Ford 351W oil filter best value
by alex16 - 07/03/20 11:12 PM
Super tech euro 5w40 - Canada
by Johan1 - 07/03/20 10:19 PM
Strangers show up for vet's funeral.
by simple_gifts - 07/03/20 09:44 PM
Troybilt tb22ec refuses to run correctly
by Dogred08 - 07/03/20 09:43 PM
Harbor Freight Nitrile gloves
by 1978elcamino - 07/03/20 09:04 PM
Did anyone get a 25% coupon for July 4th?
by 1978elcamino - 07/03/20 08:58 PM
05 4.6 Northstar crank sensor re learn?
by cknight49090 - 07/03/20 08:40 PM
In the year 2049...
by eljefino - 07/03/20 08:05 PM
2-year old oil 124 Spider
by DAC17 - 07/03/20 07:57 PM
New to us van
by ram_man - 07/03/20 07:22 PM
original '05 Chrysler trans pan gasket material ?
by visitor - 07/03/20 06:16 PM
rock auto can't ship to Calif????
by 928 - 07/03/20 06:04 PM
2001 Silverado 1500 T-Case Fluid
by Blang - 07/03/20 05:53 PM
Nasty Car wreck
by ford46guy - 07/03/20 05:53 PM
Best style of condenser?
by ddeflyer - 07/03/20 05:17 PM
Advance Auto now selling Die Hard Batteries
by Kira - 07/03/20 05:01 PM
Ontario Nuclear update - Part 2
by OVERKILL - 07/03/20 04:36 PM
Is this totaled?
by NoNameJoe - 07/03/20 04:23 PM
Burned and boycotting!
by sloinker - 07/03/20 04:23 PM
Johan1, MrMoneyMcLube, JeffAR, ThaKid22, Speedeuphoria
71843 Registered Users
71 registered members (ammolab, 02F250XLT, BigCahuna, aquariuscsm, alex16, Alaskanmont, 7 invisible), 1,368 guests, and 34 spiders.
Topics307,394
Posts5,310,299
Members71,843
When redlined... #5453366 06/14/20 01:48 AM
coleyork250 Offline OP
What would cause a car to burn oil and smoke blue when revved to redline while sitting still? Also black and some slight white smoke is emitted as well. What is causing it?
Re: When redlined... [Re: coleyork250] #5453370 06/14/20 01:55 AM
Chris142 Offline
Stuff you should not do.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: When redlined... [Re: coleyork250] #5453373 06/14/20 02:19 AM
Nick1994 Online Content
Online Content
Don't do that
2015 Hyundai Genesis 5.0L 62k Dealer Bulk SynBlend 5w20 & OEM
2000 Toyota Camry 2.2L 239k Mobil Delvac 15w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 150k Rotella Gas Truck 5w30 & Wix
Re: When redlined... [Re: coleyork250] #5453386 06/14/20 02:59 AM
J
joekingcorvette Offline
J
Yep, thats a no no.
2005 Chevrolet Corvette
2014 Ford F-150 4x4 supercrew
2014 Jeep Grand Cherokee Limited (wifes)
2012 Honda Civic 4 door (my daily driver)
2007 Lund Tyee Grand Sport Mercury 115HP 9.8HP
Re: When redlined... [Re: joekingcorvette] #5453391 06/14/20 03:16 AM
Yes, but what would cause that? The engine has blow by as well. It was not maintained by the previous owner.
Re: When redlined... [Re: coleyork250] #5453392 06/14/20 03:18 AM
dishdude Online Content
Online Content
Neglected engine being abused.
2018 Challenger SRT 392 PUP 0w-40 Wix 57899XP
2018 GTI M1 Euro 0w-40 Wix WL10024
2019 Tiguan Castrol Edge Pro 0w-20
Re: When redlined... [Re: dishdude] #5453394 06/14/20 03:24 AM
Yes, but what is wrong with the engine that would be causing that?
Re: When redlined... [Re: coleyork250] #5453396 06/14/20 03:36 AM
M
michaelluscher Offline
M
Well, what would cause blue smoke at any RPM?
Think worn rings or valve guides/seals, putting oil into the exhaust or cat
Once you bring the RPM's up, you force it all out
That's my personal experience with older Mitsubishi V6's and Honda I4's when they really get neglected, old, and tired
Or a Toyota 2AZ with shot rings and clogged piston drain holes
Black smoke usually means fuel, so some kind of fueling or combustion problem (lean or rich)
Usually rich, like my carbed SBC Grand Prix when the purge valve went bad, was nearly pouring raw gas out the tailpipe it was running so rich
Villager pulled the same stunt when the fuel pressure regulator went bad
'20 XT4 Premium Luxury 2.0T, breaking in all the toys
'06 Camry SE 3MZ-FE 146K
'06 Taurus SE Vulcan 65K
'01 Villager Estate VG33E 55K
'83 Grand Prix LJ 305 SBC 56K
Re: When redlined... [Re: coleyork250] #5453479 06/14/20 07:35 AM
ABN_CBT_ENGR Offline
Theoretically, any number of things.
Theres a point in electro-mechanical machines where the near instantaneous potential of reaction of electrical components start lagging due to hysteresis of input sensors. There is also a point where the "mechanical" actions simply cannot keep up with that speed and cyclic function.
Then add that to outer ranges of tolerance then things such as wear and or other properties of supporting things such as the individual lubricant as well as elevated forces.
Most likely a combination ( percentage unknown) of all of the above.
Re: When redlined... [Re: coleyork250] #5453514 06/14/20 08:04 AM
demarpaint Offline
There are lots of reasons, including an old tired engine. Then there's neglect, and/or worn parts from doing that, especially to a cold engine. It begs the question of why do that? The last time I revved an engine in the manor you stated was back in the days of carburetors and linkage hanging up, which I immediately corrected to fix the issue.
God Bless Our Troops
Re: When redlined... [Re: coleyork250] #5453521 06/14/20 08:12 AM
supton Offline
Sounds like it's worn out. If it was neglected then it likely has a fair amount of wear--getting blowby past the rings, which can also let oil into the cylinder, so that's blue smoke. Black could be from blowing out carbon, but that would be a momentary thing. If it does that continuously then maybe it's a bad O2, bad injector or something else way off, causing a rich condition.
White smoke could be just moisture in the system being boiled off, a few high rev's heating up the exhaust quickly and getting rid of any moisture.
What engine is this? Any EFI motor should be capable of going WOT in park and the electronics should prevent damage. Does it rattle, knock or make other ominous noises?
2011 Toyota Camry, base, 2.5L/6MT, 206k
2010 Toyota Tundra DC, 4.6L/6AT, 160k
2003 CRV, 2.4L/4AT, 161k
1999 Toyota Camry LE, 2.2L/4AT, 225k
Re: When redlined... [Re: coleyork250] #5453533 06/14/20 08:29 AM
P
philipp10 Offline
P
Strange question. You just said the engine has blowby.....what more needs to be said. Blowby is basically air, some gas and oil pushed into the crankcase then ran back thru the PCV to be burned. The rings are loose.
Re: When redlined... [Re: coleyork250] #5453540 06/14/20 08:40 AM
A
ARCOgraphite Offline
A
Worn valve guides and dried up stem seals, worn rings and ... a blown head gasket.
This thread reads like I may not wish you to be driving on the road.
So, I hope the engine throws a rod very soon.
-transmission ended -
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#9 70254mi-Rotella
Gas Truck 5W20 + Fram Ultra 7317 Filter
Re: When redlined... [Re: coleyork250] #5453646 06/14/20 10:41 AM
J
Jethro_Bob Offline
J
Engines will go into open-loop before redline. Engine could have been perfectly fine before you basically dumped an unmetered amount of fuel into the cylinders while the pistons were operating at high speeds. Which could be the cause of all the problems you describe.
+2 to thrown rod to keep you off the road.
Re: When redlined... [Re: coleyork250] #5453677 06/14/20 11:35 AM
M
mk378 Offline
M
All his neighbors are rooting for that too.
