FJC Foaming Evaporator Cleaner Review
by Reddy45 - 07/04/20 12:10 AM
Ford 351W oil filter best value
by alex16 - 07/03/20 11:12 PM
Super tech euro 5w40 - Canada
by Johan1 - 07/03/20 10:19 PM
Strangers show up for vet's funeral.
by simple_gifts - 07/03/20 09:44 PM
Troybilt tb22ec refuses to run correctly
by Dogred08 - 07/03/20 09:43 PM
Harbor Freight Nitrile gloves
by 1978elcamino - 07/03/20 09:04 PM
Did anyone get a 25% coupon for July 4th?
by 1978elcamino - 07/03/20 08:58 PM
05 4.6 Northstar crank sensor re learn?
by cknight49090 - 07/03/20 08:40 PM
In the year 2049...
by eljefino - 07/03/20 08:05 PM
2-year old oil 124 Spider
by DAC17 - 07/03/20 07:57 PM
New to us van
by ram_man - 07/03/20 07:22 PM
original '05 Chrysler trans pan gasket material ?
by visitor - 07/03/20 06:16 PM
rock auto can't ship to Calif????
by 928 - 07/03/20 06:04 PM
2001 Silverado 1500 T-Case Fluid
by Blang - 07/03/20 05:53 PM
Nasty Car wreck
by ford46guy - 07/03/20 05:53 PM
Best style of condenser?
by ddeflyer - 07/03/20 05:17 PM
Advance Auto now selling Die Hard Batteries
by Kira - 07/03/20 05:01 PM
Ontario Nuclear update - Part 2
by OVERKILL - 07/03/20 04:36 PM
Is this totaled?
by NoNameJoe - 07/03/20 04:23 PM
Johan1, MrMoneyMcLube, JeffAR, ThaKid22, Speedeuphoria
71843 Registered Users
31 registered members (Brad1119, blufeb95, BLND1, carlprop, 2009Caraman, 4 invisible), 914 guests, and 41 spiders.
Topics307,396
Posts5,310,319
Members71,843
Drill through cinder block or mortar? #5453915 06/14/20 06:17 PM
dlundblad Offline OP
I’m wanting to add an outside spigot and will need to drill through the foundation.
Is it preferred to drill into the block or the mortar?
Thanks.
03 Jeep WJ 4.0 208k
02 Volvo S60 2.4T 199k
97 Chevy Blazer 4.3 175k
04 Audi A4 3.0 210k
Re: Drill through cinder block or mortar? [Re: dlundblad] #5453920 06/14/20 06:23 PM
P
PowerSurge Offline
P
Block
1993 Porsche 964, 2001 Ford SVT F-150 Lightning, 2004 Chevrolet Corvette, 2018 Toyota Tundra and a few others
America First
Re: Drill through cinder block or mortar? [Re: dlundblad] #5453933 06/14/20 06:40 PM
R
Rand Offline
R
block with hammer drill should do it. how big a hole 3/4"? 1"?
Re: Drill through cinder block or mortar? [Re: dlundblad] #5453938 06/14/20 06:43 PM
ABN_CBT_ENGR Offline
Definitely drill through the block
Re: Drill through cinder block or mortar? [Re: dlundblad] #5453944 06/14/20 06:47 PM
E
E150GT Offline
E
Why?
1984 Mercedes-Benz 300SD - 100k
1995 F150 XL 4.9 reg cab 5MT - 253k 5w30
2016 Mazda6 Touring 6MT - 81k 5w30
2006 Buick Lucerne CXL 3.8 50k 5w30
Re: Drill through cinder block or mortar? [Re: E150GT] #5453952 06/14/20 06:56 PM
L
Lubener Offline
L
Originally Posted by E150GT
Why?
why not.
The "thinking" man's friend.
Re: Drill through cinder block or mortar? [Re: dlundblad] #5453965 06/14/20 07:17 PM
B
BISCUT Offline
B
Block. Drilling through a block with I assume the correct bit so as not to cause a blowout on the backside; should leave the block structurally sounder than if you were to take a 3/4" hole or thereabouts out of the mortar ans surrounding block. I don't know for sure but highly doubt your block has anything more than 1/2 joints. Guessing your piping is 1/2" so you'd be drilling through some of the cornerstone of the block as opposed to a more center portion.
Think of a hole in the center of a 2x4 or a hole taking out a piece of the edge of a 2x4. What would be stronger under load? The 2x4 drilled in the center by far.
2015 F150 Lariat M1 5-30 EP FRAM Ultra(48k)
2017 Sub OB M1 5-30 EP FRAM Ultra(78k)
Re: Drill through cinder block or mortar? [Re: Rand] #5453970 06/14/20 07:28 PM
I think the spigot pipe is 3/4”? It’ll likely be 1-1/8.”
03 Jeep WJ 4.0 208k
04 Audi A4 3.0 210k
Re: Drill through cinder block or mortar? [Re: dlundblad] #5454001 06/14/20 08:22 PM
PimTac Offline
Hammer drill with a masonry bit. I’ve done it a fair amount of times.
2017 Mazda CX5
Mobil 1 Annual Protection 0w20
Roki OEM filter.
Re: Drill through cinder block or mortar? [Re: dlundblad] #5454183 06/15/20 06:58 AM
A
Amkeer Offline
A
Drill through both sides with a smaller bit to locate. Then drill through both sides with the larger bit.
2014 Toyota Tacoma D Cab 4.0 M1 5-30 107000
2008 Toyota Tundra D Cab 5.7 M1 5-20 100000 miles
2003 Toyota Tacoma Ex Cab 2.7 M1 5-30 220000 miles
2020 Toyota Camry SE 2.5 600 miles
Re: Drill through cinder block or mortar? [Re: dlundblad] #5454224 06/15/20 08:31 AM
R
ragtoplvr Offline
R
Drill thru block. These days it is common to fill block with concrete. Be advised this will take a few extra min to drill with hammer drill.
Do not drill thu mortar, the mortar is softer than the block. You can lift a block and break the mortar. Also some code require rewire in the mortar That will add to the fun of drilling.
Rod
Re: Drill through cinder block or mortar? [Re: dlundblad] #5454247 06/15/20 08:56 AM
J
JohnG Offline
J
And don't drill through the middle of the block! That is where the WEB is. Most block are partitioned in the middle with solid concrete web, go off center from that, by about a third, there will be two voids, one on either side of the center web. Try to hit that area and your job will be easier.
Re: Drill through cinder block or mortar? [Re: JohnG] #5454294 06/15/20 09:38 AM
N
NormanBuntz Offline
N
This plus drilling slow and steady will keep you from dulling the masonry bit.
Porgy Tirebiter: "Heavy on the 30 weight, Mom."
2017 Toyota Camry XLE, 13K, 2nd owner
2007 Honda Ridgeline RTS, 98K, original owner
2007 Infiniti M35, 116K, original owner
Re: Drill through cinder block or mortar? [Re: JohnG] #5454301 06/15/20 09:42 AM
N
NormanBuntz Offline
N
Re: Drill through cinder block or mortar? [Re: dlundblad] #5454916 06/16/20 04:47 AM
Thanks for the replies everyone. I have done the job before for a gas line, but this area had no block. The stoner at the rental place told me $15 for 4 hrs. Well, that was for the bit ONLY. Renting the actual hammer drill was an additional $35. I was done with it in less than 1 hr.
Had I known that, I would’ve entertained buying one seeing how I have all the jobs lined up for it. Like right now, I’ll be spending another $50 so that’s $100 that could’ve went to buying the tool.
Oh well.
03 Jeep WJ 4.0 208k
04 Audi A4 3.0 210k
