Originally Posted by Triple_Se7en
Originally Posted by PWMDMD
This has always been my issue with others doing my oil change. Unlike going in for brakes, tires, replacement of a faulty part where most times it is obvious whether or not something was done, with oil changes, in particular, it would be so easy to not change the oil and say you did. Few people probably check the oil in the first month after an oil change and by then ok sure it's getting darker. Even if they do change the oil there's no way to know what they actually used. I've had at least one UOA come back more like a 5W-30 when they said they were using 0W-20. For all I know it was cheap 5W-30 conventional. Is it the end of the world? No, but not what I paid for and for cars going 7500-10000 miles not what should be used. So now I do it myself every time.
The worst part about getting bulk oil-oil changes is additive settlement in the bulk tank. The customers being served the bottom-half of the bulk tank are getting more additives that settled there, than those being served from the top-half of the tank.
Not everywhere does this happen. It all depends on how often that bulk tank gets refilled.
Not to hijack but I always wondered about bulk oil in tanks and additive pack(s). Do they ever get "mixed", off the truck and wheeled onto the shop floor?
