Forums Migration
Please read this thread
anyone noticed worse acceleration with fram ultra?
by cals400ex - 07/09/20 08:39 AM
Good article on battery recycling
by Fattylocks - 07/09/20 07:19 AM
Civic rear wheel bearing
by toad - 07/09/20 07:06 AM
Nokian Entyre C/S
by Robster - 07/09/20 06:00 AM
Corolla Cross
by wemay - 07/09/20 05:51 AM
Pennzoil strikes again with PDS (Euro 5W40)
by edyvw - 07/09/20 01:44 AM
Extra Load tires - Firmer ride?
by Spetz - 07/09/20 12:34 AM
make sure to use a software firewall
by 2004tdigls - 07/08/20 11:02 PM
Castrol 0w40 without LL-01 in BMW S63
by propellerhead78 - 07/08/20 09:59 PM
Automated key duplicators
by y_p_w - 07/08/20 09:59 PM
0W20 vs 5W20 base oils
by aquariuscsm - 07/08/20 09:39 PM
Shell Rotella T6 Multi Vehicle 5w30
by SummitX670 - 07/08/20 08:56 PM
Silicone rubber valve cover gaskets?
by Spetz - 07/08/20 07:59 PM
Back Up Camera
by Redright9 - 07/08/20 07:53 PM
Good Jackstands?
by 2015_PSD - 07/08/20 07:17 PM
Harbor Freight recalls more jack stands
by FordBroncoVWJeta - 07/08/20 07:11 PM
can a family of 4 use 34k gallons
by WhyMe - 07/08/20 05:26 PM
305 SBC Starter Grinding
by WA1DH - 07/08/20 05:19 PM
Ever hit a water meter with your riding mower?
by bchannell - 07/08/20 05:10 PM
99Burbans, EmanInOz, Apollon, lulliya, bike70ride
71894 Registered Users
97 registered members (28oz, 2015_PSD, 1911CHAMPION, ARCOgraphite, AdamZ, afree, 13 invisible), 1,897 guests, and 45 spiders.
Topics307,632
Posts5,314,685
Members71,894
Page 1 of 3 1 2 3
How much torque is loss with extensions and swivels #5454053 06/14/20 10:11 PM
B
bowlofturtle Offline OP
B
This weekend I was trying to tackle sway bar end links. Here I am thinking, 15min - 1-hour job. Due to the design and overall lack of space and room, I was forced to use a swivel.
It was a 17mm head nut. I used a snap-on 3/8 impact swivel socket pair up with a normal 6inch extension and then a 3/8 to 1/2 adapter. At the end of that was my trusty IR 2135TI. Still unable to zip it off. On the other side, I was able to get with a wrench and cheater bar.
Yes, the car is old and rusty but still, that impact is able 600ft-lbs of reverse torque if not more. The nut shouldn't be much more than 40-100ft lbs. I assume the whole setup absorbed like 50% of the power. It should still be able to come apart.
The whole thing is now being soaked in PB blaster for another try later this week. A normal deep socket is can fit in the area but the ratchet head is too thick as its frame gets in the way.
Side note- How dangerous would be it be to drive on a car without the front swaybar connected? Its an AWD car, that front bar is VERY beefy. Its a highway cruiser car for the most part.
My toys
-05 Infiniti G35x 140k
-03 Suzuki SV650N 8.5k
Maintaining
-16 Jetta 1.4T 20k
-98 Nissan Maxima 160k
-09 Toyota Camry V6 96k
Re: How much torque is loss with extensions and swivels [Re: bowlofturtle] #5454059 06/14/20 10:22 PM
O
ondarvr Offline
O
There are too many variables to say how much torque is lost. Other than to say it can be significant.
Re: How much torque is loss with extensions and swivels [Re: bowlofturtle] #5454060 06/14/20 10:23 PM
CT8 Online Content
Online Content
I can't give a number on the loss of power through swivels and extensions but it is quite a loss.
2015 F150 2.7
2018 F350 6.2
Re: How much torque is loss with extensions and swivels [Re: bowlofturtle] #5454076 06/14/20 10:42 PM
Chris142 Offline
The problem is the twist in the tools is more than the tools anvil can spin.if you put say 100 ft lbs with a tq wrench and twisted till it clicked it would put 100 ft lbs on the other end. But you may have to make 3 revolutions of that tq wrench to do it
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: How much torque is loss with extensions and swivels [Re: bowlofturtle] #5454079 06/14/20 10:48 PM
M
motor_oil_madman Offline
M
I've never had luck with swivels, they always just spin off the bolt head.
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: How much torque is loss with extensions and swivels [Re: bowlofturtle] #5454084 06/14/20 10:53 PM
ctechbob Offline
Disconnecting the sway bar will generally give you more grip on that end....but, while I've driven with a rear bar disconnected (it was part of the overall setup of the car and fine) I'm not sure I'd be willing to just disconnect the front and drive around like that. Changing the balance of the car in a big way like that without other modifications would probably lead to something scary in an avoidance maneuver.
2008 Acura TL Type S-170k
2003 Honda Accord V6-222k
Oil-Havoline HM 5W30
Filter-Partsmaster 61334
Trans-Idemitsu H+
Re: How much torque is loss with extensions and swivels [Re: bowlofturtle] #5454161 06/15/20 06:08 AM
T
Trav Offline
T
You had a lot of shock absorbers in the form of torsion bars in that setup. Twisting torque is not how impacts works, it is how strong the mechanism hits directly on the fastener. Look at a 1/2" impact extension and how much thicker it is compared to chrome hand tool ones. It will also absorb some of the force just not as much.
To get the most force transmitted to the fastener the socket should be heavy and as direct to the anvil drive as possible.
This is where guns with big hitting power really shine, I have guns rated at 1400 ft.lb and an old IR231 rated at 450 ft.lb the old IR doesn't stand a chance right? That would be wrong, it has large hammers for its size and will remove bolts the larger rated gun failed to remove. Which sort of indicates to me anyway the torque numbers on the box are basically worthless advertising.
Remove the extensions or use thicker impact rated ones and it should come right off.
Re: How much torque is loss with extensions and swivels [Re: Trav] #5454191 06/15/20 07:16 AM
Chris142 Offline
I still use the 231 I bought back in the 80's. It seems to have more power than it claims. It will remove budd lugnuts from 18 wheelers.
Re: How much torque is loss with extensions and swivels [Re: bowlofturtle] #5454217 06/15/20 08:10 AM
B
BMWTurboDzl Offline
B
This link is close: https://www.utilityproducts.com/too...torque-values-when-using-torque-adapters
Basically you have to know how far off the centerline your wrench is from the fastener. I'm not talking distance in terms of extension. For example with no swivel the wrench is 0 degrees away from the bolt (ie. it's on top of the bolt) regardless of the length of the extension used. Using a swivel at say at 10 degrees the wrench could be 1/2 inch off the centerline of the bolt or more depending on the length of the extension. At 45 degrees it could be 6 inches or more from the centerline of the bolt.
In practice unless the swivel has a fixed amount of travel (ex, max 10 degrees) you're not going to be able to accurately calculate the required TQ.
435i
Re: How much torque is loss with extensions and swivels [Re: bowlofturtle] #5454233 06/15/20 08:41 AM
supton Online Content
Online Content
Swivels and extensions can twist, and the torque applied by the impact wrench can be absorbed, leaving little to actually hit the bolt. If you were to use a breaker bar and apply torque manually, there would be no loss, the system would just twist--but with the impact, it's twist and release, twist and release, and it's just not giving that impact force to the nut/bolt.
One winter i noticed my Camry seemed to be rolling in the corners a bit more than usual. I thought gee, I guess It's a Toyota... wasn't until I did a tire rotation that I found a sway bar link had given up the ghost. Would guess I drove like that for at least a month. Obviously the car will roll around, and in the event of a sudden lane change, it may fail to react appropriately. But it's not like it's going to suddenly launch off the road. Cars for a while didn't have swaybars at all. I certainly wouldn't want to drive it very hard, but I bet if you take it out cautiously, find some empty roads and drive to see how handling has changed, that it will be just fine. Might drive more like a Jeep than whatever it is, but hey, Jeeps are still driven on the road and they occasionally make it to their destination.
2011 Toyota Camry, base, 2.5L/6MT, 206k
2010 Toyota Tundra DC, 4.6L/6AT, 160k
2003 CRV, 2.4L/4AT, 161k
1999 Toyota Camry LE, 2.2L/4AT, 225k
Re: How much torque is loss with extensions and swivels [Re: bowlofturtle] #5454240 06/15/20 08:48 AM
A
ARCOgraphite Online Content
Online Content
A
Originally Posted by bowlofturtle
This weekend I was trying to tackle sway bar end links. ...
..... How dangerous would be it be to drive on a car without the front swaybar connected? Its an AWD car, that front bar is VERY beefy. Its a highway cruiser car for the most part.
Don't go on the highway with a front bar disconnected and a REAR bar still connected, that will make the car excessively tail happy and a moderate fast lane change will loop you. Thats not good in rush hour. Think "The BIg One" at Daytona cup races..
Around town 35 MPH you should be fine unless its REALLY hilly and the roads are wet.
Again it will be easy to loop the car.
Take her around the block and test it out before going further.
Cars didn't have aniti-sway bars when I was younger.
Anti-sway bars take away the independent suspension. Now the left and right are linked with a torsion bar.
Now you can run lower rate springs and make up for the listing with the sway torsion bar stiffness.
Remember watching old 40's and 50's cop chases with the cars going around the corner listing at 25 degrees!
I think you'll be fine and dandy - if you don't go on the highway.
-Ken
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#9 70254mi-Rotella
Gas Truck 5W20 + Fram Ultra 7317 Filter
Re: How much torque is loss with extensions and swivels [Re: BMWTurboDzl] #5454392 06/15/20 12:24 PM
dbias Offline
That's what I was wondering. Any attachment that increases the distance from the centerline of the bolt or nut would in effect increase the amount of torque being applied. That's why torque wrenches are not affected by a straight extension but cheater bars or crows feet do change the torque values.
With a swivel on an impact driver I'd say the any slop or play in the swivel will lessen the impact shock of the impact gun.
2011 VW JETTA RIP totaled at 180k 😥
2012 FORD TRANSIT CONNECT Castrol Edge 5W-30
2016 HONDA CIVIC COUPE Casrol Edge 5w-30
2017 AUDI A4 Ravenol 5W-40 RUP
2019 VW Jetta SE factory fill
Re: How much torque is loss with extensions and swivels [Re: bowlofturtle] #5454503 06/15/20 02:38 PM
circuitsmith Offline
I had an aftermarket front sway bar bracket break on my 1981 Accord.
In hindsight I realized the handling had become twitchy over the previous month or so.
Then one night on a twisty road (Beach Drive in Wash. DC) in a heavy downpour, doing about 35-40 I spun out.
I managed to keep it on the asphalt, rolling backwards.
Also in hindsight I realized the brackets for the front and rear swat bar kit,
being stamped steel and flimsier than the original brackets,
weren't a good combination with the thicker front bar and added rear bar.
2017 Hyundai Tucson SE FWD
SuperTech synth, 5w-30, 5000mi/12mo OCI
Re: How much torque is loss with extensions and swivels [Re: bowlofturtle] #5455394 06/16/20 04:35 PM
B
B
Thanks all for the feedback. Going to try again this weekend.
I'm going to pick up some wobble extensions and maybe a semi-deep socket to avoid the impact swivel socket i had on there. I did use the impact and also by hand. A breaker bar under the car on jack stands doesn't have much room.
Aside from that, gotta do the walk of shame to the shop.
My toys
Maintaining
-16 Jetta 1.4T 20k
Re: How much torque is loss with extensions and swivels [Re: bowlofturtle] #5455500 06/16/20 06:36 PM
slacktide_bitog Offline
This video shows no torque loss from using an extension. Torque loss through a swivel is mostly because you change the angle
Page 1 of 3 1 2 3
