Used CVT fluid in a power steering application
by mahanddeem - 07/05/20 02:06 PM
New Mobil1 EP HM, API SP label design.
by wemay - 07/05/20 02:00 PM
Generator oil
by Eddie - 07/05/20 01:51 PM
This never ceases to amazing me
by SLO_Town - 07/05/20 01:46 PM
Empty shelves and lack of variety.
by sloinker - 07/05/20 01:17 PM
Mann HU816 (28 month service)
by Barwich - 07/05/20 12:23 PM
Napa Gold 1348 and Mahle OC148 C&P
by BeerCan - 07/05/20 10:38 AM
Dead rechargeable batteries on cordless drill
by 97tbird - 07/05/20 10:35 AM
2018 Silverado 6.0 Idle Stumble
by Phishin - 07/05/20 10:20 AM
U.S. Gasoline Production
by Snagglefoot - 07/05/20 07:39 AM
Trying to save an otherwise junkyard bound car
by agarb - 07/05/20 07:08 AM
Code reader advice
by 53' Stude - 07/04/20 10:05 PM
People driving less / motor oil prices?
by 1978elcamino - 07/04/20 10:02 PM
Fireworks and dogs
by 555 - 07/04/20 07:52 PM
Cannot unscrew oil filter housing cap - BMW E46
by 97tbird - 07/04/20 07:21 PM
Are u a big fireworks person?
by ZZman - 07/04/20 06:53 PM
Honda Accord MAP sensor question
by Kira - 07/04/20 06:28 PM
Hy-Gard Shelf Life (Opened Bottle)
by viscous - 07/04/20 06:10 PM
TacoFergie, electro, SilentC, paolo9fla, SunnyB
71850 Registered Users
96 registered members (andy2001, 2K2AcuraTL, 4WD, 97tbird, 92saturnsl2, 2010Civic, 8 invisible), 2,009 guests, and 22 spiders.
Topics307,449
Posts5,311,381
Members71,850
Front Porch Rail #5453606 06/14/20 09:51 AM
B
BISCUT Offline OP
B
I built my house 15 years ago. I have a 35 foot front porch that I build the rail system using Philippine Mahogany, pocket screw and Gorilla glue joinery. It is solid! The spindles are square cut and straight and the top cap is easily sanded. Love it. I originally had used Australian Oil but subsequently went with Helmsman urethane. I have a mahogany door that I also have Helmsman on. I kept up with the door and it's a ok. I am guilty of not taking care of the rail system and now have to sand it down and re-apply Helmsman.
My question is....what is the best way to sand the spindles? Is there a power tool that can make easy(ier) work of this? Time is really precious. I'd like to be able to do it myself and but if hand sanding is the only option...ugh. Looking for suggestions.
Thanks in advance.
2015 F150 Lariat M1 5-30 EP FRAM Ultra(48k)
2017 Sub OB M1 5-30 EP FRAM Ultra(78k)
Re: Front Porch Rail [Re: BISCUT] #5453630 06/14/20 10:16 AM
samven Offline
I dont know of a power tool that will do spindles and depending on the damage I would not recommend sandpaper. Try using a 00 steel wool to get the bad stuff off and if you need a smoother finish follow with a 0000 steel wool. Less chance of rounding corners and gets into tight spaces easier, it cuts the shine and leaves a good surface for recoat to bind to. Might even find its more work but faster than a power tool with sandpaper.
Re: Front Porch Rail [Re: samven] #5453644 06/14/20 10:38 AM
B
BISCUT Offline OP
B
Frankly I've been a hobbyist woodworker for years. I mix some of my own finishes to hand rub and use steel wool for the very reason you state. Yet for some reason I did NOT make this connection to the rail.
Thanks for the suggestion.
Re: Front Porch Rail [Re: BISCUT] #5453713 06/14/20 12:25 PM
spasm3 Offline
There are 3m sanding pads that work well by hand, some aggressive , some finer. I use them a lot.
Buff down with these, light coat of stain to get any areas that went through, and to stain the dust in the joints, then re-polyurethane.
https://www.homedepot.com/p/3M-3-7-...-Hand-Sanding-Pads-2-Pack-7448/301118025
https://www.homedepot.com/p/3M-3-7-...-Hand-Sanding-Pads-2-Pack-7447/301117170
[Linked Image from images.homedepot-static.com][img]https://images.homedepot-static.com[img]
13 elantra 84k 5w30 synpwr
17 mazda cx-5 19000 miles m1 0w30
Re: Front Porch Rail [Re: BISCUT] #5453718 06/14/20 12:46 PM
Danno Offline
I would consider something like this.
https://www.amazon.com/Oscillating-...ool+sander&qid=1592156693&sr=8-9
Had to replace part of a shed door jamb that rotted, worked great to match the new and old pieces and sand off the old paint.
2019 Jeep Grand Cherokee Summit 5.7L Hemi
2019 RAV4 Limited Hybrid
2016 Sorento SX V6 AWD
2010 Mazda 3 2.0L
Re: Front Porch Rail [Re: BISCUT] #5453891 06/14/20 05:13 PM
M
MasterSolenoid Offline
M
I have recently started hating Steel-Wool.
Makes a mess by leaving dust.
For my (interior) wood projects, I will used a Foam-Brush to apply Polyurethane and lightly sand with
400 grit paper to remove any bumps followed by a final coat of Poly.
My suggestion: Go to Home Depot and look thru their sandpaper section.
I believe they have various grits with a 'soft' backing pad (about 1 inch think).
This would give you the ability to follow the contour of the spindles.
Enjoy your porch.
[Linked Image]
2002 Ford Ranger / bought new
2 Wheel Drive
3.0 Liter Engine
Four basic premises of writing:
Clarity, Brevity, Simplicity, and Humanity.
