Forums Migration
Please read this thread
DIY Injector cleaning - What cleaner?
by Spetz - 07/13/20 12:50 AM
Rock Auto promo code
by daves66nova - 07/12/20 11:09 PM
05 Dodge 4.7 L head gasket blown again
by vwmaniaman - 07/12/20 09:44 PM
How come every vehicle’s MPG computer is off?
by OppositeLocK - 07/12/20 09:37 PM
Glock Gen 5 .40 Caliber
by BlueOvalFitter - 07/12/20 08:34 PM
Help me determine if my CVT fluid has been changed
by Dallasmale1970 - 07/12/20 08:01 PM
Hyundais, Hyundais, Hyundais!
by csandste - 07/12/20 07:57 PM
Traveller's (WPP) $10.99 - 5 QT
by Gene K - 07/12/20 07:26 PM
PEAK 10X or Peak Global Lifetime
by pbm - 07/12/20 07:25 PM
Nio stock. How high will it go?
by motor_oil_madman - 07/12/20 05:34 PM
AAP Rotella Gas Truck Clearance
by Sam_Julier - 07/12/20 05:32 PM
Any 47RH Transmission Experts? CTD Ram
by JHZR2 - 07/12/20 04:58 PM
WM Magna1 10w30 gallon $5
by 2strokeNorthstar - 07/12/20 04:55 PM
I found a WWII movie for yinz to watch.
by JimPghPA - 07/12/20 04:45 PM
Jackpoint Jackstand Review
by RamFan - 07/12/20 03:03 PM
Lesabre Brake fluid capacity
by Ihatetochangeoil - 07/12/20 02:56 PM
Baking Cookies in the Car - 2.0
by Nick1994 - 07/12/20 02:17 PM
Dealer ruined my transmission!!!!
by John344 - 07/12/20 02:04 PM
Mark_C, fxxkat, Ajreitano, Slick122, Ford4life76
71917 Registered Users
48 registered members (Astro_Guy, Amkeer, Bailes1992, 77GrandPrix, 87sammy, 5 invisible), 975 guests, and 25 spiders.
Topics307,781
Posts5,317,740
Members71,917
STP and RISLONE Zinc #5453772 06/14/20 02:12 PM
W
whizznbyu Offline OP
W
Went to my local OReilly to get a new battery and moseyed on down the oil additive aisle. Saw Rislone and STP oil treatments and both have Zinc. Is too much Zinc bad for the motor if the DPF and cat are irrelevant?
Re: STP and RISLONE Zinc [Re: whizznbyu] #5453777 06/14/20 02:19 PM
K
kschachn Online Content
Online Content
K
How much zinc do you need?
1994 BMW 530i, 253K
1996 Honda Accord, 289K
1999 Toyota Sienna, 437K
2000 Toyota ECHO, 290K
Re: STP and RISLONE Zinc [Re: whizznbyu] #5453828 06/14/20 03:21 PM
K
krismoriah72 Offline
K
" moseyed on down the oil additive aisle"
Which oil needs additives?
Re: STP and RISLONE Zinc [Re: krismoriah72] #5453862 06/14/20 04:33 PM
4WD Offline
Diluted oil ?
Re: STP and RISLONE Zinc [Re: whizznbyu] #5453928 06/14/20 06:33 PM
A
ARCOgraphite Offline
A
You want ZDP? Buy some Cam Makers wear in additive.
I'm sure the OTC snake oil stuff is very weak, maybe even less PPM than ILSAC Motor oil IIRC a recent VOA.
Wearing in an aggressive ramp flat tappet cam - That's when you really MIGHT need it.
Sometimes a bet extra it helps "velvet" things out on "raucous" engines.
Many Engines use very short slipper skirt pistons and have long "Big Block" strokes of 4" or more.
This can make the TDC " turn around" a bit "stick slippy" and Ive hade a ZDP boost smooth things out .
But that was through a High Treat rate ODPE lube not from Snake oil .
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#9 70254mi-Rotella
Gas Truck 5W20 + Fram Ultra 7317 Filter
Re: STP and RISLONE Zinc [Re: whizznbyu] #5454010 06/14/20 08:35 PM
T
tenderloin Offline
T
From Rislone website
A "snake oil" response?
Can I use Rislone Hy-per Lube ZDDP Supplement in my newer vehicle?
No, you should not use Engine Oil Supplement with Zinc Treatment in 2005 and newer gasoline and 2007 and later diesel engines. Current oils have enough Zinc to protect moving parts inside newer engines. However, to help prevent sludge and keep that engine clean, it is recommended to use Rislone Engine Treatment p/n 100QR or 4102 on all newer engines.
How is Rislone Hy-per Lube ZDDP Supplement different than break in additives (Cam Makers wear in additives from above post)?
Break in additives contain extremely high concentrations of ZDDP and are only designed to be left in the engine for a short period of time. Many of these additives don’t contain detergents or other lubricity additives important to keeping your engine clean and lubricated for thousands of miles. Rislone Engine Oil Supplement with Zinc Treatment not only contains the correct amount of ZDDP, but also the other additives important to protecting your engine. Do not use as a break in additive.
TYPICAL TEST RESULTS INDICATE:GASOLINE ENGINES
With typical SN rated oil at a 7% dosage rate expect levels to be raised to a total of:
Zn Zinc 1700 - 1800 ppm
P Phosphorous 1500 - 1600 ppm
Rislone Zinc
Re: STP and RISLONE Zinc [Re: whizznbyu] #5454250 06/15/20 08:59 AM
A
A
Good to know.
So we can put the Rislone in NOT SNAKE OIL category. - At least as far as composition is concerned
But ZDP does have detergent action so that statement is not totally correct.
And the treat rate can be adjusted to get the desired % Phosphorous, typically ~ 0.12
For a while most ZDP boosting additive were disappearing from the market likely under pressure from Automakers, SAE, ILSAC and API. Three- way catalyst and thin film wideband lambda can be sensitive to earth metal deposits
I wonder if some general advisory have lapsed or they just don't have any teeth.
