Originally Posted by bullwinkle
Originally Posted by PimTac
Those baseplate holes have sharp and ragged edges.
I agree, I wonder if the inner edges of those holes would cut the ADBV (as we've seen many Puro filters do). Guessing the purpose is to induce a rotation inside the can (outside the media)? I'm not sure I buy the idea behind that, since the pleats are vertical and not angled in the direction of rotation. DuckRyder, how is the can strength? Does it seem any thicker or stronger than a standard Ultra? That has always been one of the Ultra's (few) weaknesses, along with paint/Sure Grip flaking.
The inside of the tapping plate is smooth, I will grab a picture.
No immediate impression that the can was stronger (or weaker) I will try to measure though the paint may creates issues.
Originally Posted by GSCJR
Thank you for taking the time to post these DuckRyder!
You're Welcome.
Edit: Also like the Force, the center of the dome end can is slightly concave.
Unclear if this is simply a tooling change or was done with some purpose. I don't recall ever having seen this on FRAM of any description before.
