Planes fly over white house after speech
by 1978elcamino - 07/04/20 10:16 PM
Code reader advice
by 53' Stude - 07/04/20 10:05 PM
People driving less / motor oil prices?
by 1978elcamino - 07/04/20 10:02 PM
Fireworks and dogs
by 555 - 07/04/20 07:52 PM
Cannot unscrew oil filter housing cap - BMW E46
by 97tbird - 07/04/20 07:21 PM
Are u a big fireworks person?
by ZZman - 07/04/20 06:53 PM
Honda Accord MAP sensor question
by Kira - 07/04/20 06:28 PM
Hy-Gard Shelf Life (Opened Bottle)
by viscous - 07/04/20 06:10 PM
Want to bet on my luck? (atf to "save" transmission)
by Snoman002 - 07/04/20 06:10 PM
Too Much Zinc = Corrosion?
by viscous - 07/04/20 06:00 PM
New vehicles with a 4 speed transmission?
by MrHorspwer - 07/04/20 04:57 PM
Inability to Choose
by Gene K - 07/04/20 01:53 PM
65 200 6 mustang running kinda hot
by old1 - 07/04/20 01:30 PM
Neo-protec GT em
by dervdave - 07/04/20 01:19 PM
Mannol 9929 Ester additive
by dervdave - 07/04/20 01:14 PM
2015 Corolla with 7k miles has “soft brakes”
by NHBFAN - 07/04/20 12:30 PM
Put Bilsteins on the Silverado
by bdcardinal - 07/04/20 12:19 PM
SilentC, paolo9fla, SunnyB, Mullady76, Axia2
71848 Registered Users
47 registered members (Bfrost99, Alaskanmont, Alex38, bdcardinal, ABerns, 3 invisible), 877 guests, and 24 spiders.
Topics307,436
Posts5,311,032
Members71,848
Overthinking this...Need some help #5454050 06/14/20 09:58 PM
B
BTLew81 Offline OP
B
Not like overthinking is unusual here, but....
We’ve got a 2019 Acadia 3.6 that my wife drives. It’s a lease with two years left. I daily a 2019 accord 2.0t. I do oil changes on both.
The Acadia gets a d1g2 oil as required. I’m not too concerned as the 3.6 seems well sorted. The accord, on the other hand, I know has a tendency to dilute and is harder on oil. I’ve stepped the accord up to a 5w30 as a result. The accord I plan to keep around for a long time.
Both get 5k OCIs...the Acadia because that’s about where the oil life monitor puts me, the accord because I don’t think I’m good going much beyond that.
I’ve toyed with going to Amsoil, ravenol, or something “fancy” in the accord to get the lowest noack, highest pao/poe, etc. then I have this rational moment where I realize that at 5k intervals, this might not be that smart and offer much benefit.
After some thought while on vacation, I’m starting to think going to vanilla M1 5w30 in both. Easy to get, should be fine at 5k, and I can get the 12 quart box (for now) for 3.75/qt. Has all of the approvals I need and will probably make the accord last for as long as I want to keep it-5-7 years.
Cons? Not the best noack, nor the highest group 4/5 content. Does this really matter, probably not.
Any thoughts on this approach? I’ve been using castrol edge in both. No complaints other than having to buy a single quart to fill the Acadia. However, I’m not married to Castrol and not convinced there is anything “better” about edge.
Any advice/thoughts/words of wisdom or comfort? 🤣
Thanks.
2018 Honda Accord Sport 2.0T/10 Speed
Modern Steel Metallic/Black
Factory Fill/Filter
Re: Overthinking this...Need some help [Re: BTLew81] #5454056 06/14/20 10:19 PM
O
ondarvr Offline
O
Don't overthink it.
Put oil in them and drive.
Re: Overthinking this...Need some help [Re: ondarvr] #5454063 06/14/20 10:30 PM
L
littlehulkster Offline
L
Originally Posted by ondarvr
Don't overthink it.
Yeah, frankly this might not come across well on a forum dedicated to overthinking oil, but from everything I've seen here, if you run a good quality synthetic oil (and everything commonly available at the parts store will usually qualify) of the weight the manufacturer recommends and change it on time, you will have no problems, regardless of if you just buy whatever's cheapest or run pure unicorn blood.
For OP, both those are pretty good engines, don't stress over it. Vanilla M1 5w30 would be perfectly fine in both of them if that's what you want to do, but they'd also probably be fine on 0w20 if the manufacturers recommend that.
2015 Mazda3 I 2.0
Re: Overthinking this...Need some help [Re: BTLew81] #5454064 06/14/20 10:30 PM
M
MontePrix28 Offline
M
Since the Acadia is a lease, and if you do not plan on buying it out and the end of the lease, why not just put d1g2 Supertech 0w20/5w30 (whichever it specs) and an ACDelco filter? Following the OLM. Less than $20 out-the-door at Walmart.
Regarding the Accord, I definitely agree with the step up to a 5W-30 with it being a direct injected turbo. I know in Europe, Honda specs the civic's 1.5T (L15B7) from 0W-20 to 10W-30. I can't imagine the 2.0T being any different. If you need the cold-start capabilities: mobil 1 0w-30.
Re: Overthinking this...Need some help [Re: BTLew81] #5454067 06/14/20 10:33 PM
4WD Offline
Try your zip code for these boxes ?
Re: Overthinking this...Need some help [Re: BTLew81] #5454070 06/14/20 10:36 PM
B
BTLew81 Offline OP
B
Thanks all. The M1 12 qt box is 45 near me. Wish it were cheaper. Lol
Maybe I’ll move to that for the accord. Use the rest of the Castrol I have on the Acadia. Or maybe M1 5w30 ep for the accord.
Good call on the st for the Acadia. Not a bad idea and will probably work just fine.
To be perfectly honest I’ve thought about running both of them on Kirkland 5w30....and I’m sure that would work just fine at reasonable intervals.
Factory Fill/Filter
Re: Overthinking this...Need some help [Re: BTLew81] #5454078 06/14/20 10:45 PM
U
userfriendly Offline
U
Would me suggesting 0W40 M-1 FS for both cars upset the thinnies?
Re: Overthinking this...Need some help [Re: BTLew81] #5454087 06/14/20 10:59 PM
B
BTLew81 Offline OP
B
Wouldn’t upset me. Lol. I do get a bit worried moving up that much in terms of “weight,” but the 0w40 is a stout oil.
Factory Fill/Filter
Re: Overthinking this...Need some help [Re: BTLew81] #5454105 06/15/20 12:07 AM
U
U
Didn't think so. 4WD's post is a good one, and look how cheap the 5W30 is. We can agree on the filter. M-1 0W40 is my sever winter go to oil. Like when I get sent to Hinton, Alberta in January and it's 42 below.
Re: Overthinking this...Need some help [Re: BTLew81] #5454153 06/15/20 05:48 AM
T
Triple_Se7en Offline
T
How many miles will the Accord accumulate in 5-7 years? Because that's your time-frame for getting rid if it, Supertech will work there.
If I weren't a birth-to-old age death vehicle owner, Supertech would be all I would run.
Stay Safe - Stay Healthy
Happy July 4th
Pennzoil Ultra Platinum // Mobil-1 EP // Valvoline Synthetics
Re: Overthinking this...Need some help [Re: BTLew81] #5454165 06/15/20 06:28 AM
B
BTLew81 Offline OP
B
5-7 years is an estimate. We are expecting our second child in August so I figure once the kids are bigger and we’re traveling more we may want a second suv to spread the miles. The accord is my favorite car I’ve ever had. I want to treat it as such and feed it very good fuel and oil without going crazy.
Factory Fill/Filter
Re: Overthinking this...Need some help [Re: BTLew81] #5454185 06/15/20 07:04 AM
K
ka9mnx Offline
K
M1 5w-30 is a good choice for the Accord. Mobil1 says their oil is good for 10k so your covered at 5k. The lease? I wouldn't bother with expensive oil. SuperTech would also be good for both. I don't plan on getting rid of my vehicles and see what I'm using.
2005 Ranger 3.0 - SuperTech Syn 0w-20/Motorcraft
2000 4Runner 3.4 - SuperTech Syn 5w-30/Toyota
1997 B2500 Van 3.9 - M1 HM 10w-30/Mopar
1993 F150 4.9 - SuperTech Syn 5w-30/Motorcraft
Re: Overthinking this...Need some help [Re: BTLew81] #5454194 06/15/20 07:19 AM
B
buster Offline
B
Regular Mobil 1 grades are PAO/GTL/AN. I just took a look at the latest MSDS for M1 5w20 and it's 30% PAO/30% III. Years ago Mobil 1 was PAO and 15% POE. Over time, likely due to Castrol and people being cheap, we started to see the shift of synthetics going to III.
I personally wouldn't care much about what goes in the leased car. For the Honda I'd go with 5w30 EP. If it calls for a 20 grade, I'd go with EP 0w20. The 0w20 will hold its viscosity better than the EP 5w30.
2020 - Mazda CX-30 - Mobil 1 EP 0w20
2019 - Subaru Impreza - Dealer Oil
Re: Overthinking this...Need some help [Re: BTLew81] #5454300 06/15/20 09:41 AM
B
BTLew81 Offline OP
B
Thanks Buster. It does suggest a 20, but with a tgdi I just sleep better at night with a 5w30. That’s what it’s had for all 24k miles. No impact to mpg or anything. So perhaps M1 5w30 Ep is the way to go. Any insight on the group 3/pao mix on that oil?
Factory Fill/Filter
Re: Overthinking this...Need some help [Re: BTLew81] #5454333 06/15/20 10:39 AM
T
TrainingPolicy Offline
T
While I completely understand overthinking the type of oil I use, understand that it's still a Honda. Hondas are typically very easy on oil, even with the fuel dilution problem. If you use an approved oil and change it according to factory specifications or before you shouldn't have a problem. Mobil 1 is a great choice, or you can go with Pennzoil Ultra Platinum that is another great oil. If you are really worried about fuel dilution then every so often when you are getting on the highway just put the pedal to the floor, it should get the engine spinning fast enough to 'burn off' some of that excess fuel in there.
2003 Infiniti G35 6MT 105k
2005 Honda Accord 237k
2010 Hyundai Santa Fe 112k
