Brp 2t vs xd100
Bethlehem pa
Not watching what I was doing I put a half gallon of 2T full synthetic brp oil in my ficht Di outboard. There was 2 gallons of xd100 in the reservoir. I use xd 100 simply because many say its the best for carbon buildup in the old fichts. I might have the last running 1999 150hp. Need it to stay that way at least through this season. Should I dump the reservoir or are the oils compatible?
I could guess but why not contact the oil bottlers .Out boards are expensive.
You probably already solved your issue but the XD100 was probably over kill for your engine. Also, your full synthetic BRP is a top quality oil. I wouldn't lose sleep over it.
