re: Passenger side tires wearing faster [Re: CapriRacer] #5455051 06/16/20 09:03 AM
CharlieJ Offline OP
I had the car aligned when I bought the tires new 15k miles ago.
Re: Passenger side tires wearing faster [Re: Gebo] #5455056 06/16/20 09:10 AM
CharlieJ Offline OP
I had a tread depth gauge and noticed this a long time ago. Now they need to be replaced. I had the car aligned at a highly rated shop that’s been in the business for 40+ years, I would think they did it right.
The tires are directional so I could only rotate front to back. Won’t do that again...
Re: Passenger side tires wearing faster [Re: supton] #5455060 06/16/20 09:19 AM
CharlieJ Offline OP
The cornering has definitely effected tire life 😀 tires are directional so I couldn’t rotate from side to side. Next tires won’t be directional. Tire Dunlop Direzza DZ102, they aren’t the best tires but are better than these new ECO tires new cars are coming with, those are terrible for grip!
